View Full Version : Evo How To Requests / Questions / Tips
Pages : 1 2 3 4 5 6 7 8 9 10 [11]
  1. removings the panels of the car
  2. Defi Boost Gauge Mounting
  3. Stereo wiring
  4. How the hell...
  5. autometer mech .boost gauge, help!
  6. spark plugs
  7. Wastegate by-pass
  8. Greddy Boost Gauge
  9. Need help with coil overs
  10. Vishnu cam gears
  11. Underside of throttle pedal
  12. Installing coil overs tomorrow
  13. Radio UNINSTALL....
  14. install-MBC
  15. need stuff done look here
  16. Header/Intake UN-engrish instructions.
  17. RMR 6 puck
  18. Help installing Samco radiator hose kit
  19. HKS Carbon-Ti Exhaust and AEM Short Ram Intake - questions
  20. Designing Gauges from Scratch
  21. S-AFC new users guide
  22. Greddy Turbo Timer ground wire?
  23. Definitive Guide: installing euro
  24. Exhaust gaskets question
  25. HKS Type I TT stutter...
  26. Hks Turbo Timer Type 0
  27. Having trouble with glove box
  28. Help! need to disconnect battery but sockets are with friend
  29. Hks Install??? Please help...
  30. SAFC II 94 octane settings
  31. help locating a fuse
  32. Problem after batt. relocation
  33. ? for the guys with the DIN panel gauges installed
  34. Do Not Install Ignition Harness From Emanage On Your Evo
  35. please help throw out bearing ?
  36. How to Install Aftermarket Seats
  37. B&M short shifter
  38. Deck install Question for the EVO
  39. Blitz DTT DCII Help!
  40. Evo Motorsports Tech articles
  41. Rally Strut Install
  42. o2 simulator
  43. Best results polishing stainless?
  44. Greddy harness for Turbo Timer install
  45. Front Sway Bar Install
  46. Upper intercooler pipe ideas?
  47. How To: Valentine 1 hardwire procedure
  48. Air/fuel gauge install
  49. B&B Downpipe question
  50. Cusco Oil Catch Can, HKS Racing Suction, and Custom Ground Kit Pix
  51. Debadging
  52. Tach Lead On A Shift Light
  53. Turboback installation opinion
  54. The needle on my boost gauge fell off!!!
  55. how too greddy tt
  56. Additional boost gauge
  57. how do you wire boost guage for power and ground?
  58. Gauge, vacuum hose....goes through where??
  59. Cusco oil catch can install pics
  60. Exedy Twin Disc??
  61. DEFI BF gages installed
  62. Coil Over install anybody??
  63. Instrument Cluster Needles
  64. Quick exhaust question...
  65. Seat and armrest cleaning.
  66. S-AFC II problem with throttle percentages
  67. Need Help Installing Tachometer
  68. P-Hybrid Power Boost Controller Help
  69. Help!!!! Clutch dead!
  70. HKS SSQ install help
  71. Service manual
  72. Stereo relocation instructions
  73. Boost Guage Install
  74. SS clutch line install... please post
  75. Evo 8 oil change
  76. SWAY BAR INSTALL? Need help
  77. K&N oil filter
  78. Fuel Cutoff?
  79. Buschar air filter
  80. Stealth Airbox Mod
  81. Setting front toe
  82. HKS Super Sequential Blow-off Valve Installed!!!
  83. Help plz
  84. EMERGENCY please help!
  85. E-manage Ignition/Injector install for EVO 8
  86. Custom Intercooler Screen
  87. help with CAI install
  88. installed "jdm" antenna
  89. HKS Type 0 TT
  90. Help Help
  91. AEM Intake and HKS SSQ installs
  92. Good prices on EVO rear bumper
  93. Evo VIII badges
  94. Perrin O2 simulator trouble
  95. how to remove front bumper?
  96. Removing the steering wheel column
  97. Heat Extraction
  98. Need Rim Help Fast!
  99. Article on Evo Box removal please!!!
  100. seemingly stupid question about running wires (dash/headliner)
  101. Does Anyone Have a Turbo XS RFL BOV?
  102. How do I remove the CD player
  103. another exhaust question...
  104. Car hesitating from 3-5k RPM under full boost
  105. Nova 200 Le Alarm
  106. question about exhaust installation
  107. Blow-off Valve and Boost Controller?
  108. installing air/fuel gauge
  109. built DIY grounding kits
  110. Location of high note horn?
  111. Blitz DTT contrast adjustment
  112. GREDDY TYPE S BLOW OFF VALVE, troubleshooting
  113. someone help with clutch install please!
  114. ok how do i change the clutch line
  115. adjusting headlights?
  116. Need help for HKS SAFR installation,Airflow meter type ??
  117. Evo Airbox Removal/Alert
  118. How to protect and detail your EVO inside and out.....
  119. Perrin Oil Catch Can Installation
  120. DEI 700T Alarm Installation Instructions
  121. Evo Driveline Fluid Change w/semi-useful pics (long)
  122. turbo timer with aftermarket alarm problem
  123. clutch install(how to get transfer case off without breaking anything)
  124. Turbo XS Dual Stage Boost Controller
  125. Evo Lighting
  126. boost solenoid
  127. Can someone SoCal help me with hole in firewall?
  128. manual boost controller install help
  129. JDM tailight install???
  130. Boost Gauge installers in So. Cal?
  131. Defi BF boost gauge HELP!
  132. EGT Installation (yes I already searched)
  133. How to connect an A/F gauge on EVO?
  134. What wires to tap for A/F Gauge install
  135. HKS Turbo Timer Type-1 install help
  136. Auto Timer install help
  137. Alarm Bypass???
  138. What to use to tune for HKA AFR?
  139. how do you get the mirror cover off?
  140. Turbo Timer Harness
  141. Help with Autometer Ultra Lite Boost Gauge
  142. rubber blocks holding front springs
  143. GReddy Turbo Timer install guide
  144. How to change gauge color from red to blue???
  145. How to remove front bumper?
  146. valentine one install
  147. Has anyone taken out the clock yet???
  148. Evo8 Alarm install...help
  149. importance of vacuum indicator in BOOST Gauge?
  150. grounding kit
  151. Hood vent removal
  152. How many hours to install?
  153. HELP!~ Greedy Turbo Timer w/ Harness
  154. Instrument Cluster Surround
  155. Links to cam install instructions?
  156. In dash changer/gauge install ?
  157. Apex-I AVC-R Install W/Pics
  158. Greddy Profec e-01 install help please!
  159. Anyone In LA have done the grounding kits?
  160. Downpipe install?
  161. Accurate AFC Install neede. Tried search
  162. Apexi tt wire hook up w/ pics
  163. How to install ralliart pedals
  164. DIY Ground Kit for $20
  165. Evo ECU Removal
  166. oil/ air fuel install pics
  167. Evo 8 e-manage install v-faq
  168. Japanese Instruction Translation
  169. Greddy turbo timer
  170. Air/Fuel Gauge Install
  171. Install: Perrin Short Shifter (pics)
  172. HKS Cams Install
  173. Removing the stock emblem...
  174. Revised JIC EXHaust Install (RMR and Perrin as well..)
  175. Few questions about Blitz TT install
  176. Turbo XS RFL Install
  177. apex-i AVC-R install
  178. Perrin short shifer pics?
  179. CF gauge pod progress
  180. Sparco Pedals
  181. How-to: RMR Downpipe and Brace install
  182. A'PEXi auto timer install
  183. Smoked evo tail lights
  184. HU decoy??
  185. Lineage Ground Wire Kit
  186. Manual Boost Controller Install
  187. oil pressure gauge/air Fuel gauge
  188. How to remove the Evo A-Pillar?
  189. Grounding Kit Installation
  190. ground wire kit
  191. WRX WALBRO fuel pump install into EVO - easy
  192. Tranny flush and fluid change
  193. Anybody with an HKS TT Type 1 can help me?
  194. Somebody answer this quickly please
  195. B&M Short Shifter install ++++
  196. How To - Use Toluene to boost your octane
  197. HKS Type 1 Install w/HKS harness...
  198. Blitz SBC-iD EBC install!!!!!
  199. Lightweight battery install on EVO VIII
  200. Will cold air induction kit improve the bogging?
  201. 2 New Steps to Project Vivid EVO Added!!!
  202. How To Relocate The Sports Meter Kit/Replace Factory Stereo
  203. Brake pad installation directions?
  204. How to change stock radio backlight color
  205. oil changes
  206. How to change climate control backlight color
  207. Tons Of EVO Installs and Reviews
  208. Simple front camber increase
  209. Boost Gauge Install
  210. Hardwire V1 to sunroof/lights?Has
  211. Buschur Exhaust Install on EVO VIII
  212. HKS SSQV blow-off valve install documented!
  213. Clutch job on my Evo 5...Same as in 4 & 6
