View Full Version : Evo How To Requests / Questions / Tips
Pages : 1 2 3 4 5 6 7 [8] 9 10 11
  1. DIY exterior/interior fabrication questions
  2. Blacked out Tail lights..
  3. Sparco Harness bar Question
  4. Buschur racing MBC pics please...
  5. EVO Fuel pump install?
  6. Need help on carbon hood?
  7. greddy type s BOV for 05 evo
  8. Rear bumper removal?
  9. What did I remove? PICS included HELP!
  10. Install tools
  11. o2 housing problems
  12. splicing / electrical question..
  13. More on Valentine 1 hardwire....
  14. Need Help With Install
  15. HKS Exhaust ti question
  16. Those with Joe P. MBC...help
  17. Apexi TT question
  18. how much it cost.....???
  19. NEED HELP!!! Front LIC Plate Bracket Install
  20. HELP! How do I adjust the hood latch? My new CF hood is loose...
  21. Stero install, HELP!!!
  22. jdm mr headlights problem
  23. Buschur O2 install (alternative method) qith pics
  24. O2 housing
  25. REQUEST: DEFI-D Air/Fuel Gauge Installation
  26. Front sway bar , Removing .
  27. Bulb guide for headlight modders: helpful links
  28. Defi oil pressure gauge..do I need anything else?
  29. 02 Sensor Problems
  30. $2500 to spend what to do next
  31. Turbo XS Exhaust Question !!?
  32. alarm/ turbo timer diagram(been away from the forums)
  33. Boost Guage Question
  34. Hks Eids Wiring
  35. Idle Question
  36. HKS Circle Earth Grounding kit for Evo - need help
  37. what did your walbro fuel pump come with, exactly?
  38. exhaust hanging
  39. CF Rear bumper Guard
  40. cabin filter size ?
  41. How to remove / replace your spark plugs
  42. Lower damper removal
  43. Carbon Fiber Engine Shroud
  44. set up boost control
  45. Part # Question
  46. Fog lights on with just parking lights?!?
  47. Greddy Type S VTA BOV problems
  48. advan tires weight?
  49. o2 sim install ??
  50. done modding, need help with the tune
  51. How To: Change your Brake lines
  52. Req: Brake Disc, Brake Pads, SS Line Install Howto
  53. Need pictures of ecu wiring with color wires/diagram
  54. Help with Greddy Turbo Timers
  55. Question on Sparco 4-pt Harness Install
  56. radiator install write up wanted
  57. How to Greddy Type-S Single Spring Mod
  58. Helix IC Pipe kit Install
  59. quick help!!!
  60. Brake pad tutorial
  61. intake intall
  62. How to install a Three Speed Scatter Shield
  63. How to: install injectors!
  64. Head unit wiring question
  65. Clutch disk thickness?
  66. Sparco 4 point harness install
  67. Need your clutch changed - contact me
  68. Apexi TT and HKS harness
  69. SS clutch line/restrictor pill?
  70. How do you remove steering wheel column cover?
  71. Request: How to install the passport zr3 laser jammer
  72. walbro 255 fuel pump install
  73. Evo spoiler
  74. Help my lights went out !
  75. just installed a K&N drop in filter
  76. HKS Type 1 install question.
  77. Another radio relocation kit question
  78. Installation of 10.5 hotside
  79. MR stereo wiring
  80. Knock Link Install Instructions
  81. greddy ful auto timer instructions
  82. How to install the spark plug anti-foulers to remove the ses or cel light
  83. Somewhat of an HKS RS intake installation
  84. how do you get rid of the rattling in the b-pillar?
  85. Air/Fuel Gauge Problems
  86. How to Install Hallman EVo RX PRO
  87. AutoMeter Triple-pod A-Pillar question(s)
  88. avic n1 into my 2003 lancer evo
  89. how do i remove driver side mirror?
  90. Clutch disable??
  91. Part number ...from Evo MR
  92. Draining intercooler spray reservoir?
  93. How to build an FQ-320?
  94. BLITZ FAT DCII installation wiring diagram
  95. restrictor pills???
  96. Ipod intergration with factory headunit?
  97. will this short shifter fit my car
  98. Anyone Replaced an Axle seal yet on their EVO?
  99. hallman mbc question
  100. spark plugs
  101. where is the ecu on evo ????
  102. hot to se Hallman MBC! please help!!!
  103. Installation of Blow off Valve
  104. removing stock header.. question
  105. MR Vortex Generator - Installed
  106. how to avoid frustration installing Blitz DTT
  107. remove stock air box
  108. painting my engine block's valve cover
  109. Need help to install Water Tempature Gauge sender
  110. How to Make Your Factory Console Gauges RED
  111. need help!!!short shifter kit
  112. Defi Link unit install question
  113. Add Foglight to RS?
  114. Anyone know how to adjust the clutch peddle??
  115. radio faceplate console thing..
  116. clutch line bleed - confused
  117. How to paint the stock enkies?
  118. Fuel Pressure Sensor Install
  119. Tein Flex coilover install (ProStreetOnline.com)
  120. Blitz Fatt Turbo Timer
  121. Evo Factory Subwoofer
  122. HKS Timer Type 0 – RPM Connection
  123. some make write up on sidemarkers
  124. how to remove storage bin below HVAC??
  125. MR Headlight installation
  126. Install how to on Sports Meter Kit
  127. exhaust question
  128. apexi TT
  129. Where does the intercooler sprayer hose plug into?
  130. Lower Intercooler Pipe install
  131. Factory Gauge Package
  132. Need O2 sensor housing!!
  133. HKS SSQV problem!!!!!........spring not the right one for evo 8?
  134. Anybody put a remote start on a manual
  135. ARC heatshield install?
  136. Disable A/C on with Defrost?
  137. Avic - N1 color changes
  138. "How To" Intall HKS SSQV Blow Off Valve!
  139. different oil pressure sender info...
  140. Disable '05 EVO 5000 RPM launch limit
  141. HELP!!!! need info on how to tune HKS SSQV properly
  142. "How To" Intall Nology Hotwire In 17 Easy Steps!!
  143. Electronic Boost Controller
  144. Rear O2 sensor ???
  145. Spark Plug question...!
  146. Momo steering wheel Help
  147. AEM Digital Ignition Module
  148. Oil Pressure and Temp Gauge Install
  149. Mitsubishi brake air guide install
  150. Kartboy Shift Linkage Bushing Install
  151. How to tell, boost leak
  152. Clear Bra Paint Protection film Install
  153. Where are the underhood bushings located.
  154. AC temperature extremely hard to turn.
  155. how to take off the side mirrosr?
  156. cf wing on cf trunk
  157. Installing aftermaket intake, is it necessary to get an S-AFC for tuning?
  158. Momo Tuning Pedals
  159. Purchased a 05' Evo MR, Seeking Advice for Upgrades, tryed and true!
  160. Black Out Headlight Materials
  161. Urgent: How to remove hood windshield sprayer?
  162. How do you set up the Hks Evc V
  163. ?setting greddy profec bII bc help???
  164. Reading 16 psi on autometer boost guage
  165. Installing front sensors for laser jammer sensors???
  166. How To Install A Blitz SUS Power Intake..?!?!
  167. Painting Springs Question?
  168. Remove the back seats... ???
  169. Using a Fuel Pressure Regulator for Injectors and Pump??
  170. Seat Help.................please
  171. Help with Defi link install
  172. hose sleeving kti help
  173. question about my BR exhaust
  174. If you have an Autometer EGT... please read (or any egt with a long probe)
  175. NOS, BOV, Catback Question?
  176. Idea for Gauges
  177. How to Swap Radio with Gauge Panel
  178. How to make your wing all-CF
  179. Make A How-To on the FULL Carbon Wing!
  180. Problem with EGT install
  181. Apexi Timer
  182. Bushur FMIC install
  183. Trany thowr out bearing help
  184. 02 Housing install
  185. First MR owner with a stupid question
  186. How-To: T-Sport Rev-Lite shift light install
  187. Shifter Base Bushing Install
  188. IC Sprayer Reconnect?
  189. which gauge is more reliable?
  190. HKS Cam Gears adjustment
  191. How do you remove the A-Pillar?
  192. Help-Torque Specs For Downpipe Spring Bolts
  193. HKS TT Type 1 problems
  194. Keyless Remote Programming
  195. EGT Gauge Question
  196. Cold Air Intake Pipe Install & Intercooler Tank Relocation
  197. Cold Air Intake Pipe Install & Intercooler Tank Relocation
  198. A good cat??
  199. Intake Pics??
  200. Help installing Autometer boost on Evo 5
  201. Removing cd player
  202. Sport Meter Kit relocation?
  203. Serpentine Belt removal and installation
  204. EGT Sensor install question
  205. Trouble with heater controls?
  206. Rear Bumper Removal
  207. Question about installing the Buschur Mass Air Pipe..
  208. Instrument Cluster Problem
  209. Nifty brake cooling ducts
  210. AEM UEGO install w/EMS...suggestions..
  211. Fuel injector Install
  212. shift light help
  213. has anyone painted their tail lenses red from the INside?
  214. OEM Evo Fluids and Redline too!
  215. Evo headlight blackout
  216. Need Help ! Stock Recaro Bracket?
  217. How-to: AEM CDI Install (pics)
  218. removeing one or two mufflers
  219. Fuel pump install question? Please respond ASAP!
  220. Tip: Stop the beeping alert to fasten seatbelt
  221. Defi Oil pressure and EGT gauge help needed
  222. Help! I need to know how to remove door panel?
  223. greddy turbo timer questions?
  224. DIY Better adjustable stock BOV!! Free mod!
  225. Very fast click click click sound after Boost Gauge Install
  226. Self maintenance
  227. Install a pass-through for the rear seats on Evo VIII?
  228. Squeaky sound.
  229. Gear Oil Pump?
  230. EGT Probe and Water Temp Wiring
  231. To those with helix down pipe..
  232. Bolsen's Guage cluster light mod ROCKS!
  233. Dual Bypass Oil Filter install on an Evo
  234. How to install an AFC II with the harness!!!
  235. Hole in firewall?
  236. Evo stalling after tune up...why?
  237. I need HELP! MY Greddy boost guage is reading crazy boost
  238. apexi turbo timer help
  239. Tail Light Mod - WEBCAST
  240. Is There A Way You Can Take Apart The Tail Lights Without A Heat Gun???
  241. Cusco Oil Catch Can Install Pics (With Buschur Intake)
  242. How to install a small shift light into your HVAC vent
  243. new Evo oil change question
  244. Mechanical o2 Fix
  245. steering wheel not centered is it the alignment ?
  246. What COLOR is the speed sensor wire in the ECU?
  247. SAFC2 dimensions (will it fit in lower panel)?
  248. Autometer ultralite boost guage?
  249. free DIY better flowing stock exhaust.
  250. Easy & Cheap Foglamp Bulb Upgrade
