View Full Version : Apex-i S-AFC / S-AFC II
Pages : 1 [2]
  1. How does your car run with an SAFC?
  2. safc settings
  3. S-AFC II someone have a .pdf of the user manual?
  4. f/s SafcII
  5. F\S: SAFC II $200 shipped
  6. Fuel Cut fix question?
  7. SAFC2 info
  8. wideband and s-afc 2
  9. PLEASE help
  10. Which road should I embark?
  11. Dyno Results: post yours!
  12. super afc2
  13. For sale, afcII
  14. Decel air settings
  15. For Sale: SAFCII with harness
  16. safc how to?
  17. safc2 extension harness
  18. help with installing apexi T timer
  19. 325whp / 315trq on DynoJet w/ AFC?
  20. 720's to 780cc injectors?
  21. You can make decent power on an SAFC2
  22. stock settings, stock car
  23. FS SafcI w/ buschur settings
  24. should I get AFC II?
  25. seeing state ref, hide safc?
  26. Cheap New Safc-II
  27. not too sure about s-afc2
  28. FS SAFC II Cheap
  29. throttle response
  30. super afc2 help
  31. Does the SAFC-II work?
  32. Have a quick question on SAFC II harness
  33. tuned with safcII
  34. 650cc injector fuel settings
  35. Good base settings. (stage 1)
  36. a real newbie help!!!
  37. i need a super afc2 book
  38. Wried Problem
  39. ECUFlash enough for bigger injectors?
  40. Rev wire on ecu which one?
  41. Do I need a S-AFC 2 if I get a ECU reflash?
  42. SAFCII from Talon
  43. SAFC I or SAFC II
  44. Need Help Asap
  45. IN-1 sensor check voltage???
  46. Anyone need an SAFC with harness?
  47. Just bought a afc and i dont know how it works
  48. safc2 wiring for europe version evo8??
  49. need help on gettin my afc2 wired up and workin
  50. weather question
  51. po234 fuel cut?
  52. Mounting Solutions S-AFC
  53. Mounting Solutions S-AFC
  54. Is there any reason to have an AFC if I'm flashed?
  55. calling all s-afcII need help please
  56. Trouble With Safc2
  57. SAFC settings on 91 octane
  58. AVCR installation help
  59. Trouble getting consistent A/F ratios
  60. What Gauges are necessary?
  61. Super Afcii Wiring?
  62. Afc or Afc2
  63. theres a lil x next to my knock meter.
  64. Need a Afc n harness new/used
  65. S-AFC2 Install w/o guage package
  66. Newbie:Help w/ AFC II. Installation with harness!!
  67. AVC-R Install and settings
  68. Couple ?s about afc can some1 help me
  69. Data Logging
  70. buschur stage 2 s-afcII settings?
  71. Stock E.C.U. ?
  72. wiring question
  73. Karman readings
  74. Larger Injectors effect on IGN timing
  75. Knock reading? Reliable?
  76. s-afc harness for evo
  77. CN-4 Field Harness and SAFC-II
  78. Base SAFC II settings?
  79. S-AFCII + BOV question
  80. Throttle reading on my SAFC2
  81. I'm on the SAFC2 Fence...
  82. SAFC II Question
  83. Any thing different about installing SAFCII on an 04 Evo?
  84. SAFC II default settings for EVO VIII...
  85. Harness - which side is ecu side?
  86. S-AFC newbie help
  87. SAFCII knock reading?
  88. afc fix k&n typhoon prob?
  89. SAFC II vs. HKS AFR
  90. airflow#'s in hz
  91. SAFC2 Quick question about throttle
  92. Another good reason to get an AFC
  93. Service engine soon light
  94. Good AFC info from malibujack
  95. The Right Pin out for AFC is here
  96. safc2
  97. SAFC II not showing correction
  98. Comparision of S-AFC II to XEDE
  99. Finally hooked my SafCII Up. OMG
  100. ApexI SAFC POLL - Please Respond
