- Innovate ot-1 obd2/CAN interface? lm2 info?
- Evoscan 2.1 Problem please help
- Help
- evoscan help
- to xede or not?
- code reader
- Help the electrically challenged (me)!
- Greddy B-Spec II Tuned for 20 PSI
- Is this complete
- Max safe BHP output on EVO7.
- Just reflashed!!!
- need some help on connecting LC-1 to laptop
- MAF vs. MAP using Factory ECU
- EMS experiences
- Evo X MAP Sensor
- New FMIC and Piping Retune??????
- Missing Evoscan Hex Files
- WORKS Vs. K&N
- Noob tuner, with a couple logs
- 400 whp - what to do?
- evo 1 gsr tuning??
- idle sensor problem help pls
- obd2 connector
- boost cotrol question
- How to pick the cam i need? 272 280 270 etc???
- help with gear box..
- Hks F-con Is
- Help Gems ecu stopped working
- Lc-1 gauges
- t70
- need help on what to do next..
- what is wrong!!!!!!!!
- 30r question...need help asap!
- mitsulogger
- Switching from AEM to HKS F-Con V Pro
- Wideband Shootout!!
- Trying to get 2byte load to work with mitsulogger
- Ecuflash and Apexi Neo Question
- Tune and Scan Tool Question
- $1000.00 to burn, you know the drill.
- Just a little information
- Cdi Cop
- How much does mivec on the evo help with spool up of a big turbo compared to a evo 8?
- Slow spool stock turbo
- Anyone run HKS F-Con Vpro?
- any1 tuned by ICS?
- please help me
- Base Tune Neo Help!!!
- Evoscan 2.0 Reading problem!!!
- In dash computer
- knock after drop-in filter install
- EGT gauge issue...
- New Car Help
- Removing my turbo this weekend. Any tips?
- What is needed to convert your Evo from 93 to E85?
- My Evo's Dyno - input needed please!
- Do I need more fuel to make 400whp?
- LC1 installed by a shop, help me find it!
- questions about tune..
- Boost control !?
- What hardware?
- F Con V Pro Users\tuners
- Evoscan v2.0 NEED HELP!
- Zeitronix EGT broken??
- dissconnecting battery
- Apexi Avcr losing settings
- TTP Tuned Dyno Chart
- Correct values for innovate lc-1 to emulate o2 sensor with test pipe DP
- ECU boost control
- Getting/Making charts from Mitsulogger
- What do tunned Fuel maps look like?
- Evo ix Basemap
- What can't you do in BOOTCAMP?
- p0300 on evo x!
- Vishnu Flash Question/Help
- In Need of a Stock EVO IX MR Rom.
- Balance Shafts
- Q on wideband.
- LC-1, XD-16 Error 2 (first use)
- Ecu Flash
- Fuel Trims +60%, Help
- Help, no spark after new engine install
- Differences between dyno tune and mail flash
- !! Very useful ECU Readiness Code Steps specifically for Passing Emissions with P0300
- Map sensors
- silly white connector
- Does anyone use ecuedit?(LC-1 ref)
- Evo 2 Step?????
- New Tune For My Car
- Defi boost gauge broken??
- Please Clarify my Wideband Research (Innovate/Zeitronix)
- Question about tuning
- dyno tuner in the OC
- Question about my '06 MR
- Tune?
- Activating Evoscan Alarms/Triggers
- Anyone using ECUEDIT?
- Limit of engine EVO VIII?
- idle keeps dropping??
- anyone have info on evo X ecu, tuning, stock or base maps, etc...???
- Dave Buschur or Tym Switzer?
- Aftermarket IC Tuning question
- should I do a tune? what do you all think? tuners???
- log with aem wideband?
- Can't change Timing/Fuel Tables
- please help?!?!?!
- ODB-II Port
- Tuning Questions
- Worth a tune?
- Making a tuning cable?
- Can I ground my LC-1 to the ECU?
- Where to place Lc-1 unit
- Who is tuned at 18psi?
- ECU locked need help
- Question for professional tuners
- Newbie question on immobilizer code
- misfire code p0300
- Can someone break down ECU LOAD for me?
- Ticking noise
- question about hks eids
- Can't get mistulogger and inovative to work
- Standalone? or Tune Stock ECU?
- loggin 2byte load with Evoscan or Mitsuloger help me
- Carolina Residents Attention
- exhaust rap
- noob question
- twin fuel pumps question
- service engine soon light
- only hits 160% load
- What should I do?
- Traction Control on EVO?
- Question about extending wires for LC-1
- First Steps...
- intakes and tunes?
- Tuning in winter vs. summer
- Losing your tune?
- ZT-2 Lcd screen slow!!!
- Can Mitsuloger log a/f ?
- Tactrix cable problem...!?!?!
- Need advice on WB02 and placement
- determining target A/F
- Brian Crower Cams - How do they compare to cams twice the price???
- Log boost: JDM MAP vs. Aftermarket gauge?
- pro efi ecu
- Mid throttle knock at 2500-3000
- Premier Evo Tuner?
- p172 from Hell and Factory ECU- HELP
- slow spool
- Mods Before Dyno Tune Question/
- Question about GM 3 BAR Map Sensor
- so i went to inquire about a tune...
- Aem Ems Or Apexi Power Fc And Commander
- Aem Ems
- anyone not know how to do own mods?
- Whats the difference in tunes?
- Need Data log lab car definitions standards
- evo 9 back to stock
- Slipping Clutch?
- Variable Geomeetry Turbo on EVO?
- ecu question
- Logging and tuning in cold temps.
- questions about simple log parameters
- need advice on WBo2 sensor
- dyno'd! rich air fuel, help
- What gear do you use to Dyno your 5 speed Evo
- LogWorks 2 issues, maybe laptop related...any ideas?
- aem uego cant log with evoscan, need help
- do i need a retune please help
- Easy ECU question...
- Which direction to take with engine management
- maps???? do they exist??
- little help pls
- Affect of Lower Reading TPS on ECU
- Need to buy a base Lite tune with my mods!
- Re-tune after 10.5
- Is this log too lean??? Tuning Guru's please look
- What to gap plugs to
- How to get Log in table form??????
- Must I run-in/break-in my new cams before tune?
- Motec M4 - need help in tuning
- Why Lower Boost on Alchy Than Race Gas?
- tuner question
- Tweaking my 91 oct map
- Does the stock ECU record driving patterns?
- Gus' EvoIX MR Tuning Story
- AFR fluctuates up and down?
- EvoScan 2.0 release
- Tune and the dealership
- car runs rich after fill up
- Need to get My Evo Tuned
- Just got flashed from Ivey
- 04 ECU into an 03 evo
- is this right???
- Good stock ECU writeup?
- hydra ems
- need opinion
- Do EVOs sux that much....
- Check out my log please
- hp gain and tuning
- Need tuner in Austin.
- Need help guys.
- What benifit w/O2 housing and mods
- Houston! Can someone please log my tune?
- Getting flashed on a dyno next week-any advice?
- LM-1 evoscan Q
- Okada coil packs
- question about my AF #'s
- Blitz Induction Cover +Drop in filter
- Optimal timing???
- IX Log
- MBC or JDM Map Sensor
- Which engine management product?
- EVO IX SSL Weight?
- Lc1
- Rev matching knock
- Need Help Installing Wideband
- Stock map plz
- 06 IX MR log
- Walbro 255 Fuel Pump
- fp evo green & 780cc inj NO TUNE
- Opinion on hp/tq and a/f graphs
- Question: Removed DynoFlash tune and set back to stock
- Evoscan will not connect.
- Will someone view these logs for me please. . .
- Urgent Hks Blow Off Valve
- logging issues with windows 98..
- Comparing Innovate LC1 to AEM Uego
- Zeitronix signal wires ...
- evscan airflow/rev units
- HYDRA or AEM EMS
- afc ?
- Car running extremely rich just in stalled WB o2 censor just ruined it running it ?
- Innovative wideband wont work.
- Help 21 AFR ???
- Help..Stalling with stock BOV
- Cobb Tunning
- Po172 Need Help
- thanks atlantic motorsports great tune*****
- evoscan logging in a 99 eclipse gst
- Searching for tuner in New England RI area anyone know of anyone ?
- IveyTuned my evo VIII
- Hks V-pro
- Ams Dyno Tune
- Can I Adjust My MBC While Having A Tune?
- What is the best air intake for EVO9?
- Tuners in Austin, Houston, Dallas???
- nippon denso 560cc injector latency
- how many of you who have gotten tuned, log your car after the fact?
- VTA with a MAF Translator?
