- tuning seminar
- Ams
- Making a race gas tune ?'s
- 4 wheel slide tune!!! :)
- Is Engine management necessary?
- Motec M800 PnP Harness for the Evo IX?
- Blue tooth
- engine hose..setup?
- launch control
- i'm new her.searching parts for evo 9.
- AFR = 0, Lambda = 1
- What Engine Managment??
- New here
- tunning experts please read my concern
- Can the dealer tell?
- Compressor Surge?
- Do I need my OEM ROM or will the Aktive Matrix do?
- Logs from Good Tunes
- Short ram intake question
- Schools of thought on tuning?
- help
- new flash method
- Which Reflash to get?
- Which Flash??
- Trying to tune - 2 questions
- what to do after fried coil pack?
- new here. need some help with my evo
- need help searching about tunes
- SES code P0000 and P0011 Please help?
- MoTeC or GEMS???
- Engine or Boost Issue after 1/4 mile runs
- Zeitronics help!!
- Check Engine/Tuning Question?
- What EGT are people seeing
- ECU Flash and Vista..?
- dual stage MBC for 20psi and 12(WG) psi......possible?
- Who flashed my car? Is there a way to tell?
- here's a ? for the tuners
- SES "Engine Overboost Condition"?
- Need to tune evo and live in ND!
- Need Help, SAFC II or Flash??
- Can't decide on which tuning method
- ACD and Anti'lock lights blinking
- dyno4mance tune!!!!!!!!!
- Anyone have ttp flash
- Ecu tune & Fuel Pump. Help a Nub out Please !
- Street Tuning advice?
- Ecu and Immobilization code Question at Mitsubishi Dealership
- Anyone Logging with Macs?
- What to log with?
- Need Help with Mitsulogger
- good place to good car tuned?
- High Knock
- Tuning help
- Tune after cam install?
- logworks live tracking
- Logging/Wideband weird result
- USB to serial that work with the lc1
- Need tune advice
- Machines Gone Wild
- Car Trouble: Slipping Clutch??? Not Sure Help!
- Injector resistor pack - removal or not
- Jestr M0 flash and M1 ?
- need a tune!
- Sharing Some Dyno Tunes we did at Vivid Racing
- Missfire Issues
- 2 Step/Launch control bounces of limiter very slow???Help!
- How often do you log?
- Best tune in NC
- Knock sum vs. Knock voltage
- High Gear Issue
- Tuned @ YIMIS
- Hks Evc6 Questions/how To
- EVOscan ?????????
- Good tuner in Virginia Beach Area???
- How do I put more power using stock turbo???
- 91 and 93 octane and tuning
- AFR variations due to temperature?
- Need help on finding a place for tune
- Stock Evo AFR
- Looking For Others That Want A Tune From Ams In Tampa, Fl Area
- E85 AVAILABLE in TAMPA,FL !
- Boost gauge "T" Question? Never been asked before!
- evoscan help
- Fcon Vpro
- help!! need jdm tuner in fl
- thinking about offering my Stock ECU tuning services...feeler
- help me fix evoscan!!!
- how do i run 2 maps on a laptop?
- Overcame fuel cut & started logging
- Data Log Lab aka DLL errors
- Strange boost and A/F ratios need help!
- MAN ! What does it take to get someone to tune your car??
- Stock EVO IX MR... lumpy idle normal? Need some answers please!!
- stock ngk gap at .32
- The value of a tune.
- Motec Plug N Play Question
- i need some logging and tuning help!!!
- Which Falsh
- gauges on a radio?
- AEM UEGO Acting funny
- HELP! EVO rough idle and stall & no full boost
- NOS what type EVO VIII?
- where to buy ecu jumper harness
- Tune solve misfires?
- MSD DashHawk?
- Using Two ECU'S
- Which is better turboback, cat-back?
- Apexi AVCR settings help
- Need Boost Help!!!
- Boost Control Question/Problem?
- I want to get tuned...but?
- Results of fooling around with the stock BCS
- 04 and 05 transmission?
- datalogging ?????
- Zeitronix boost log - long decay time
- AMS tunes? (Atlantic Motorsports, not Automotorsports)
- Stock Ecu Swapping????
- SES with tactrix?
- IX Whp and Tq on Dyno Dynamics w/ TBE, MBC, and 20-22psi
- Just Got back from ISP
- So you STILL haven't purchased a Tactrix Cable?
- Hks 3037 kit
- Ecu flashing error
- Serial to USB adapter that works.
- E-Flash (Dynoflash) Question or Two before writing to ECU
- 2003 Evolution 12 PSI?
- MAS cleaning
- Mitsulogger
- Free Datalogger?
- How to go back to stock
- So Much For a BaseLine Dyno Run
- HKS mushroom causing knock?
- street tune/ part out question
- A/F measurement. Which O2 sensor?
- Anyone have this code before?
- How much would i make on the dyno?
- LC-1 / LMA-3 Users....Where did you connect for your power source?
- My exhaust fires flames, is it wrong?
- For Sale Hks Ssqv Bov
- Lean AF at peak torque
- Dynoflash E-Mail Flash on the way!
- Can people post examples of various logs generated - in CSV format.
- speedelement tune?
- Anyone running MAP sensor on stock ecu or flashed ecu?
- Innovate exhaust clamp with LM-1 ?
- Overboosting problem?
- Restrictor pill removal necessary for ECU reflash
- P0171 Code Help!!
- s-afc??? help
- Problem holding up the boost in my EvoIX
- Just Got Flashed
- LC-1 good start?
- EMS for Gt35r?
- selectable map tuning options?
- Engine knock problem
- HKS evc ez II boost controller few questions
- profec setting problems
- Hks Ssqv Bov
- Tuner Question..queries question
- Is anyone on this Forum Running there car on a Wolf 3d ecu?
- Cosworth just contacted me about their new Evo standalone....
- Bung for LM-1 sensor
- what computer mangment should i get
- Can immobilizer be removed?
- ECUtek... hp gains???
- tuning question
- My Dyno tale - Guidance from Alfred @ Tuning Tech and Jestr M1 flash...
- Need a tune
- werid noise when you crank the car
- Beware the Dynojet Wideband
- So who else is tuning AEM's?
- Can this be done?
- possible whp from dyno flash?
- Innovate LC-1 Compatible USB to Serial Converters
- Cam gains before and after flash?
- Tuning estimate w/ ECUtek>s-afc(selling)!!!
- AFR'S and EGT's
- leaded or unleaded?
- ECU Addressing?
- should i get retuned
- Dumb tuning ?
- IX Tuning Technologies Dyno graph - 91OCT
- just a noob question about logging
- UTEC vs ecu Flash
- Switching back to stock injector question.
- Tuning Selection for Newbie
- pocketlogger
- boost solenoid removal...
- What do you use to run your race gas and pump map?
- The stock 05 evo build has begun
- Orange County
- Problem after changing to Ralliart ECU on EVO 6 TME
- Any one has s stock IX AFR chart?
- Knocklink sensor
- Greddy V-Manage
- ECU Flash in Seattle Area?
- n00b question
- warrenty is fianlly gone, which reflash now?
- Anyone else get SES light from the Perrin cat
- "Service Engine Soon" light question
- Datalogging, knock, and Octane Flag reading...
- Cannot Reflash My Car!
- k i got a hks intake and ground kit for xmas
- AFRs too lean in high-load -> need fuel pump?
- got my new evo, I have questions about tuning and logging equipment
- 2.3L management
- ECU Harness IX
- tunning for low,mid,high power?
- ECU Flash
- wat to do
- Jester Tuning in Socal!?!?!??!
- problem with AEM wideband accuracy
- Which ECU?
- Wideband After Cat Accuracy
- Lift throttle knock
- GM MAP sensor trouble
- EvoScan Log: Help!
- WARNING: COSWORTH EVO IX CAMS SHAFTS... BEWARE... exhaust cam shaft does not align!!!
- got flashed
- Dynoflash Custome Tune 320whp, 347wtq
- Ix
- Technical question about boost...
- Too much boost!!!
- Apex'i ITC
- more knock and more logs + something interesting
- boosting
- When to replace o2's?
- stand alone ?
- log , any thoughts?
- check my log out
- HKS 280 Cam timing
- I/C Spray
- boost issue
- Correct Pin-out For Zeitronix ZT2
- Most Bang For The Buck?
- Treo Palm Pilot Phone w/data logger.
- zt2 software
- fuel cut question
- Dyno graphs Wanted: Meth/Pump/Racegas. SAME MOTOR.
- Why Methanol can blow you up without a failsafe?
- Where is the OBDII port on an IX?
- Evo III OR IV parts
- houston, tx area tuner and dyno
- Which Wideband?
- What should I do for a tune?
- air/fuel?
- What's the cheapest method for datalog (afr, knock,...) ?
- New used evo going on dyno need info.
- LMA 3 timing install
