View Full Version : Evo How To Requests / Questions / Tips
Pages : 1 2 [3] 4 5 6 7 8 9 10 11
  1. How to install a turbo xs ignition amplifer?
  2. How To Request: Clutch Master cylinder
  3. Request: Boost Leak Test With Pictures
  4. How To install cams in a IX
  5. How to shave off triangle for Evo 8?
  6. Requesting How to on Greddy TI-c for ix
  7. Stock Exhaust vs Modfied Apexi WS2
  8. Transmission and Transfer Case
  9. What is the Best Way to Install Engine ???
  10. need help on wing install and removal
  11. apg oil catch can
  12. How do I install a forge mbc for a gt35r?
  13. DIY Installation
  14. Drivers side motor/trans mount?
  15. oz or ralliart trunk on evo
  16. convert evo ix to mr headlights
  17. need help with hks bov
  18. Side motor mount
  19. Autometer Electronic Boost 12V Question
  20. Polishing the stock intercooler
  21. What Tires are Recommended for 19x8.5 on an Evo
  22. Thanks Random People
  23. a pillar gauge pod problem
  24. New brake fluid procedure
  25. How to Swap Transponders from USDM key to JDM key
  26. cant get bottom heat shield off please help
  27. 2003 front o2 sensor location help please...
  28. intake manifold swap...
  29. HELP!! need the location of the front o2 sensor
  30. Help with Stewart Warner Gauges Please
  31. How Prosport Boost EGT Oil pressure
  32. Side mirror removal & Ganador install
  33. Painting Brembos how to
  34. G2X Data Acquisition
  35. Need direct on porting
  36. help with steering wheel
  37. Prosport Air Fuel Ratio Gauge Calibration
  38. Service manual EVO 7
  39. how to change the rod bolts?
  40. how do you Bright a very dark interior
  41. Idler Pulley/Accessory
  42. Where should I put my front plate?
  43. evo IX problem! please help!
  44. How do I reduce weight on my IX?
  45. HKS Type 1 Install without Harness
  46. serpetine/drive belt HELp
  47. Learning about the engine bay
  48. need help for after market head unit install
  49. How do you remove the stock ecu?
  50. HID Problem
  51. Question: can you cut stock...?
  52. Help !!! New Turbo Mods for My Evo III
  53. Prosport Oil Pressure gauge help
  54. HKS Turbo Timer Type-0
  55. Megan CB and JDM Bumper: ANYONE?
  56. HID headlight adjust...03 evo8
  57. 05 clutch install, alternative method, makes it trivial
  58. aem intake question
  59. stripped a brake line installing stainless lines, HELP!
  60. hewp!! Where is the o2 sensor wire??
  61. how to install rear door window glass
  62. intake manifold removal
  63. intake question
  64. Installing CF Ducts- what needs to come off?
  65. Need Help: Installing Apexi air filter
  66. any one running HKS SSQV EVO BOV Ver. 2 Kit W/Pipe
  67. Rear wiper dont cancel.
  68. Removing ABS sensors????
  69. stuck bolt on heat sheild
  70. Prosport Gauge Boost Install?
  71. Fiberglassing info needed
  72. how to install aftermarket horn
  73. Buschur Racing Viii Carbon Lip Help!!
  74. Recipe for 400whp??
  75. Evo8 vs Evo9 front bumper cover
  76. HELP!! Will this Defi gauge even work?????
  77. AVCR install or Ecu Pinout for Evo IX
  78. Loose rear view
  79. Alarm system wiring question
  80. Quick help- Removing Washer Sprayers from Hood
  81. question about boost controller and boost guage
  82. IX VG Help
  83. Remove Gauge pack from RS require removing HVAC piece?
  84. anyone know how the 3-bar map sensor from Group-s works???
  85. brake rotors removal
  86. How to boost your octane using various formulas
  87. boost leak question?
  88. i have 1000 what do i do
  89. HOW? to install Blue Racer Defi Boost gauge
  90. defi contriol unit ii
  91. Camber plate install
  92. will the HKS evc or Blitz SCBIII fit inside the sunglass holder?
  93. How To: HKS Type 1 TT on Evo IX
  94. Fog Light Wiring
  95. Having a problem
  96. greddy profec b spec 2
  97. How do I remove the center console?
  98. fog lights will not work!!
  99. Tanabe spring install help
  100. 2006 Evolution IX MR Transmission Fluid Change
  101. Jun B.L install + lessons learned
  102. Tip: Evo IX V1 hardwire installation
  103. does the oil filter really madder?
  104. Quick does anyone know the oil pan drain bolt thread size?
  105. turbo timer & boost conroller mounted together.
  106. Steering wheel removal and install a new one?
  107. Looking for an easy way in removing those bolts from the Catalytic.
  108. Alarm system install ?
  109. How To Install Laile: Beatrush Undertray Mitsubishi Evolution VII-IX
  110. perrin oil catch can
  111. boost gauge
  112. boost gauge
  113. hid failure?
  114. Aeroquip flush hood latch - DIY install
  115. Request: clean up the "How-To" section
  116. How To: Fully integrate Turbo Timer and Alarm - with Shock Sensor
  117. easy place to put gauge?
  118. Need help removing front Brembo calipers!
  119. Installation Manuals
  120. Installing a harness bar for evo 9
  121. Taking apart the dashboard....
  122. HOW TO: Taillight Blackout
  123. Side Passenger motor mount installation?
  124. need help with o2 sensor
  125. how do you remove???????????
  126. Pls. QUICK HELP to install my Vortex Generator
  127. need help with takata harnesses
  128. stock solenoid install
  129. caliper clearcoat refresh... remove caliper?
  130. Painting stock lugs
  131. Need help. How do you polish stock strut bar?
  132. Oil catch can installation
  133. Install AEM Wideband guage with sensor
  134. How To Take Off Front Headlight?
  135. How to Install a Proper Front Tow Hook for Racing
  136. Intake question
  137. apexi tt just FRIED my Evo!!!!
  138. Request: EVO RS Trunk
  139. How To: Remove ABS
  140. CAI in 9 with ACD?
  141. will it work? (headlights)
  142. Need "How To" for HID's and OEM Fog lights for RS models
  143. Question about exhaust install...
  144. Need help installing injen upper pipe, CAI
  145. How to preload your WGA (video)
  146. Tires
  147. Spark Plug install
  148. Going back to stock exhasut need help
  149. Those with ARC catchcan and mini bat help please
  150. rear wiper
  151. evo ix cam install
  152. need a how to on...
  153. Rewiring stock amp
  154. How to install intank fuel pump?
  155. Fuel pressure regulator setting?
  156. Valve Cover Painting...
  157. HOW TO: keep the clock from dimming when you turn the headlights on
  158. INSTALL: VEI systems Triple-Gauge
  159. HOW TO: clutch pedal adjustment
  160. INSTALL: radio relocation kit
  161. HOW TO: modify your stock "lancer" gauge to accept useful gauges
  162. INSTALL: oil pressure and temperature senders
  163. HOW TO: "gus mod" dejon tools leak stop kit (MR BOV!!!)
  164. HKS DLI2 install directions please
  165. Please help with Greddy Profec B Spec II
  166. help! buschur delux fmic/ ic pipe
  167. (HELP)My Sunroof doesn't close!
  168. Perrin PWI-1 Water Injection System install pics
  169. front intercooler mesh
  170. How do you install a fuel cut off switch
  171. easiest to replace o2 housing?
  172. How to Remove/Replace Tie Rod
  173. Need help separting top part of Recaro Front Seat from bottom half
  174. How to Request: Re=tapping a bolt hole
  175. v1 hardwire questions...
  176. Forge Bov Question
  177. Input on rear axle removal?
  178. Input on rear axle removal?
  179. Installing Chassis/Suspension Braces
  180. Need Help. Installing Tach
  181. illumination
  182. Tuning the Profec B spec II--simple version
  183. How-To Request: OEM wing on Carbonfiber trunk
  184. how 2 install AVC-R
  185. EVO 8 to EVO 9
  186. How to Install an AutoDimming Mirror
  187. DIY billet oil catch can for about $20
  188. Timing belt tool needed?!?!
  189. brembo face lift, changing the red
  190. cleaning up inside of IC/piping? tips please?
  191. Three Spoke Shroud on back of wheel - Loosen or remove?
  192. All motor mounts installation how to??
  193. Evo OEM spray paint?
  194. UK Evolution IX Badge INSTALL w/Pics
  195. rs*r gtII exhaust
  196. AEM truboost electronic boost controller install
  197. o2 housing to downpipe bolt question
  198. evo RS power windows and doors
  199. Front license plate holder
  200. Removing side marker lens?
  201. taking off a stock wing on the evo9 help!!!
  202. Plastic clips under door scuff plates
  203. IIIV front bumper lip screws?
  204. How to remove glove compartment?
  205. triple gauge panels and bracket modifications
  206. Joining dissimilar metals
  207. Installing Wing - What to use for "gasket"?
  208. Greddy Profec E-01 Install anyone?
  209. haze in headlight help
  210. Cusco Catch Can Isntall
  211. 02 Cat Delete NEW TO THIS questions
  212. How to install cf heatshield??
  213. ss o2 housing install?
  214. help please
  215. Kartboy and Cat Back
  216. My Battery relocation and trunk net [pics]
  217. Detailed Defi-Link Boost & Oil Pressure / Temp Directions
  218. mitsulogger 1.5v
  219. little help please
  220. Ultimate Racing Fuel gauge adaptor
  221. Mechanical and Electric Question
  222. MR driveline fluid change
  223. Remove Left Front Axle?
  224. Easy and quick way to install o2 housing and exhaust manifold.
  225. Making your own LICP & UICP
  226. Stewart Warner 42 Draft Designs
  227. Mechanical BOOST GAUGE PARTS Please help
  228. s-afc??? help
  229. sold srt4 got evo9 please help
  230. Oil Press. "T" Piece check engine
  231. fuel pump. please HELP!!
  232. How to install JDM rear bumpe?
  233. Help SafcII to stock settings???...
  234. HID conversion kit Fog Lights 3000K
  235. can u make cwest canards fit the stock evo bumper?
  236. What's the size for the Greddy shift knob to fit on the Authority short shifter?
  237. Defi-D gauge off
  238. BOOST/AIR FUEL/OIL TEMP quick question
  239. How to clean a O2 sensor
  240. clutch install parts
  241. Rear Bumper Removal
  242. help installing clutch
  243. How to Replace lancer "gauge" with omori 45mm boost gauge
  244. help installing apexi cone filter
  245. Aftermarket "MR" gauges?
  246. I need help removing the top portion of the rear seats
  247. DEFI where do i tap these wires????
  248. Setting up the Apex'i AVC-R
  249. Oil Temp/Pressure Sender Install
  250. adjust throttle cable
