View Full Version : Evo How To Requests / Questions / Tips
Pages : 1 2 3 4 5 6 [7] 8 9 10 11
  1. Dealer ship sticker removal
  2. alpine cda-7893
  3. INstalling Wet N2O
  4. Installing Ralliart Accent Plate
  5. Problem on my carbonfiber hood~~~
  6. APR Canards installation help??
  7. Compression Test How-To
  8. Fuel Line for Wet N2O
  9. Problem with installing HID Fog Lights
  10. What is the diameter of evo's radiator hose?
  11. here is how i installed my NX kit.....
  12. Will Someone Please Let Me Know If I Should Tune My New Gears!!
  13. Greddy Upper IC pipe question
  14. Duty Cycle for Boost Controller ??
  15. HKS SSQV Version 2 question
  16. Clutch Restrictor Pill Removal (without disconnecting clutch "hardline"???
  17. how to remove turbo
  18. Torque specs and part #'s please.
  19. Helix IC pipe question
  20. looking for amp installation guide
  21. Defi link II
  22. New Stereo with Premium Sound
  23. HKS timer use
  24. Bolts sizes *help*
  25. Forge Evo Adj Wastegate
  26. How to change Rear Differential Fluid
  27. how do you remove clutch line restrictor - help!!!
  28. Need Evo 8 Owners Manual!
  29. Re: Need to know how to connect an Air/Fuel Ratio Gauge
  30. Wheel hub removal and lug/wheel stud installation
  31. What tools for SS clutch line install and restrictor pill removal?
  32. Intercooler switch install for constant water on
  33. RS headlight
  34. Iridium plugs can't be gaped?
  35. Boost leak test
  36. Electronic boost controller install?
  37. Radio Wiring
  38. How To Install: New HID Bulbs w/ Partial Bumper Removal. (Pics)
  39. How to install agency power BOV
  40. Request: Dash Removal PDF File
  41. Transmission Fluid Change Instructions : EVO 8
  42. ACT Clutch & Fidanza Flywheel EVO 8 Installation Instructions!
  43. Greddy Boost Gauge Wiring
  44. Front Rear Swaybar install
  45. weapon-r engine torque dampner
  46. Question on Greddy Profec-B Spec II
  47. Hood Pin Install Request
  48. Six-point race harness belt installation
  49. Help with Downpipe Spring Bolts
  50. Need Help?
  51. ? about K&n oil filter
  52. Advice needed on parts
  53. Supra pump installation?
  54. ****Front License Plate ****INSTALL
  55. Spring Question!!!!
  56. Blitz FATT w/ HKS Harness Install
  57. move the battery to the trunk
  58. Basic steps to swap stock turbo out for TME, White Rabbit, etc.
  59. CLEANING STEERINGWHEEL(metal part)
  60. Modding MR Diverter Valve
  61. EGT Probe install how to request
  62. O2 housing question
  63. how do you re-finish stock wheels
  64. Stock Air Box
  65. Apexi Safc Ii
  66. helix intercooler pipes wtf???
  67. flip-out
  68. Fuel Rail install
  69. how to request: bleed lifters
  70. How to build an Intercooler Pipe Pressure Leak Tester
  71. Rear Diff/ Transaxle/ Transfercase Fluid change - what tools do I need?
  72. How do i mount a in-dash flip out screen
  73. Boost leak
  74. List of Places to Check for Boost Leaks
  75. Pivot Shift Lamp
  76. Carbon Fiber Exhaust Heatshield
  77. Need help how to crush a 1g bov
  78. Alky water alcohol injection installation question
  79. Infinity Complete Sound System Uninstall
  80. How To Install Aftermarket HU...
  81. APS Piggy Back EMU and Chip Question
  82. How do I take off this heatshield?
  83. Buschur Exhaust question...
  84. Defi D-Gauge Oil Temperature gauge intallation
  85. how do you take out the water sprayer tank
  86. Sway bar install (front and rear)
  87. It's hard to install in dash Mobile Video player(cd, dvd, flip-out screen)?
  88. HKS EIDS Type K Install
  89. Need Help with Hallman Boost Controller
  90. How to die / dye your carpet
  91. JDM Ganador, mod to work with US Evo
  92. URGENT HELP NEEDED (Brakes)!!!
  93. how to change cam gear settings
  94. Greddy Harness for TT, am I missing something?
  95. EGT Install Terminology Question
  96. How to Fill Tranny Fluid?
  97. blitz boost controller
  98. are 03-04 ecu pinouts same as 05
  99. Watermarks
  100. Koyo Bearing
  101. install MR taillights
  102. help installing DC sports titanium front strut brace
  103. Aftermarket turbo install??
  104. How do I install the Greddy Type-S
  105. RS power door lock conversion
  106. How To Mount Lancershop Autometer Steering Column Single Gauge Pod
  107. how do i mount my Autometer steering colum gauge pod?
  108. Lowering the Recaro seats in the Evo?
  109. How hard is it to install PLX m-300.....
  110. 255 pump problems
  111. Removing stock rear wing?
  112. how to adjust camber plates?
  113. Request: How Do You Have Your 5pt Harness Installed?
  114. Cusco Type 1 install?
  115. Intake Manifold pressure source
  116. Just installed Autometer Nexus gauges..Here is what i think.....
  117. Autometer Air?fuel Gauge
  118. EVC 5 Vacuum line pics connections needed
  119. How To: Evo Rear Bumper Removal And Evo Ix Rear Bumper Install
  120. official PLX R-500 install thread
  121. Apex-i AVC-R for Evo 7
  122. Help taking apart the headlight!!!!
  123. Need a DIY Removel of Dash
  124. Defi Gauge and Greddy Oil Block adapter
  125. EVO ticking clicking tapping
  126. Defi gauge installation
  127. How To Install A Taylor Battery Relocation Kit(evo8)
  128. How To Install A Taylor Battery Relocation Kit(evo8)
  129. rear bumper removal, anyone done this?
  130. Egt?
  131. Alarm system install request
  132. Fog/High/Low Lights
  133. Shifter bushing install
  134. Sparco harness bar
  135. Walbro 255lph Fuel Pump
  136. How To Remove your front and rear doors
  137. Rear Bumper Removal
  138. Front Fender Removal
  139. What wires should we splice into?
  140. How To Request: Battery Reloc to Trunk
  141. Dent Removal
  142. CAN SOME1 teach me how to install intake?
  143. Authority CF rear bumper protector question
  144. Touch up paint pen
  145. FMIC instal
  146. How to Degree Cams?????
  147. Helix Intake piping
  148. Please help
  149. Which way does my forge dv valve mount?
  150. INstalling Component Speakers in front
  151. Foglights on automatically with headlights
  152. removing steering wheel
  153. Samco Hose Install Question
  154. How-to: Autopower bolt-in rollbar install
  155. Do Luck Carbon Fiber Front Lip Install : EVO 8
  156. Helix Intake to a Stock AIRBOX
  157. Request on How - to / Installations for AVIC-N1 / N2 on Evo8 05'
  158. Painting your trunk lock
  159. rear sway bar install someone?
  160. Engine check light !!!
  161. How to install RMR carbon fiber gauge pod?
  162. Need opinions on re-wiring...
  163. Hallman MBC Evolution Kit Install
  164. VIS Cf trunk install?
  165. *help* Greddy Upper IC pipe
  166. Clutch Pedal adjustment
  167. tune-up...?
  168. aLpine CD/Receiver removal (how)?
  169. How to install Sparco Grip Pedals
  170. Power Enterprise Boost Control/Gauge
  171. Quaife Front LSD Install
  172. Quaife Front LSD Install
  173. Boost Guage - does it come apart?
  174. How to instal UR HF Cat
  175. Recommended Suction Kit & BOV upgrade
  176. Help, my car is not holding boost...
  177. turbo xs standard
  178. How To adjust Brake Light Pedal Switch.
  179. Installing Autometer Duel A-pillar pod?
  180. properly break in car and maintenance
  181. Zeitronix Wideband 02 Install
  182. Access to Parts and Accessories
  183. Need help with idle problem
  184. need wiring info for factory gauges
  185. stock gauges help help help
  186. EVO VII Wheel Stud Help Please..
  187. Center Console
  188. Exhaust Question
  189. how to ins. injen ic hard pipe and intake
  190. cusco v bar
  191. req. on replacing clock with greddy profec b
  192. Question about sportmeter indash gauges
  193. PSSSSHHHH!! Sound on the evo
  194. need pics of stock bov :(
  195. Hks type r intercooler
  196. Ssqbov
  197. How To: Install WeaponR custom EVO8 Catch can w/pics
  198. Need Wire Diagram for inside Fuse Box
  199. Anyone in the UCF/Winter Springs Fl area?
  200. Greddy Oil Temp and Pressure Guage
  201. How To: Eyelid installation
  202. Painting center panel pieces... just can it!:D
  203. How to Paint FMIC
  204. How to install air fuel gauge
  205. Help S-SAFCII unstall on 05 EVO
  206. Need help with boost spikes and boost drops
  207. Please post your settings for the Greddy Profec B spec II
  208. kinda related to evo...but how to...
  209. How to tighten up Parking brake cable
  210. Recirculating Button Light
  211. Wiring Question
  212. Blew the cap to my water pump
  213. megan racing dpand 02 housing install
  214. Greddy Profec B spec II
  215. Request on Hood pins
  216. Quick Question installing Apexi TT w/harness
  217. Walbro fuel pump problem after install
  218. Do I have boost leak? #'s given
  219. new manifold?!?
  220. AVC-R possability
  221. help installing walbro fuel pump
  222. Defi BF Control Box help
  223. How To: Change your O2 Housing
  224. HELP on Greddy TT Please!
  225. Need some help with HKS RS INTAKE/ Greddy type s bov
  226. HELP NEEDED!: Boost Gauge Wiring
  227. UTEC ABC install?
  228. Request: AP Steel Braided Clutch Line Install
  229. A/F hook-up on ecu for Autometer A/F Gauge
  230. 3inch flange/stock cat ??
  231. avcr install: presure sensor filter...
  232. AEM Replacement Filter
  233. How to hardwire iPod?
  234. air bag disable
  235. Help! 255 in starting out.
  236. help!!! installing blitz dtt dcII
  237. How do you install canards?
  238. Timing Belt Install Guide? Please!!!
  239. HELP, installing Turbo Timer
  240. sparco harness bar added installation details
  241. Question- How long it take s to install the clutch
  242. Turbo Timer Issue Little help please =)
  243. Help with spark plug wire change out
  244. Request: Cams?
  245. Mitsubishi CAPS - how/where to get?
  246. More Alarm Wire Q's
  247. Belt Tensioner for cams?
  248. Perrin fuel rail install question
  249. Why Is my Turbo Timer not Working?!?!
  250. Dome Light Wire
