View Full Version : Evo How To Requests / Questions / Tips
Pages : 1 [2] 3 4 5 6 7 8 9 10 11
  1. valve cover install
  2. Help Reinstalling Kickpanel
  3. grommet size and install?
  4. How to request: removing powersteering hose.
  5. dusty headlights?
  6. Coilover install--how to request
  7. how to post photos?
  8. Prosport Premium Gauge wiring help.
  9. Alarm/Uninstallation HELP!
  10. How ot launch Big turbo, big cammed car
  11. edfc harness routing
  12. paint remover on blacked out headlight?
  13. Boost Gauge install HELP!!
  14. Question about painting headlight housings
  15. Min. Oil Presure in an EVO7
  16. help: invidia O2 housing install
  17. blacking out headlights...sanding???
  18. How to flush car fluids?
  19. help! need advise from you guys
  20. spring removeall/install help!
  21. which clutch is right for me?
  22. Remove Front Recaros.
  23. evo viii compresson housing swap
  24. HKS Cirlce Earth grounding kit instructions?
  25. How to take apart taillights
  26. How To: Make headlights clear
  27. Front Motor Mount Bolt
  28. Making JDM headlights functional in usdm ix gsr
  29. 06 Evo IX - how do I remove the stock stereo?
  30. weight reduction and weight balance
  31. Can you paint cloth seats?
  32. Problem with the engine
  33. How-To Request - Replacing Evo VIII Instrument Panel Bulbs
  34. how to: install charge speed front lip?
  35. need help on how to get taillights to go back to clear look
  36. AMS UICP pics??
  37. Dash Lights NEED HELP PLEASE
  38. How to remove MR shift knob
  39. How to remove steering wheel from steering column?
  40. Which oil filter in this list is most appropriate
  41. Removing Air conditoner
  42. Importing Pre VIII EVO
  43. How to install the HTA 35R
  44. How to remove a defective O2 sensor, including wiring?
  45. Oil Pressure Adapter
  46. How Do I: wire the rear wiper?
  47. mitsubishi evo 8 boost gauge in bars
  48. How to modify VIII bumper to look like IX?
  49. Instal of bov
  50. how to change acd fluid?
  51. IX ECU outputs for Apex TT
  52. Titek O2 housing / DP spring bolt question
  53. using aftermarket seat with stock seatbelt
  54. Mustache bar bushing install?
  55. Sun Auto Hyper Gauss Install
  56. installation rexpeed type 1
  57. Siebon Carbon Fiber Hood/UICP
  58. Leather hand brake removal
  59. AC removal - refrigerant evacuation
  60. Boost gauge errors
  61. Question about installing Oil Temp sensor
  62. Key compartment on evo trunk.
  63. Greddy Full Auto Turbo Timer
  64. How To: Boost leak tester for $5.02
  65. AVC-R Help
  66. Defi Heads up display film--got questions
  67. Antenna Help
  68. Rear Diff Fluid Change on Evo VII
  69. Buschur Front Undertray Install
  70. paint VIII tail light lens red
  71. Door handles?
  72. Oil change - 5qts and still low!?
  73. Any How-to for Head removal?
  74. Removing black stain/residue on rear bumper.
  75. exhaust manifold torque specs
  76. 06 wicked white Evo IX MR FOR 29,00?
  77. How to remove the rubberize sealant
  78. Apexi/Blitz TT
  79. c-west rear bumper install
  80. What is fender work
  81. Rear Differential Removal
  82. Raptor Performance Shift Light/HELP!!
  83. HOW TO: Bleed Your Lifters
  84. Will Evo 8 intake fit Evo 9?
  85. Request: Replacing Valve Cover Gasket and Spark Plug Seals
  86. Replacing EVO 8 oil pressure switch/sensor please help
  87. Disassemeble cigarette lighter
  88. ** HELP** Evo 8 USDM lights
  89. How to put wing back on??
  90. How to: Make a non foglight evo to a foglight evo?
  91. Centering exhaust???
  92. JDM bumper license plate modification??
  93. Component Speakers install?
  94. How TO: release throw out bearing
  95. Anyone find a how to AC removal?
  96. MBC install?
  97. BOV on 06 MR???
  98. Trunk Wing Hole Size
  99. Rear Speaker install?
  100. Turbo oil line to pan gasket...
  101. TurboXS Intercooler Install
  102. Help: How to take apart my turbo for coating
  103. How to replace O2 housing (pics)
  104. How to remove the IACV from TB?
  105. What Gear To Adjust Mbc In?
  106. Megan 02-DP Gasket?
  107. Replacing Fog Light Bulbs
  108. Thinking of a Shorter EVO?
  109. Hks Evc Vi
  110. Engine Installation?:(
  111. Turbo removal...
  112. Shifter Bushing Install Help
  113. Grounding Kit Points - Results
  114. EVO VI: Cusco shocks installation?
  115. Service interval
  116. ix mitsu diamond removal?
  117. defi blue racer gauge...
  118. Replacement of Heater Core
  119. installing IX SE front lip
  120. How can I get my fog lights to turn on with only my parking lights on?
  121. Headlight Help
  122. Side Marker light question
  123. Side Markers Removal
  124. EVO Trailer HITCH
  125. Wastegate Actuator Arm re-installation
  126. Side Window replacement? HOw?
  127. How Do I Remove Badges Off 08 Gts?
  128. Need some help with EGR solenoid replacement
  129. DIY prosport boost gauge install
  130. evo power steering
  131. need help with gauges install
  132. Power locks and Cigarette lighter not working.
  133. anyone have pics for tbe install?
  134. Anyone have a step by step on how to install afermarket stereo
  135. e brake
  136. Need Pinouts or factory radio harness
  137. 4 point harness mounting point
  138. Where to mount wideband O2 sensor?
  139. Tips/Pictures on hiding Boomslang wiring harness
  140. Take off front sidemarker lights
  141. HKS RS Intake won't fit my IX!!!
  142. how to replace cam seal
  143. Battery Boxes – Metal or Plastic?
  144. installing a Blitz SBC i-Color
  145. hks intercooler evo ix
  146. EVO IX Shift knob replacement...
  147. requesting front seat removal guide.. thanks
  148. HELP!!! Serpentine Belt Removal and Installation
  149. EVO IX power window switch removal?
  150. Evo IX Non-HID Headlight Issues
  151. GReddy Oil Cooler Kit Install
  152. The real way to port headers
  153. HELP Wiring a Bosch Universal O2 Sensor
  154. LICP install without removing front bumper
  155. Cuaco catch can???
  156. Hks Eids Tunning
  157. evo IX acd solenoid
  158. replacing turbo
  159. test pipe with stock dp?
  160. Grounding Cable Install Pics
  161. Where the heck is the coolant drain plug
  162. How to re-install trunk tension bars?
  163. FP EVO Green 20g-lt request
  164. replacing turbo/ removing turbo
  165. AEM Wide Band Installation / Question
  166. all carbon fiber wing
  167. Throttle cable relocation question.
  168. RRE Cam Install Video
  169. How to: Stock WGA spring mod
  170. 9 turbo in 8 request for info
  171. How to adjust low beam hid(i have the oem tilting ones)
  172. How to install these..
  173. HELP fuel injectors not sealing at fuel rail
  174. power to gauge illumination problem
  175. Request: Door Skin Replacement
  176. HKS Fuel Rail and Injector Install tips on how to do it ?
  177. Brake Rotor Replacement
  178. How to: properly use an adjustable cam gear on Evo IX
  179. HELP: Custom intake tube
  180. EVO IX Front Bumper Removal + Intercooler Install help PLEASE!!
  181. Megan exhaust fitment question...
  182. HKS SSQV bov into HKS RS air intake
  183. headlights
  184. 05 Exhaust leak
  185. Engine Start Button
  186. Time to install spring?
  187. Alignment of rear Mitsubishi Diamond badge
  188. How to make dull rims look new again?
  189. Installing a BOV
  190. Question about how to install a Greddy Turbo Timer
  191. spring install question
  192. agency power bov
  193. help!! painted headlights, now HIDs dont work
  194. Megan coilover install video
  195. SRS light kill or turn off with opensource or obd 2 scanner?
  196. Help with removal of axles for TC removal.
  197. HELP: Aeromotive Eliminator Relay
  198. How to get my openport 1.3 working with evo-scan or EcuFlash
  199. cam timing marks?
  200. AC Remove
  201. Help Engine bay appearance
  202. How can I get Cruise control on a EVO VIII GTA
  203. Greddy Turbo Timer Instal Pics/good detail
  204. jdm headlight conversion
  205. So do you need to bleed the clutch when you flush the brake fluid??
  206. Nisei Intercooler Pipe Bracket?
  207. will aps intercooler reservoir fit evo9?
  208. How to install Cusco REAR strut bar Type OS-T
  209. How to take out stock fuel pump filter
  210. Hks Eids Problems
  211. Ways to solve dp hitting tc..
  212. Start Button
  213. Buschur Deluxe FMIC install
  214. Kartboy bushings
  215. Vaccum tubes for MBC
  216. remove silver ring from steering wheel?
  217. What wire did I tap into?
  218. gsc cam install
  219. So I seriously need some help with a boost leak test
  220. Help! How to lift up the carpets of the car
  221. Help with Ultimate Racing Fuel Pressure Gauge Adapter
  222. How to Install Aquamist HFS-5
  223. Silverdale, WA Help
  224. Advice on pulling a motor
  225. Need HOW TO Help: HKS DLi 2 Ignition
  226. Help with fuel pump
  227. Evo IX Black Out Front Headlight Turning Signal?
  228. Buschur Double Pumper Install question
  229. Help with Defi-Link Control Unit II install?
  230. Best Place to Install Antenna for Alarm
  231. new ebay tbe what to do with o2 sensors
  232. Extreme trouble with pulling axles/clutch install
  233. Anyone know how to black out headlights?
  234. Fix charging system
  235. Dashboard Light help
  236. Help Installing Db gauge
  237. Steering Column Removal
  238. Greddy FMIC question???
  239. Washer Sprayer Removal?
  240. Can't get 12v from anywhere so far?? only getting like 5v or 6v!! help!!!!!
  241. Help Needed: Side Skirt Protectors
  242. Replacing oem Oil temp
  243. need JDM MR headlights on IX
  244. just installed bov noticed uncapped nipple
  245. how to remove dash????????
  246. New import tuner show premiering tonight
  247. Wanted: A-pillar boost gauge how to
  248. exhaust install
  249. Beatrush & Ralli Art CF Lip
  250. Power Steering Pump
