- How to tighten gas pedal?
- Yellow HID's
- stockkk ecu?
- stock ecuuu help
- Is there a trick to wiring the defi D egt?
- Evo 8 stuggling at wot, and poping
- ecu?
- CLUTCH Issues..... :/
- Finally, i have evertyhing i need. Pics :)
- bulbs
- Grinding Sound on the Passenger Rear?
- Buschur Race FMIC
- Revised Interesting Poll!!
- AEM wide band gauge not working?
- One headlight dimmer than the other.
- 10hr journey in the morning
- do i need a retune?
- CEL pops on and goes away.. no DTEC displayed
- Tranny and diff fluids..
- Anyone used a Bosh universal O2 sensor?
- fog light trouble
- SES light came on during acceleration?
- Question about the Apexi Intake
- Need a new Radiator for my 03 Evo which should I get?
- Where to buy timing belt stuff?
- SE Lip with Beatrush Undertray
- Evo as daily driver
- how to dissamble a evo ix rear spoiler
- Evo 8 vs evo 9 turbo
- Window glass interchangable with the regular Lancer?
- Drive by wire??
- How much do Used Evo 8 seats go for normally?
- Help with BEATHRUSH Front plate installation...
- After my long trip clutch fails and now wont start?
- Ceramic coating and heat extraction coating of parts
- IF you ordered something and it came damaged.......
- Where to buy Precision Turbo's?
- This doesn't sound good....
- Defi bright/dim - is this normal?
- Vortex Generator Install Question (Bracket Needed?)
- Ditching my wing!!! Do regular Lancer trunks fit?
- Buying A Evo 9 (FOG LIGHTS)!!!!!!!!
- Looking for opinions for EVO chips
- Best Wideband
- distance from head to stock rad fan
- EVO IX film case care
- gauge ?
- Fog lights only come on when high beams are on...is this normal
- Nitto NT05 Review [Modified Magazine]
- What do you guys use to fill up T case fluid? Im looking for 1 easy to use/not messy!
- help please!
- Where do I find Recaro Material??
- WHat is the torque specs for intake manifold....I have a bad vacuum leak
- Evo 7 vs british army (funny and painful)
- 20g and 02 housing
- help stutter after shifting
- Need Some Help
- Is a MR worth it?
- fixing scratches on a ARC shift knob
- plugs
- TB Pics??
- headlightt?
- A Puddle in my car...
- Style on the hood
- 30K Help
- OVerboosting with very little throttle input
- Evo X MR shift knob
- Blitz SBC i-d boost controller question?
- Need part# for diaqueen please!!
- Leaking Samco Radiator Hoses on my Evo VIII
- Need Help with decision
- Defi D-Gauge oil pressure sensor help
- Electric Issue - Minor..
- fog lights question and opinions needed
- scraping going up driveway
- Installing an Electronic Boost Controller.
- 1DIN In dash with relocation kit.. clearance??
- who has the ---------- for sale
- Evo Crash
- Cigarrette Lighter Push Start
- How to get 500whp/500wtq?????!!!
- Problem with aftermarket HID conversion kit.
- Where could my short be?
- stock injector impedance ?
- What to do with third gauge pod... ideas or leads please.
- My car needs to go on a diet
- Cracked oem front lip
- US vs. UK
- HELP! Fighting with Mitsu *WARRANTY*
- Power steering removal questions...safe???
- Website That Has Evo VII Parts Manuals Online?
- Question: Nisei Mini battery tray
- Dealer abused my evo, help..
- How do I recalibrate/reset my BISS?
- part number request
- Pinout on harness that connects to the fuel pump
- Where has evopowermods been?
- Thinking about Buying an EVO Again!!
- May have been played on car purchase.
- 2.3+hta35r+twinscroll
- E85 guys oil question
- Imput
- OEM vs Aftermarket
- Prosport Wideband
- Evo/Import Drag Racing DVD's
- Dealer raped me!
- No pick-up in acceleration?
- Lancer windshield same as Lancer Evo 8 windshield?
- Loud Noise From front right Wheel well
- 8ball shifter
- screeches while reversing and turning wheel?..
- valve cover issue
- Putting car down for 7months
- possible to fit trunk in back seat?
- Running two fuel lines from the Double Pump
- A few gauge questions
- AEM Wideband gauge response delay
- where to get Brembo brake caliper stickers?
- Vandalism ftl..
- when you dont have your Evo...
- oil leak cant find any help or advice...
- new clutch YAY, now onto another problem... BOO!!
- Help With Defi Oil Pressure Gauge Wire
- CPR Car Planet Racing World First Twin Turbo'd Mitsubishi Evo 9 RS
- Need some help with maintenance issues
- EvoM Decal
- 115mm silencer?
- Beatrush fitment question with AMS FMIC and Piping
- Where is the crank sensor located?
- Key Hard To Remove From Ignition
- Painting Intercooler Bad?
- moonroof rust?
- Need help with driveability issue
- JDM Evos and well everything else.
- water or meth or alcohol?
- Broken seat side
- Exhaust Wraps
- VIII going to green
- Intermittent starting issues
- Wing nuts and bolt sizes
- Evo Insurance Question ...
- Front Bumper?
- evo turbo in a eagle talon
- HUGE boost leak, only high rpms
- Keyless remote
- Circuit breaker AMP recommendation?
- Aftermarket Parts for Evo VIII
- Tire Comparison: Nitto Invo vs. Nitto NT05 vs. Nitto NT01
- Spark plug wires for an EVO IX???
- NO check engine light
- quick help with gauge problem
- Quick answer about a test pipe
- Anyone using this digital boost gauge?
- AEM Tru-Boost Electronic GAUGE Type CONTROLLER
- gauge mount taking down questions
- Suction or return hose?
- Trunk Hinge cables? Not sure if routed correctly.
- Did anyone get a flyer in the mail for a complimentary oil change from Mitsubishi???
- 2 Step Launch Control
- Vent on Cold Turns the A/C on?
- Does this sound right?
- HID Ballast
- Not sure if this is the right fourm but how much is shipping seats normally
- mounting gauges?
- How many TME RS's did Mitsubishi officailly produce?
- Connect LC-1 to SBC i-color
- tune passing smog?
- ? about Aem Wideband replacement
- AC Issue - HELP
- FP Red turn around times
- Driverside headlight mod?
- Lighting Issues.
- evo mr oem gauge plug for oil temp sensor.
- question about undertray
- How to differences between Evo 8 and 9 tails (painted)
- anyone know how to remove EVO8 FRONT FLOOR CONSOLE COVER?
- Bride, Sparco, All expensive JDM seats....r they worth it?
- Passenger side headlight moves by itself?
- Water Leak, Need opinions please...
- missing parts
- Clutch issue, dealership A-holes, and a rant...
- dvd Screen Gauges
- Egg on my car...
- do 03 evos have cruise control modules?
- silly newb color question
- How do you take the steering wheel off?
- 350hp
- Yellow on White????
- Help wilth part # please
- Tint
- would you buy a salvage evo
- Injen Intake
- Fq-400
- Need help: Bought some parts from members in here
- Strange Noise From Under Car
- Exposed rear speakers [pic request]
- Ecu?
- lancer starter on a EVO
- A Present?
- Where is the ABS fuse?
- Weight Vs H.P
- Crazy battery setup!
- emp o2 dump?
- Need Solution For Bumper
- Is it possible to install ayc on a ix?
- help, getting toyed with by the dealer
- ABS Light & No Heater Blower
- SES light on, and then off again?
- Greddy Turbo Timer in Stock Clock Location?
- 400whp or bust
- Optilux 55w 12v yellow bulbs?
- WHY does my evo shut off when the AC's on!
- Ebc
- New Idea for the Antenna
- help car just shut off
- Helpppp! Fmlll
- Someone smashed my tail light
- cluster problem
- Overreved
- Will a turbo timer damage a Wideband?
- HELP driving in 4th and car started to sputter!!
- Bearings Balance& oil pump
- where can I run the wires thu the firewall for my gauges?
- help please anybody
- Get better MPG
- My Thread Was Unworthy!
- HKS TYPE-1 (something went wrong)
- Exhaust questions
- Man down.. evo down
- evom decal install ??
- XS Engineering Exhaust
- Crank position sensor isues
- JDP Carbon Center Console
- 60,000 Service - how critical?
- launch control?
- now oil change is even cheaper!
- Gauges quiestion
- fixing a boost leak
- so my evo flooded
- Is this rear damage repairable?
- EVO 8 2003 vs EVO8 2005
- "knock" sound from right-rear?
- Weird Issues with IX
- New to site, my FP Red setup almost complete
- evo FTW!!
- Auto transport
- Bozz Speed lowered seat rails
- after gas fill up, she doesn't want to start
- *Unveiled* Pioneer AVIC - U, AVIC - X and AVIC - Z Car Navigation
- Any interest in seat locks for the Evo?
