View Full Version : Evo How To Requests / Questions / Tips
Pages : 1 2 3 4 [5] 6 7 8 9 10 11
  1. Spring and Retainer install
  2. Removing the Head...
  3. How To Polish and Buff Head Shield
  4. need advice on removal of.....
  5. how to install greddy boost guage????
  6. Apexi Grounding Kit
  7. ingalls engine torqe damper
  8. Help! My headlights aren't sealing properly!
  9. need help on installing my HIDs in my NON HID Evo
  10. How to discharge/refill ac system?
  11. Base Ignition timing advance how-to
  12. Swift Spring Install?
  13. 10.5 plus o2 housing pics
  14. Forge Res BOV Type RS
  15. C-clip and Anti seez, Where can I get this?
  16. Want to See: Cusco V-Brace Install
  17. tq Spec
  18. anyone running a aque mist meth kit
  19. spoiler removal
  20. Perrin o2 simulator
  21. CF under paint on wing
  22. Help with control unit II install...
  23. forge mbc easier from under car?
  24. JDM EVO 9 Bumper Part #
  25. Evo 8 Hks Cam install
  26. How To Paint the mesh on the Hood Vent?
  27. How to lower my car?
  28. Wanting to change out transfer case...
  29. Question about bodykits
  30. need help in tt
  31. Throttle body air leak...Pics inside with how to fix!!!
  32. Adjust hand brake?
  33. help with my avc-r boost controller
  34. help with forge bov
  35. Blowout Valve Question!! Help Out Plz!
  36. need asap!!!
  37. Conversion Charts for Defi kPa or Celcius gauges
  38. Proper storage of the gas cap on the clip
  39. How to: Make your test pipe look like a CAT
  40. How many hours to require to install the HKS EVC
  41. Carbon overlay install for Front Mitsubishi Emblem
  42. $5 o2 cheater/non fouler how-to
  43. Another DIY Grounding kit Install...
  44. Shifter cable install?? Please help!
  45. INtakes..Short ram?cold air? heat shield? drop in?
  46. Need help with APR canard install, they don't seem to fit
  47. ghetto evo7 tails for under 30 bucks
  48. How to get rear view mirror off?
  49. Cheap and easy trunk lid "handle"
  50. 10.5 hotside and o2 housing install?
  51. HELP! can't get the fill plug off!
  52. How to create a stealthy interior, black.
  53. How to create a stealthy interior, black.
  54. Energy Suspension Polyurethane Bushing Master Kit Install
  55. Porting Question
  56. HKS RS intake ??s
  57. is there a how to on removing and installing clutches
  58. Is There A How To For Water Injection
  59. Greddy Type RS BOV One Spring Mod
  60. wheel rash repair
  61. removing side mirrors?
  62. Good assembly lube for cam install?
  63. Walbro Pump Install
  64. greddy bov rs
  65. Problems with new injen intake
  66. trunk/cabin pass-through
  67. Removing door panels on an RS
  68. Beatrush Underpanel How To Request
  69. anyone a diagram for a iat sensor??
  70. engine harness
  71. Front emblem removal IX without bumper removal
  72. In dash DVD install help on a evo IX
  73. HKS/Blitz Harness work on an IX?
  74. How To Install the grills on the Evo IX front Bumper?
  75. SRS warning light question
  76. t-case drain bolt size
  77. Hooking up air fuel gauge Question??
  78. mbc install question
  79. 06 evo 9 RS question
  80. glove box removal
  81. Interior Glow Switch wiring!
  82. greddy type s help
  83. Any one has a picture of an MR intercooler
  84. stupid problem to have
  85. seibon hood
  86. cf on wing
  87. o2 housing
  88. safe to launch at 5k?
  89. Fuel Pump Install
  90. MBC Installation Location
  91. Jdm Evo 8 rear bumper install
  92. How-To polish (rims)
  93. Urgent information needed
  94. ARC Filter
  95. Steering Column Cover Removal
  96. EVO 9 MR speed signal wire help!!
  97. Problem with transfer case cover
  98. Rear mud flaps
  99. Dash Repair
  100. Want to know how to install HID kit in EVO4-6.5?
  101. how to wire up headlamp leveler??
  102. Wire colors for the "low fuel" light?
  103. Greddy TT Grounding Question
  104. Is this shifter weird or what?
  105. HELP with WIRING DIAGRAM
  106. Ingalls Engine Damper Help
  107. Simple/cheap front mud flap install
  108. electrical wiring for guage install??
  109. How to Request: Programming the Apexi AVCR?
  110. how do you crack the cam pulley nuts off ?
  111. Swapping power windows/mirrors/locks and remote locking into an RS
  112. defi gauges acting up, need some help
  113. Request: Carbon Fiber how to ???
  114. How To Modify Front Underbody Panel For Easy Floor Jack Access.
  115. HKS CAM INSTALL ISSUES :( not good
  116. heat gun or oven?
  117. uninstall autometer ultra-lite gauge?
  118. Need help installing Trailing arm bushing?
  119. need help with alky instal
  120. boost gauge vacuum line fpr isnt that bad
  121. Making your tails JDM look alikes!
  122. How to make plugs for your spoiler holes
  123. Oil Temp Sensor Cable
  124. removing the factory shift knob
  125. The Ultimate Valentine One Concealed Setup
  126. DIY - Paint Custom Paint Your Rims! Red Lip (Lots of Pictures)
  127. Installing control arm bushings
  128. T-Bolt Clamps (How to and list)
  129. Changing Entire Exhaust! Any Tips? Advice?
  130. Yet Another Amber Interior Lights -- Includes Foglight and Headlight Switches!
  131. AMS Exhaust Gaskets
  132. How do you install injectors on the evo.
  133. NOS on a IX?
  134. Convert BAR to PSI
  135. Rear passanger auto lock wont work?
  136. Transfer Case
  137. Nisei Upper Intercooler Pipe: Help!
  138. streetconcept V-style help
  139. DIY Black out your Evo headlights
  140. How To: Remove Perrin Antenna Gap
  141. Downpipe Air leak
  142. Yet another MBC install question (PIC INSIDE)
  143. Greddy Profec B II Install Pics
  144. Greddy 52mm Boost Gauge reading in Bar
  145. Agency Power front motor mount
  146. Timing Belt How to...
  147. question about uego install
  148. How To VID: OEM Grounding Kit installation points
  149. Questions about Buschur Stage 2 kit w/Deluxe IC
  150. How do u change the modified fuel cap back to the original fuel cap
  151. Adjusting E-brake cable
  152. Greedy type Rs installtion question
  153. How do you remove the gauge cluster to replace burnt out lights?
  154. Evo 9 Agency power BOV
  155. Evo 8 - fitting 3rd stop light after changing spoiler
  156. Wire problem
  157. need help
  158. how to make a dual brake bleeding catch can
  159. Illum wire in radio/clomate control panel?
  160. Tips on how to install cusco oil catch can?
  161. NEED HELP on installing greddy type rs recirculaiton when the BOV is not in position
  162. URGent
  163. power window and door locks
  164. Fixing the caliper paint problem
  165. Stainless Manifold Stud help
  166. Painted tailight problem
  167. Powerflex motormount install w/o press
  168. Do I have a fuel pump already?
  169. Installed my MBC, have a question...
  170. need help..
  171. Cam install DIY question
  172. boost problem
  173. Trunk Bar
  174. anti fouler
  175. Oil Temp Gauge
  176. How to open your tails
  177. Power Steering Removal Question
  178. Exhaust and warranty question please help
  179. How do you adjust JDM headlights?
  180. HKS type 1 turbo timer install for a IX
  181. Downpipe to turbo outlet issue
  182. Authority Turbo Outlet
  183. Leak tester parts source
  184. Help Car Wont Start!!!
  185. Help Car Wont Start!!!
  186. intercooler and bov
  187. HOW TO: Install an EVO 9 CF panel into an EVO 8
  188. I need your help on Greddy boost gauge
  189. do you have to remove to subframe to get transfer case out?
  190. Taillight removal
  191. IX MR Oil Change
  192. rs with stock infinity system
  193. help with timing
  194. Kartboy Exhaust Hanger Silly Question
  195. Help!!!
  196. Bypass Transponder w/ PKU-MIT for E9
  197. How To: Hook up the boost gauge to the dimmer switch.
  198. questions about defi oil pressure install
  199. How To Black out Headlight (Detail)
  200. Bulb Classification superbrightleds?
  201. Where to Buy Console Lights
  202. Will this Triple Gauge Pack fit in the Radio Slot
  203. DC Sports 2 in 1 Downpipe and Cat. delete install notes
  204. How much boost can the Type S BOV hold??
  205. EVO VIII spoiler removal
  206. HKS BOV poped off
  207. Valve Spring Tool?
  208. How to Install Oil Temperature Gauge
  209. shifter panel
  210. I have Non HID Foglight headlights and want JDM MR
  211. question on greddy turbo timer
  212. Finished my gauge/radio swap...but
  213. Wallbro?? Fuel Cut??
  214. help.
  215. In the middle of radio/gauge swap!!
  216. Convert GSR/RS to Factory HID w/Fogs
  217. Defi boost gauge question
  218. how to install hks TT type-1 HELP!!!
  219. cig lighter removal
  220. Wire back to stock ECU
  221. New FMIC, downpipe, cat delete
  222. Quick question. about hard pipes
  223. sports meter kit
  224. How To replace just the bulb
  225. How To replace just the bulb
  226. Red Interior Lighting on the IX
  227. Service Manual Boost Gauge Install Question
  228. What oil filter for a IX
  229. DIY Muffler Delete
  230. How do you make custom panels?
  231. hks evc v instructions
  232. hks turbo timer type 1 manual
  233. greddy tt
  234. k&n intake
  235. Aftermarket boost gauge install on MR
  236. carbon fiber trunk
  237. zeitronix???
  238. How to HID complete Headlight swap into RS
  239. Hks Eids Woes
  240. Espelir exhaust question
  241. how to remove headliner?
  242. Greddy boost Gauge wiring help
  243. DIY Mini Battery kit. Looks like the pros.
  244. Boost Gauge question
  245. Putting in Sparco racing shells - A dumb tip
  246. Headlight Adjuster (NOT!) obs.
  247. Manifold installation question
  248. How to Request: HKS Circle Earth
  249. Boost Vacuum lines part number?
  250. Hard Water Spots fix
