- VTA with a MAF Translator?
- Reflashing a stcok ECU
- Running Weird Question
- Tuning beyond WOT
- Unusual load reading observed during datalogging
- just put an injen intake
- bad afr's....
- EVO III low boost
- Afr
- AFR in the low 12's
- Who needs an ams tune in hawaii
- What is this on the motor?
- xpost: Need help with ECUFlash, possible issue with Injectors scalling or fuel map
- evo dies
- After Mivec Tune (Service Engine) Light turn on
- ECU patch harness evo VIII
- Zeitronix and Vista users....
- Reputable Shop Tune VS Local Tuner Tune
- Evoscan question
- I need a tune in the Tulsa, OK for my new 50-trim Kit **HELP**
- Problem with bigger injectors and utec....please help!
- bigger intercooler now getting knock
- Whats max power b4 stand-alone?
- Start Car up..Idles high 3000 RPM (Help)
- Evoscan / Mitsulogger / ECUFlash / MAFT GEN2 Help!
- engine flush
- Pop Quiz
- Datalogging options? Noob needs help
- Evo Tuners with boost hose pills
- Anyone running VP Import Race Fuel
- Tuning 101
- Cobb Access Port!!!
- ok tried this in the general section..cat to testpipe
- wideband vs afr meter
- Need help New to logging
- immobilizer help
- Vishnu Reflash
- Tuning Schools
- what should i go with
- very new to this
- EvoScan v1.0 graphing?
- Getting a Tune
- Flash question
- Need a tuner in south florida
- EvoScan question
- Loss of power at low rpms
- 780's with a 35r?
- Idle
- Fuel Capacity - Racing Cell?
- aem uego
- ACT street clutch kit or CARBONETIC super clutch
- Help... Got an Older Turbo Timer..
- Want to Get My EVO IX MR Tuned near CHICAGO
- New website is up! Mellontuning.com
- MoTec Ecu for Evo's - Standalone or PnP units
- reflash + cams or Intercooler? which would u choose first?
- 08 Lancer Running Lean?
- Race Gas on 93 tune
- Is someone runnig a cut-out exhaust?
- Looking for Tuner
- AFR Kit for electronic guys!
- hallman boost controller is it worth?
- Should I use a boost controller for this setup?
- ecuflash questions
- saving and switching maps
- Load vs TPS vs Efficiency
- Is Shell V Power all that ???
- Load vs. Load ???
- Evo Questions help plz?
- Dyno2003 Engine Simulation
- Enginuity
- How low does the AEM UEGO read? (richie rich)
- Injector signal oscilloscoped?
- California Tune up
- General Tuning Question Regarding Flashes,Piggybacks
- necessary to tune for new setup?
- First trip to the dyno - EVO IX SE
- Some questions before i start modding...
- What about this setup?
- NEW FP GREEN, setup doesn't produce expected power!!!
- Need to get tuned!! I live in NEW HAMPSHIRE!
- Cold Start Idel Problems With Hks Eids
- AMS tune "Very pleased'
- HKS EIDS Type K
- Another IVEYTUNE Happy Customer
- Error code and CEL!!! Please help!
- Best Injectors for EvoGreen setup
- Help with Exhaust Manifold
- Need some help stage I and stage II maps nocking
- trying to use a narrow band A/F meter
- Wide band O2 sensor question?
- tuned by CBRD today
- hks turbo
- After market ECU
- High Coolant Temp?
- Ses/cel Po136
- Need some help, Map knocks in 4th.?
- Help with evoscan...invalid serial?
- Water Temp Increase
- speed shop
- Could the tune be the problem?
- is tuning required
- please help car not starting!
- Apex tubro timer wiring ???
- Boost Level Check
- Need help in southern cali
- Kind of stuck with ECU situation
- Please Help Me Out Asap
- P0300
- Rich Fuel
- reading knock sum
- Greddy V Manage
- EvoScan Glossary
- How to change two step launch limiter rpm
- Low AFR's using Evoscan
- is there a evoscan for dummies??
- Good Tuning Books?
- Has anyone here have been tuned by nate?
- Turbo sounds like Supercharger?
- problems with evoscan v0.99
- help deciding
- EvoGreen and BC 272's
- Fuel Pressure / IPW Fluctuation
- Ecu
- Gauges to keep an eye on my engine
- EVOSCAN vs PROSCAN which is best??
- Need Help with E-Flash InformatioN!! Plz!
- ECU Reflashing?
- **350z Guy here Need Help Tuning Apexi AVC-R
- Need Replacement Connector for Greddy Profec B Spec II
- HELP!!! Unknown issue caused -30whp "blurp" on dyno
- Help!
- TTP Tuned?
- Evo VII ralliart ecu
- Funny looking dyno graph inside!
- Reading the stored values in the ECU
- Delay in WB02 readings?
- Tuning and Injectors Question
- [Need help] Problem with throttle position
- HELP! Evo Tuning in Illinois??
- tune at LSE Performance
- Will my car make it
- is a re tune required for upgrading downpipe?
- SES LIGHT? Can EVOSCAN pull the code?
- Is It a General Consensus?
- Can someone process (power) my Zetronix Log?
- tunning
- Best ECU Mail-IN Flash?
- ecu flash
- Cold Idle Problem
- ECU flash by 4-wheel-slide
- Advice Please on Vishnu Stage 2 kit?
- Sputtering Issue
- WORKS flash / ECUUnlocker questions
- blow-through MAF
- New to tuning, what to look for?
- What's the purpose of a wideband if anlready tuned?
- Jester Tuneing
- Ralliart ECU
- Prosport Gauges.
- DLL DYNO comparison my modded EVO8 GSR vs Stock EVO9 MR
- 01 lancer
- Ecuflash wont read ecu
- intake and tb ???
- Wideband Comparison
- Max wastegate duty
- can 100 octance change AFR?
- Ems...
- Avcr Help
- OBDII pinout
- EvoScan and 2G DSMs
- New to site recently purchased EVO MR
- Problem with Fuel Cut In Need of Help!!!
- stop cel with anti foulers.
- evo 9 cams
- 272's and tune
- Boost leak test
- build boost on the line?
- Custom air box?
- Evo VII GT-A ECU
- MOTEC Fuel testing on Evo9
- Wideband
- Email flash
- Tuner Shops
- Another gauge
- Engine Management
- Set Fuel pressure with engine out of the car
- Flashes vs Engine managment
- Engine Ice.
- Choking Issue
- Which do most prefer....
- To Advance, or Retard?
- vishnu vs gruppe-s
- ?'s for TTP
- St Louis Flash
- Possible Immobilizer issue - original stock ECU won't start car
- ECU wiring schematic?
- Retune from summer to winter?
- Zeitronix boost sensor not showing vaccum?
- Very Crappy! My LM-1 Died!!!!
- Billet Design!
- Bigger injectors?
- Cannot connect, probs with tactrix cable
- Haltech EMS?
- LC-1 problems ... HELP !!
- Drivability and MPG re: Opinions on my flash
- Tuned by Sean Ivey Today
- I need help logging Evoscan with Innovate LC-1
- Need tach signal for data acquisition
- AGENCY POWER....vs....HKS Ti....vs.....GREDDY Ti-C
- Dyno run video (Did some upgrades today)
- Ivey Tune
- Installing Cams Without Tune
- Machines Gone Wild (MGW) Tune
- Need help. Bad Idle
- Reseting the ECU
- Check Engine Light On ( Engine Over Boost)
- Log reading help
- Need A Tune !!
- Test Pipe or high flow cat
- tune shops in ny???
- Help! Any Jestr affiliates, need a new map asap!
- Buscher Modified Walbro Pump
- IX spare ADC pin?
- Mitsulogger --> Excel
- my evo9 RS need 350hp+
- HKS EVC VI problems
- wideband?
- 02 cel and Ecu safe mode question
- Radiator Fan Issues on an IX?!
- 2 Step install
- tuning?
- HKS EVC III 3 electronic turbo boost valve controller
- How to find a Turb back exhaust system thats quiet as stock??
- Apexi avcr or Blitz dual sbc?
- EcuFlash & EvoScan works on new MacBooks??
- What has to be checked to log load?
- is it natural that u get richer AFR in higher gears?
- Greddy Profec E-01... RPM signal?
- serial to usb help
- LogWorks3 Beta 1 released today.
- My first log
- NY Flash
- AEM or Flush
- newb tuning ?'s
- Economic Driving :D
- Boost Problem
- Dont waste $ on Racegas unless tuned on it?
- Props to 4 Wheel Slide
