- Will go with 280's/Bushur21G/Alchohol inj!
- experiance of ecutek?
- I guess this would be the right area for my ??'s
- 272's with Alky, or 280's with RS turbo? Help!
- next mod recs? where to find hotside?
- Anyone running Ecutek yet?
- Stock 02 Sensor Help!?
- Need Help!!!!
- whats the best piggyback and turbo back combo?
- engine light/o2 sensor
- Apexi Boost Controller Settings?
- aftermarket comp/obd/piggyback
- How do you feel about the Apexi BOOST CONTROLLER
- Turbo Trix vs Dynoflash >,<
- Please look at log for EGT and WB o2s
- Topspeed In Alpharetta!!!!! Great
- Hks V-pro
- NEW APS 3.5" turbo back exhaust Q's NEED HELP ASAP!!!
- Can 04 Ecu be reflashed for 05 evo?
- AEM power packages
- ECU+ forum - Yes or no
- Newbie in need of help and advice with turbo kits
- No Lift To Shift - Ecu Hunt
- Boost gauge
- EGT Temps??
- need immediate help! can't get LM-1 to datalog rpm...
- Do any vendors offer a 280 flash?
- Best tuner in florida
- ECU tuning after Perrin Intake?
- anybody know what this is??
- MicroTEC
- Blitz SBC i-D (Sequential Boost Controller i-D)
- Whats the difference between these to?
- Blitz R-Fit
- Ecu+?????
- What are these ECU upgrades???
- weather compensation?
- New to logging please help
- Which Inputs Would you guys prefer?
- look at this log, ok?
- the best for my wants
- Which Motec for EVO VIII ?
- Will maps work on new car??
- Tuning and engine management 101.
- FIC Injectors Question...
- Finally solved the WOT "burp" hesitation prob!
- does this happen to you
- help for a beginner...
- AMS Water Injection
- small help please
- How to maximize power with Apexi AVC-R
- AMS Turbo article .
- Anyone running derekdevises meth inj on their evo?
- this is a dumb one
- quick question
- Need Help !! ??
- Stock ECU Location ?
- Evo 3 Ecu...
- PDA Scan Tool/ Data logging Ques
- AFC or GM mafs
- what hp/tq should i expect w/mods
- how to avoid detonation during the tuning process??
- Dont change the Fuel you were Dynoed on!
- ?Turbo upgrade and engine management?
- Evo fuel question
- DYNO 05' GSR w/ apexi catback, boost controller, and AFC. is it worth it?
- Zeitronix Questions
- quick. best size spark plug wires for 4g63?
- Turbo Guide
- Race Gas Versus Alky GT30
- Exhaust Heat Shield
- What system should I go with ??
- Dynoflash clarification needed
- XEDE? Flash? Reflash? Confused Help.
- Knockbox equivalent for EVOs?
- What software are the ECU flashers using?
- What are the EVO VIII stock AFRs?
- stock '05 on Mustang dyno...anyone?
- Evo boost Taper
- HKS Carbon-Ti Exhaust and downpipe wanted
- Ppl In Ky,tn,va,nc Willing To Travel To Get Their Ecu Flashed
- help
- For those using the HKS TT type 1
- Zeitronix Wideband 02
- THe BEST ECUs out there.
- When should you buy ARP Head studs?
- chart for VTA correction on a/f management
- ECU + Is anyone using this ??
- need help with BOV Whistling. and boost flux
- What are some of the top evo tuning companies?
- Which is the best Xede,Utec etc ?
- which VP racing fuel? O2 sensor probs?
- HKS computer ?
- Question on tuning...after being flashed.
- boost leak need help
- Zeitronix LCD install location?
- hks 272 vs. 280 camshafts, which one is better?
- PLX or LM1
- Can someone explain Engine Management stuff
- F-Con SZ and UniChip
- ultra speedmeter No.4000
- question setting turbosmart BOV???
- car acting up
- Microtech LTX8S EMS
