View Full Version : Evo How To Requests / Questions / Tips
Pages : 1 2 3 [4] 5 6 7 8 9 10 11
  1. How To: Install a Zeitronix Wideband
  2. Carbon Fiber Hood
  3. HELP!!!!!!!! I'm an IDIOT!!!!!!!!
  4. How To: Fog Lights ANYTIME
  5. Megan Racing 02 Housing, How Hard To Install?
  6. Need Help for a friend installing AEM trueboost gauge\controller.....
  7. Turbo Timer Install Help
  8. climate control relocation
  9. Help! Front Right Control arm install..
  10. How To Post a Write up
  11. tein lowering springs....
  12. Please help Im hidious.....
  13. ? For those with the Rexspeed Triple Dash Pod...
  14. '06 RS low beam upgrade headache......
  15. How to Install Power Locks on a RS
  16. Install help for a Greddy Profec-B spec
  17. exhaust manifold.....
  18. intake manifold..problem.
  19. hks grounding kit
  20. license plate holes
  21. How to install a nipple on an Aftermarket LICP. Fixes Low boost flutter of BOV
  22. How To: Make Fog Lights funtional WITH PARKING LIGHTS
  23. Fog Lights
  24. A-Pillar Drilling
  25. How to Dissemble Evo Wing??
  26. need dyi turbonetics mbc install
  27. Glove Box
  28. Help! GL-4 fluid from Mitsubishi
  29. Need Help W/hid Adjustment Motor
  30. Power Enterprise Wiring Help....
  31. How to Install Headlight Protection Film
  32. How-to Perrin 25mm rear swaybar & stout mounts
  33. Blacked out taillights
  34. Clutch Install
  35. any mod to make the 4 corner jackpoint stronger?
  36. Speedometer
  37. HKS filter maitnance
  38. ams vsr intake manifold
  39. cutting out the tri-angle in bumber (8)
  40. Is it possible for an ordinary owner to change TC/tranny fluid?
  41. T-Case removal.
  42. how to hook up greddy TT?/
  43. (Request) How to setup max boost using MBC
  44. Power Enterprise Boost Gauge/controller Installation Diagrams, Color Codes.
  45. EVO IX ECU pin chart
  46. Lock/Unlock Wire color at door
  47. Boost Controller Installed Incorrectly?
  48. turbo timer type 0
  49. Anyone done washer mod on evo headlights?
  50. electrical problem?
  51. Swift Spring Install How-To?
  52. Diy Licp?
  53. help. dash lights out.
  54. apexi super ground system mounting spots
  55. How to remove OEM o2/Downpipe Donut Gasket?
  56. how to install a front engine mount
  57. how to check if crankshaft sensor is bad?
  58. Gauge Options
  59. I need some help
  60. NEW HKS EVC wiring troubleshoot help.
  61. Tc.....
  62. 02 Housing Install w/pics
  63. plug the o2 hole
  64. A-pillar/stock gauge info-help
  65. Torque specs on exhaust bolts
  66. lowering springs???
  67. Help Help, cant get this right
  68. COOLINGMIST METH KIT evo people who have it and i need a experianced installer
  69. HKS Chrono gauges - How to Use??
  70. How To: Install DC3 Catch Can
  71. How To: Install DC3 Catch Can
  72. How To: Install DC3 Catch Can
  73. Help finding a thread - dashboard gauge install
  74. Help: Retarded Oil Pressure Gauge Install
  75. fuel pump install
  76. Cam position sensor housing leak/sealant.
  77. HELP! Car won't start
  78. NEED HELP WITH HID's
  79. Replace/Change/Mod EVO Horn
  80. Car in shambles due to DP...
  81. engine harness removal?
  82. HID bulb replacement
  83. install for connecting rod bolts??????
  84. pulling the drivetrain
  85. Defi Control Unit Install Help!
  86. Installing Beatrush Propeller Shaft Bushings In your Garage
  87. Greddy TT
  88. Where to mount turbo pressure gauge on a EVO VI TME
  89. Rear differential Pic request
  90. is there any way??
  91. Water Temperature Sensor Adapter
  92. JDM EVO MR headlights into US EVO MR
  93. Anyone know how to disassemble stock gauges????
  94. AEM Tru-Boost Tuning Question
  95. How to replace front o2 sensor
  96. Need help With EVO9 9006 bulb replace
  97. Removing B-Pillars And Rear pillars
  98. Simple Question for those who have installed a Gauge
  99. Exhaust Manifold "Stud" Removal
  100. Passenger side window replacement
  101. need help taking out side mirrors
  102. tanabe teas installation?
  103. VIS Carbon Finber Trunk Lid
  104. how do you rewire to keep the foglights on with the lows?
  105. How To: In-Car Valve Spring and Retainer Install
  106. AMS upper intercooler pipe kit
  107. Installing street-legal 4-point harnesses in the Evo (Schroth)
  108. Installing a Beatrush Aluminum Under Panel
  109. Magnecor (or Ralliart) Spark Plug Wires
  110. ok i need some help with an auto meter gauge
  111. how to remove the paint on the hood vent?
  112. How do i get through the dang firewall...
  113. HKS Turbo Timer Type-0 installed but..
  114. How To Remove Wing? Can someone Teach Me?
  115. o2 wire..?
  116. o2 wire..?
  117. Evo VII standard fuelpump size (diameter and length)
  118. Fuse Removal For Radio/Dome Light Help!
  119. how to disable seatbelt beeper sound
  120. How to take off the frozen bolts
  121. Guage Problems
  122. EVO 9 MR HID ballast/ bulb install help..
  123. Window air deflector install tips?
  124. NEW SUBWOOFER BOX IDEA. small size, light weight, and good sound
  125. Safc Ii
  126. head unit
  127. 5th point location with race harness?
  128. Where is a safe place to Jack up your evo9MR
  129. any wiring gurus here?
  130. BC Racing coilover install, BR series
  131. Cheap Mitsu Wheel Studs
  132. evo 9 gauge panel schematics?
  133. Question about painting headlights?
  134. One touch close sunroof mod
  135. How to modify your stock "lancer" gauge to accept useful gauges
  136. How to remove ECU
  137. how can i revert back to stock settings?
  138. Help jdm evo 7 tail install
  139. Clutch fork direction??
  140. Seibon Carbon Fiber trunk on Evo 9 MR
  141. Routing Line for Meth
  142. MBC Tie-In Point
  143. VEI Triple-Gauge Install - boost, AFR, oil pressure
  144. Evo IX Front Bumper Removal
  145. Painting Rims? how to?
  146. Turbo-XS RFL Ti catback install question...
  147. Fuel Pump Install Problem!
  148. Cleaning the throttle body
  149. looking to replace defective turbo coolant line
  150. How to remove sound damping material in a non RS?
  151. Omori guage install???
  152. How to : repainting Brembo brake calipers?
  153. Intercooler piping hitting Fan
  154. How To Install Seibon OEM CF Hood?
  155. Is there a howto for hiding wires in the motor bay
  156. GT35 turbo ...intake..MAF... help/ questions
  157. ...hope this is the right place to post
  158. Helix V2 down pipe install problem
  159. Question on installing aftermarket tail lights....
  160. How To Adjust Camber Front & Rear
  161. Need help removing front axle...
  162. How To- Install SAFC2 into Sun Glass Console
  163. Smog Help in California
  164. 03'/05' Evo exhaust swap?
  165. Greddy Turbo Timer and Remote lock failure
  166. boost
  167. crank angle sensor
  168. How to install a flip-down DVD screen for rear seats?
  169. stock wastegate
  170. Relocating HVAC
  171. forge bov
  172. Major Issue Of Evo? Someone Help Me Out!!
  173. greddy profec spec 2
  174. Gas door question.
  175. Ideas for weight reduction with full interior
  176. oem boost solenoid
  177. Anyone know how to get grease and tar off of underbody?
  178. Door panel removal and speaker installation
  179. need help with shifer light
  180. fUSE ?
  181. need help(auto gear oil)
  182. foglight question.
  183. ATF SP 3-how to change gear iol for auto evo(evo 7 GT-A)
  184. ? APR EVO 8 Carbon Fiber Front Splitter
  185. i need electrical help!!!
  186. Need help with gauge install(wiring)
  187. How To: Protect Your Intercooler
  188. Removing/Installing front lip on Evo IX
  189. exhuast install help?
  190. Mechanical 02 fix...
  191. JDM Headlight Install
  192. Help w door Panel Scratches
  193. How difficult is it to change the accessory belt and radiator hoses?
  194. help with perrin mbc intall
  195. LC-1 owners where do you mount the controller
  196. Autometer Air/Fuel gauge
  197. How to : Install HKS SSQ BOV Recirculation Kit
  198. YARIT: Yet another red interior thread
  199. Replacing headunit of a 2003 Lancer
  200. Brake Rotor Swap
  201. Will the CEL light affect performance?
  202. How to Remove Alternator
  203. 30,000 Major Service
  204. Defi Control Unit Warning Mode Help
  205. how to remove 3rd brake light cover
  206. How to pull the motor
  207. Help installing RALLIART CF center consol
  208. Sun hyper force ignition?
  209. Removing rear o2 sensor on Evo IX
  210. Lost Wheel Lock Nut
  211. Blinder M-20 Laser Jammer Install
  212. fog lights on with run lights
  213. APR GT3 Mirror Install
  214. Need pin chart for Evo IX
  215. stock head stud removal tool?
  216. Best way to remove paint from wheels??
  217. Need help installing APR cf mirrors
  218. How to: HorsePower Freaks 2.5" LICP install*Pics
  219. Radiator fluid chang?
  220. Living in Seattle WA, where do I take my car?
  221. Help:
  222. Performance orientated battery relocation, amplifier and subwoofer install
  223. Help Misfiring
  224. How do you tighten front bumper to get rid of gap between headlights?
  225. HID install
  226. 2003 Eclipse Clutch Install. trying to help friend.
  227. How To: Properly Bed your Brake Pads
  228. O2 Housing and Exhaust Manifold Replacement DIY Request
  229. Crank Pulley Problem
  230. ignition install problems
  231. take out back seats
  232. Perrin boost tube help
  233. RRE oil catch can install and PCV valve delete
  234. Clutch Cable Install
  235. How to connect dash lights to headlights?
  236. Power steering flush
  237. Tow hitch
  238. how do you get to wastegate/adjust?
  239. Anyone rebuilt their own Transfer Case?
  240. Evo's oil change with pics
  241. wheel fitment...
  242. Help with roof trim....
  243. Just installed FMIC, what do i cut off of Zero Lift kit?
  244. RRE MBC install questions
  245. Cruise (I hope!)
  246. problem installing a 10.5 hotside
  247. spring install help !!!
  248. Removing front and rear crash beams...
  249. boost leak test
  250. wing sun damage??
