View Full Version : General Engine Management / Tuning Forum
Pages : 1 2 [3] 4 5 6 7 8 9 10
  1. Stock Evo 9 MR rom file
  2. Does tactrix still sell logging cables?
  3. MAF sensor problems!
  4. Wideband/Boost controller opinions?
  5. Just got Tuned and now error codes
  6. tuning school
  7. what injector size???
  8. Gt Pro Performance????
  9. sotck bottom end durability
  10. Stroker pistons on stock crank?
  11. Methanol
  12. LC1 Analog out as o2 sim
  13. Stock 8 Turbo Gears to -9/-9 ???
  14. Is it worth it ?
  15. How to identify an Evo 9 turbocharger?
  16. vishnu tuning....
  17. HKS 280 Cams?
  18. mail in flashes?
  19. Learning how to read logs
  20. Tell me if this tool will help me?
  21. Differences between stock airbox and open filter
  22. Wideband calibration during decel with Evo
  23. HKS EVC VI qusetion???
  24. Topspeed Dyno Tune
  25. Please help diagnose my friends IX
  26. NewTurboBack - flat dead at WOT
  27. putting a cat back on the car, reflash needed?
  28. Evoscan 2.4 and ACRelaySw field
  29. evo scan ?????
  30. EVO8 low boost (11psi)
  31. How to learn this stuff basics to all of it?
  32. o2 housing?
  33. Stock Evo with MBC - what psi to set?
  34. Greddy T78 33D
  35. What cause car to stalled out in neutral??
  36. the antilag will damage my turbo???????
  37. What kind of power should I get with these mods?
  38. EVO IX ecu location
  39. Boost map question
  40. P0403 And P0107???????????
  41. AEM Tru Boost Tuning - Need some advice please!
  42. evoscan 2.4 not working with aem wideband but version 1.0 does
  43. Most Important Guages For Tuning
  44. Difference between EVO Turbos
  45. My mod choices
  46. StandAlone Computer
  47. Want to have my buddy tune the car what software for stock ecu?
  48. which aem P&P or Universal?
  49. stock ecu issue
  50. V-manage
  51. cam sensor issue or ?
  52. GSC S1 cams, Walbro?? Should I buy that??
  53. HELP!!! Car stalling!!!
  54. change filter, AFR?
  55. Boost Conroller? Manual or Electric?
  56. which wideband to use for logging and tuning
  57. Evoscan v2.0 DLL definition?
  58. Oxygen (lambda) sensor help
  59. Acoustic Dynamics
  60. Just got a live demo of Zeitronix DashDaq touch screen datalogger
  61. Big Problem not very happy
  62. Stock Evo IX MR ecu flash?
  63. how do i log wideband 02 with mitsulogger?
  64. Vinshu 400 package
  65. Fuel Injector Plug Pigtail replacement
  66. MAP Sensor Wiring Adaptor
  67. need a little help...
  68. help something is wrong
  69. warning about perrinc ebcs
  70. Zeitronix/boomslang problem. pics inside.
  71. Zeitronix users, quick?
  72. Problem ecu ralliart
  73. extreme power cut falls on face!!!
  74. Lc1
  75. I Need help to tune or re-program my ECU (Evo III JDM)
  76. Local Tuner search
  77. Turbo timer - car shuts off as soon as I turn the key
  78. AMS short block question
  79. 2003-04 EVO 8 HP & Torque after tune
  80. HKS EVC VI question!!
  81. Engine Management
  82. Prosport Gauge Issue
  83. ecu harness evo ix
  84. Best Brand for my Evo VIII
  85. knocking
  86. twin plate exedy clutch
  87. Tuning, do I need it?
  88. Hallman Pro vs. Hallman Pro RX
  89. Do I need a Reflash?
  90. Weekend Tune
  91. Anyone know a datalogger that can support intercooler inlet/outlet temps?
  92. n00b question
  93. where do i plug in my tactrix cable?
  94. 03 evo problems
  95. apexi avcr connections
  96. DDL evo 9 definitions
  97. boost problem
  98. Hi New To This Forum Help
  99. can the ecu lose its reflash somehow and go back to stock form?
  100. Mitsulogger!!
  101. What knock count should make me worry?
  102. Exhaust Minifold
  103. Evo 8 Tune with Selection ??
  104. EVOlink G3 Plugin Engine Management
  105. Maf ?
  106. Getting my car tuned by MINE's? contact info?
  107. ROM read & write error.
  108. Need some help
  109. Can I use JDM Boost Sensor on Zeitronix Display?
  110. random missfire CEL problem on EVO 8...
  111. i need numbers help!!!!!
  112. Whats the best Engine Management System for a 9?
  113. injector question
  114. Which EBC? AEM TruBoost or Greddy Profec B Spec II?
  115. EVO MR help!!!!
  116. EvoScan setup help
  117. EcuFlash v1.35 and v1.29a
  118. Hey Malibu Jack, Help! Losing My Afr's, Mitsulogger
  119. TPS Calibration
  120. Walbro installed today... AFR observations
  121. Tuning in General?!
  122. cant log autometer wb with evoscan?
  123. clutch..maybe
  124. NEED HELP!!! New mods injector probs
  125. Zeitronix boost sensor problem
  126. Innovate XD-16/LC-1 Calibration
  127. LC1 out put voltage question.....
  128. 05 slight modded any opinions on what next
  129. remap and remap for a few $
  130. Going to get tuned by AMS, going on a trip..
  131. IX ECU O2 outputs for Apex turbo timer
  132. wastegate question
  133. What is average EGT's
  134. Major Roadblock! Please help!
  135. When to tune?
  136. Best way to have OBD II back for Emissions
  137. help!!! turboXS
  138. evoscan will not open
  139. custom tunes?
  140. What Is A Speed Density Setup?
  141. help no boost at all????????????????
  142. MAP Sensor Part Number
  143. ebc's and different wga
  144. Connecting LC-1 to analog gauge
  145. TUNE yes or no??
  146. Evo 8 ECU Question.
  147. if im tuned for 93oct and i go out of state can i put 91oct in
  148. Email flashes..
  149. Convert to peak & hold injector driver?
  150. The Cosworth Engine?
  151. evoscan no HP reading
  152. *help* possible fuel cut out in MR
  153. Finalizing map
  154. Questions about log values after installing 65mm TB
  155. please help identify this ecu! CAPS?
  156. Read my plugs
  157. Read my plugs
  158. Tuning Results
  159. dynoflash lacking
  160. Wideband Question...
  161. aem twin fire module 4 channel for evo 9
  162. plug gap from factory at 20?
  163. evoscan cable
  164. When do I really need a tune?
  165. evc 6 ebc tuning help?
  166. Need older version of Evoscan
  167. tuning questions
  168. please post mods and dyno numbers here!
  169. aem help
  170. apexi question
  171. GM IAT sensor temp vs volts scaling?
  172. ignition boot miss
  173. is this stroker kit capable
  174. Need Immobilizer help!!!
  175. Interesting fix....
  176. Total noob to tuning...few questions
  177. Power between winter and summer? (temperature changes)
  178. Base lancer 16g help?
  179. Exhaust Gas Recirc (P0401)
  180. Life in my shoes
  181. General Help With EVO ECU.
  182. Dyno day at P & L
  183. knock caused by something mechanical
  184. Pos Lc-1?
  185. Exhaust and Intake b4 tune can hurt?
  186. hks vpc
  187. Tuning Cosworth Cams w/ GM Boost Solenoid
  188. Evo IX RPM Signal
  189. Could I be maxing out my MAF?
  190. i need
  191. What LC-1 firmware are you using?
  192. P0104
  193. LC-1 and DB gauge wiring problems?
  194. the numbers are in
  195. Pocket Pc Logging software?
  196. help to set up cam gear
  197. utec ecu + or other?????
  198. So torn between EcuFlash and Access Port
  199. Evolution specialists in the San Francisco area
  200. Any tuners in the Colorado area??
  201. Tarmaq Gravel Snow (All 3 lit up)
  202. Evoscan Issue
  203. P0300 code and Tunning?
  204. Noob questions
  205. Moving to Jersey selling stuff Buschur/AMS!!
  206. Air/fuel Problems Cant Go Over 4500 Rpms! Please Help!
  207. Hks Evc 5
  208. cel and miss at idle?
  209. egr flow fault code p0400 or p0040
  210. Cannot analyze CSV logs in EVOSCAN
  211. check engine light
  212. Evo8 street tune in SoCal
  213. idle and tailpipe sniffing AFR
  214. Please don't bash me for asking this...
  215. what is this? what does it do?
  216. Is Tactrix cable compatible with both: XP and Vista?
  217. Tactrix cable problem
  218. Confused
  219. got my 50trim evo 8 tuned!
  220. Iat gauge?
  221. Intake mani question
  222. aem truboost question
  223. AMS TUNE APRIL 11th and 12th BOSTON, MA
  224. problem with boost
  225. EVOScan help
  226. Custom tune on stock ecu, P 300
  227. HELP!!!Turbo XS Tuner Pro Question
  228. HELP!!!!!!! Check Engine Soon light came on!!
  229. Hks Eids
  230. Defi EGT probe slow[er]
  231. afr
  232. WOT ---7.35 always on the wideband ???
  233. SARD Injector Specs?
  234. ??? About datalogging and widebands
  235. Apexi AVC-R Boost Controller Question
  236. help!!!!!tuning
  237. knock sensor wiring
  238. Throttle Hang, RPM Rise, Etc.
  239. fpgreen dyno. low torque?
  240. MoTeC M800 OEM Evo IX start up map
  241. O2 sensor install in LA area
  242. What gap on plugs for more boost and meth?
  243. Question about map sensor and iat installation
  244. $100 wideband o2 setup
  245. HELP! LC-1 guage problem
  246. 05 ECU into 03 Evo VIII shell
  247. question about load?
  248. WTF!? 6hrs on the dyno. no top end!!
  249. got my ecu rom, how to tell if its stock?
  250. WOT Pause?
