View Full Version : General Engine Management / Tuning Forum
Pages : 1 [2] 3 4 5 6 7 8 9 10
  1. ECU/GM 3-port boost question
  2. Injector Battery Comp (usec) 1200cc
  3. MAFT install question
  4. Has the ECU been effed with?
  5. Wideband vs narrow band
  6. Ems??
  7. Cam gear adjustment??
  8. What is this?
  9. where can i get the aem ems the cheapest!!!
  10. Need help tuning!!!!!!
  11. battery being drained
  12. 03 ECU in late 04?
  13. How normal is this!!! LEAN..
  14. odb socket
  15. help choosing the right injectors!
  16. Tuning in AZ
  17. New Injectors and Fuel pump advice
  18. Load % problems on a 2g with Evo 8 ecu swap...
  19. AFR Map Logging Issues
  20. UEGO WB02 Sensor in place of the front narrow band 02 sensor
  21. Need help with Datalogging
  22. need help w/evoscan 2.5 com1 issue
  23. EBC Help
  24. Injector help need
  25. AEM WB02 vs ProSport WB02 - Logging question
  26. Climate Control Electrical Help! Please!
  27. need help?
  28. Rear O2 Sensor CEL Question
  29. Changing roms
  30. A Question about rebuilding Engine
  31. Get an HKS Suction Pipe to Idle at 38Hz ? ?
  32. Exh Cam Timing on Mivec Evo IX
  33. tactrix problem
  34. LM2 to Evo OBD Connection - Help
  35. queston about tuning
  36. Question on my tunning has this happend to u!
  37. Fuel Pump
  38. Brand new gsc s1 cams
  39. Cel p0202
  40. where did you mount your standalone?
  41. Why is it mbc>ebc
  42. Open source tuning?
  43. boost control ?
  44. I need to hold more boost up top
  45. Timing Question
  46. quick question
  47. plx or LC-1?
  48. EVOScan question
  49. Question : EVC 6
  50. Cat install after tune
  51. Killing Timing Belts
  52. data logger
  53. car dies when headlights are turned on?
  54. HKS F-Con
  55. Noob question: AFR gauge range?
  56. timing maps
  57. turbo timer install help needed
  58. o2 senor?
  59. innovate lc1 help
  60. not sure if im running into a problem or not...
  61. Look what UPS just brught..V-PRO 3.3
  62. emissions machine not reading my ECU???
  63. need hlp asap
  64. Mut Monitor V1.9 Release 31/1/2009
  65. .....Threw a Rod,.......
  66. Evoscan question
  67. Error: No response from vehicle ECU
  68. Open air filter shuddering on boost.
  69. evo 9 JDM map sensor vs evo X USDM map sensor
  70. DYNOFLASH and ICS Experience
  71. Tuning a Red with cams....injectors?
  72. Tuning a stock evo
  73. Help quick question b4 i order
  74. Stuff for tuning
  75. Anybody installed big injectors???
  76. help me
  77. For ALL you AEM A/F Ratio Guage(rs)
  78. DLL Definition for Evoscan 2.5
  79. Clutch HELP!!!
  80. Damn ECU is "LOCKED"
  81. Helppp!!!
  82. tuning with macbook
  83. apexi avcr 4 bar sensor.
  84. Mut Monitor V1.3 Release 10/1/2009
  85. racegas + meth??
  86. Car is knocking
  87. Evoscan 2.5 Link??
  88. higher boost
  89. Engine Cranks but wont fire
  90. Mivec Head on Evo 8 block??
  91. Temporary wideband O2 sensor installation for tuning
  92. check engine light on
  93. Octane Testing
  94. dual stage boost controller and tune?
  95. something rubbing up front??? help
  96. something rubbing up front??? help
  97. Do I need a Engine Management System?
  98. Evoscan problem
  99. Upgrading to IX turbo tomorrow!
  100. some advice on tuning
  101. Boost level's and high octane
  102. ICS Steps Evoscan
  103. from crappy socal 91 to North Carolina 93.
  104. logs from 2 different tunes, feedback please
  105. Evo Scan not working...
  106. EVO6 Bench ECU
  107. Evo 8 Detonating / Sputtering horribly Please Help!!!
  108. EVO Guru's help....!!
  109. evoscan question
  110. water temp reading incorrect
  111. 500+whp on stock 2 liters??
  112. Installing an evo 8 usdm d jethro in an evo 7 JDM
  113. evo IX 16g is an FP red?
  114. kelford 272's and stock valve springs?
  115. Spark Plug Torque Down
  116. Need some help using ecuflash
  117. please help need older version evoscan
  118. Newb question
  119. EVOscan: playback problem
  120. problems with car and occaisional p0303 code.
  121. Unstable idle, car almost stalling at low speeds, need help
  122. Getting rid of MAF on stock ecu?
  123. TBE gains with and w/out catalytic converter
  124. o2 housing question
  125. Help with LC-1 and evoscan
  126. ECMlink vs ECUflash
  127. Ecu Pinout.. Can anyone help? JDM evo8 -7 -6
  128. rpm raise neeed help!!!!!!
  129. Where t o download the EvoScan?
  130. Greddy Informeter Touch and Boost
  131. question about cams
  132. The Next BEST upgrade? HELP
  133. P0303 Misfire!!!
  134. What is the gain set to on your EBC?
  135. Precision 780s
  136. Tuner Options In Socal
  137. Do these trouble codes mean anything?
  138. backfire/hesitation under acceleration
  139. How to read ECU error codes with EVOSCAN ?
  140. Logging with alternate Wideband O2
  141. tuning question
  142. need some opinions
  143. EvoScan problem
  144. Free flow cat vs testpipe
  145. Innovate lc1 sensor replacement
  146. EFI 101 Class
  147. Which Tuner to go with?
  148. freeze plug
  149. what computer do you use to tune?
  150. quick EvoSan and Tactrix Question
  151. ECU Options
  152. Noob questiosn - coming right up ^^
  153. Dtc P0234 On Sacf2 And Avcr??
  154. Stock Head
  155. 2g Dsm Ecu + Dsm Link
  156. Dyno numbers 313.2 whp on Dynodynamics, Dyno4mance tuned (Thanks Bruce and Andrew)
  157. 4wd traction control
  158. Exhaust gases smell a lot fuel!!! Could be a problem?
  159. Injectors
  160. Nashville Shi Pal Tennessee Evo Mechanic
  161. Nashville ****en Tennessee Evo Mechanic
  162. evo 8 ecu on evo 7
  163. new dyno update! 340whp! =)
  164. anyone using Vi-PEC
  165. need a good evo mechanic in nashville tn please help!
  166. Anyone running Haltech on evo IX?
  167. lc-1 reading 15.1 problem
  168. gauge choice
  169. dc sports exhaust and wideband
  170. Anyone ever use LS1 coil packs.
  171. Best Stand Alone for E85???
  172. do you think we could
  173. stupid question....
  174. Tuning gear?
  175. Really need help, greatly appreciated!
  176. two sets injectors
  177. I just purchased the BR filter kit and...
  178. Hks F-Con vPro
  179. Best laptop for factory ecu
  180. Evo patch harness
  181. How much timing and boost are you running?
  182. new to tuning
  183. I found this ECU upgrade
  184. Oem Ecu Trouble
  185. Total MR swap
  186. Tuning questions
  187. Turbo XS DTEC, where do I start?
  188. non-tune mods
  189. Mvec control
  190. AMS Custom Tune?
  191. Evoscan & Data log lab logging questions
  192. AEM EMS or Stock ecu
  193. repin maf plug
  194. Will I need a wideband for my planned setup?
  195. AEM Tru boost question
  196. Thanks to Andrew & Bruce @ Dyno4mance
  197. Evoscan logging issue with frozen fuel trims..
  198. next mod
  199. Pic of the idle bleeder screw
  200. evoscan not initializing
  201. innacurate wideband readings in evoscan 2.4
  202. Water temp on Evoscan
  203. Pectel E2 Engine control for Evo
  204. 4th gear pull WOT timing advance
  205. tactrix cable question
  206. Openport 1.3 cable w/out datalogging??
  207. Which ECU?
  208. (Trinababe) Looking for the software (CD) for the greddy blue emanage
  209. How to tell if my engine is running too lean or too rich??
  210. need to upgrade injectors for evo9-20g+cams?
  211. tuning in nj?
  212. 2003 evo 8 rom
  213. Stock Injectors
  214. looking for a tuner in colorado springs
  215. tatrix cable
  216. Jestr coming to Miami??
  217. zeitronix data logging problem?
  218. Mitsulogger version
  219. Tractrix 2.0 cable does NOT work with EVOSCAN!!!
  220. Walbro 255 fp install/ wideband install..lean idle afr!
  221. largest injectors on stock ECU??
  222. Anyone running MoTeC?
  223. Does Tuning Affect Reliability
  224. boost drop problem please help
  225. Evoscan problems, need help
  226. NGK Wire set for VIII
  227. injector scaling
  228. Tactrix Cable blown component
  229. LC-1 Calibration
  230. loosing power plzz plzz help
  231. basic bolt on sean ivey tune
  232. Motec M800 maps!!
  233. Any Tuners for EVOs in the San Bernardino County?
  234. Evo 6.5 TME
  235. How to quick tune ?
  236. Ecu Link G3 Tune
  237. quick boost question
  238. C16 Race Map Help.
  239. Low End Power Modz??
  240. what i need?
  241. anyone used the innovate lm2 yet?
  242. tune for nitrious?
  243. tuning for air/fuel
  244. What else besides a GM MAF
  245. Was going to pull my motor but . . .
  246. Hallman MBC, NOOB needs help
  247. p0243 help??
  248. Aem Wb
  249. TPS voltage
  250. Tuning the RED.. Where to stop cranking the boost?
