View Full Version : Apex-i S-AFC / S-AFC II
Pages : [1] 2
  1. AFC neo question.
  2. Boost monitor not working
  3. AVCR Help
  4. Is there a solution/workaround to the Apexi AVC-R Settings-Bug?
  5. Where's all the info gone.......
  6. Apexi AFC NEO & HKS EV VI, Will these work together?
  7. Questions about APEXi AFC Neo
  8. SAFC bad for the EVO?
  9. Safc for tuning
  10. Boomslang harness compatibility?
  11. Evo IX SAFC II Diagram
  12. Boost Problems
  13. Do i Need Reflash for Apexi..!!
  14. Safc
  15. I need a tip please
  16. Apex'i NEO & Aquamist HFS-5
  17. how much can i lean out on c 16
  18. Please Help Me Out Asap
  19. FS:apexi Safc/avcr
  20. wtt: my tuned safc for your stock ecu
  21. apexi S-AFC NEO for sale with harness
  22. Bashing? And good setup?
  23. Why are you using the S-AFC?
  24. s-afc neo setup
  25. Safc-II to keep or not to?
  26. safc2 questions
  27. FS: Apexi Safc2 Special Edition Black W/ evo8 harness
  28. SAFC2: Knock during deceleration/idling
  29. Safe way to lean out w/ AFC?
  30. Please help
  31. Please help
  32. s-afc??? help
  33. Super ITC
  34. s-afc removal???
  35. install safc car not starting???
  36. Stupid Question
  37. ill effects removing SAFC?
  38. safc neo karman signal problem!
  39. SAFC 11 neo
  40. how much power are you making with an afc
  41. SAFC II question before purchase...
  42. S-AFC II diagram to a EVO IX
  43. Question about reflash and AFCII
  44. safc2
  45. anything else needed?
  46. VIII and IX harness
  47. Knock?
  48. SAFC install question
  49. Will my Safc mess up my flash?
  50. wbO2 vs nbO2 difference in tuning
  51. apexi AVC-R
  52. Apexi AVC-R on an Evo IX
  53. Fastest time with afc
  54. SAFC2 tuning question
  55. please help me tune my safc2
  56. what gain does SAFC tune make vs. stock?
  57. SAFC-II readout after turing car off.
  58. throttle point setting
  59. power off function on SAFC-II?
  60. New Owner needs help!!! SAFC/ECU
  61. Should I keep the SAFC-II
  62. Evo 8 (stock) worth an SAFC-II?
  63. SAFC II pin layout....
  64. safc2 install on EVO IX
  65. installed AFC2 and problem occured
  66. S-AFC II vs. S-AFC Neo
  67. 05 Evo MR + SAFC trouble
  68. injectors without fuel computer?
  69. when logging 02 do you use bank 1 or 2
  70. S-AFC II is it enough
  71. Lambda?
  72. does boost affect timing advance?
  73. my boost spikes at 1.4 and drops to about 1. or so
  74. SAFC@ with aem uego
  75. Pulling fuel on stock turbo with 680's
  76. safc neo
  77. Suggestions?
  78. Help to tune SAFC and SAFC 2 for my EVO 7
  79. SAFC 2 and SC Power mount
  80. Who here has the produced the most whp w/an "SAFC II"?
  81. intercooler tune?
  82. SAFC display
  83. gains
  84. Fs Safc Ii
  85. datalogging wideband signal with pocket logger
  86. setting plz?
  87. RPM readings dont match
  88. Help tunning after intake
  89. Omit???
  90. SAFC2 for a idle on a sti
  91. CEL P0102, Any one had it?
  92. My thoughts!
  93. Tuning a IX with SAFC-I/II
  94. Knock
  95. SC-Power SAFC holder
  96. SAFCII, Profec E-01
  97. safc II display problem?
  98. can the safc2 control the fuel rich or not?
  99. Stage 4 buschur safc 2 settings.
  100. AFC2 w/ MAP Mod using AEM 3.5bar sensor
  101. Petition for Boomslang to make SAFC-2 Plug and Play Harness for IX
  102. Petition to make SAFC-2 Plug and Play Harness for IX
  103. timing?
  104. what do you use for a logger
  105. where to buy afc II evo harness
  106. SAFC help on '03 stalling problem
  107. leaning out
  108. knock reading, how high?
  109. Max HZ numbers???
  110. how much did you tune change in the winter?
  111. understandin Lo/Hi Throttle points...
  112. knock values, are they legit??
  113. apexi safc 2 BLUE for sale
  114. RPM's on an AFC-II
  115. General questions about beginning to tune
  116. s-afc screen not working???? help!
  117. Evo3 SAFC2 Fitting Help Needed!
  118. injector gas withdraw w/afc
  119. S-AFC 1 install help
  120. Temp dropped now my knock reading is HIGH!
  121. 05 MR at 21psi, 94octane
  122. Knock reading
  123. stock safc 2
  124. SAFC-II Red!!!
  125. S-AFC II on top of Tune???
  126. Installation of S-AFC-II
  127. SafcII...want to boost higher. do i need bigger injectors
  128. 05MR w/exhaust and MBC set at 20psi
  129. where did u put ur afc
  130. What color is it?
  131. safc2 and 680's on a 50trim
  132. With afc installed will your stock ecu still change any settings
  133. tuning safc for race gas?
  134. What exactly does a safco do??
  135. Safc II black for sale
  136. Safc question pls help
  137. How to hook up Safc
  138. s afc settings gone after car is off- anyone experience before?
  139. biggest injectors to use w/afc
  140. stock datalogs
  141. datalog results
  142. Need help ASAP w/ SAFC II
  143. good deal on harness
  144. only one problem please help
  145. initial setup for an used safc2
  146. WTB- Apex AFC 2 w/harness
  147. palmnstein or pocket logger software?
  148. Brand New AFC !! FOR SALE!!!!
  149. AVC-R problems !
  150. SAFC 2 w/Harness For Sale
  151. Which Safc Ii Harness?
  152. afc II password reset???
  153. help with safc install
  154. Mitsubishi Evo Hks Carbon Exhaust
  155. Black Face S-AFC II For Sale!
  156. flash and lg injectors..
  157. SAFC2 fpr sale CHEAP
  158. can't get my pocketlogger to work.
  159. ecu
  160. tuning with SAFC
  161. Reflash and S afc
  162. Question regarding S-AFC
  163. Trade S-AFC1 FOR S-AFC2 BLACK
  164. guys save your car and read this if your new to the afc
  165. Meth & SAFC
  166. SAFC-II 2500-3500RPM Problem
  167. Adjustment after adding Fuel Pump
  168. BOV need a Retune?
  169. rpm does not match
  170. safc2 solution for EIDS
  171. Datalogger for MacOSX?
  172. S-AFC 2 monitor readings
  173. Just A Little Bigger Turbo?
  174. My First time tuning my car
  175. a little help with my timing
  176. Turning with the Wideband
  177. Safc I or II
  178. Passing Emissions with S-AFC
  179. Anyone mess with the low throttle fuel settings?
  180. newbzie question-
  181. Pocketlogger results
  182. safc II WITHOUT upgraded fuel pump or injectors
  183. Alcohol injection & SAFCII
  184. Initial SAFC2 Settings
  185. SAFC with flash??
  186. SAFC Tuning with Logger
  187. Fuel Cut?
  188. S-AFC II Question
  189. Is low throttle supposed to fluctuate?
  190. can you read knk with s-afcII?
  191. Apexi SAFC II for sale!!! $150
  192. dynoflash
  193. low throttle setting
  194. Quick Question... please help!~
  195. SAFC Reading RPMS Incorrectly
  196. n00b safc question
  197. how come the AFC killed my idle
  198. Timing
  199. Splicing Fields Harness?
  200. point me in the right direction for a logger
  201. S-AFC II settings?
  202. quick question
  203. Max Karman readings?
  204. low throttle timing
  205. afc settings w/ flash & race gas
  206. S-afc
  207. reading AFR with LM-1
  208. Splicing turbo timer onto Fields Harness
  209. HI/LOW% part throttle transition for auto-x
  210. Karman Frequency
  211. question???need answer or opinion
  212. self learning throttle?
  213. 05 GSR safc settings
  214. Looking for gas mileage....
  215. Buschur AFC II and non-Buschur TBE
  216. Stock MR w/S-AFC Logs
  217. S-afc Ii
  218. Old safc install, not safcII
  219. Safc II Wiring Problems with Apexi boost controller
  220. ..solder connections, poor idle
  221. 264/264 cams, stock ecu, and tuning
  222. ??? on the peak feature of S-AFC II
  223. Biggest Injectors with SAFCII
  224. jumpy feeling
  225. cam gears
  226. Tuning in an intake...
  227. Settings
  228. Flash vs SAFC
  229. SAFCII knock reading
  230. 325 code (knock sensor)
  231. how much awhp do you get with safc on stock engine and basic mods
  232. HELP!! S-AFCII & Check Engine Light
  233. safc ii setup question
  234. cheap fields harness
  235. S-AFC Troubleshooting
  236. safc harness
  237. jumpy pully pushy feeling???
  238. check ou these logs too rich still? stock injectors stock pump ? all on 1.4-1.3 bar
  239. safc default password?
  240. knocking on safc over 100 at wot?
  241. S-AFC II install wiring trouble..... HELP PLEASE.
  242. what is your throttle setting at?
  243. F/S: A'PEXi S-AFC I --- $150 shipped
  244. wiring - solder or male/female clip?
  245. SAFC install with Harness help?
  246. most power on safcII
  247. Help With Afc Ii
  248. S-AFC 2 help
  249. S-AFC II - how to splice wire
  250. who's got the how to install SAFC?
