- reserve tank??warning light??
- Vendors w/ JIC FLT A2 in stock?
- Buschur Racing slippery is fast, more aero stuff
- Ballast: where can I source this ???
- Small nick on 10.5 turbine housing. Will it be an issue?
- 10.5 hotside/o2 housing question
- Adjustable FPR for Perrin fuel rail...
- 90K - What would you do?
- Weapon R Street Intake Manifold
- tuned with cat putting in testpipe....
- How do you mount your Braille B106?
- In Japan, buying Evo when I get back to states. What to get here?
- why does my car run so hot?
- Schroth Rally 4 harness
- blitz fatt dc iv tt harness for evo 9
- A couple of wierd questions..........
- Would i fit into a bride zeta III seat?
- mileage
- Lowered Cars your defense against scraping all over the place
- Sema 2007
- Need help with motor
- just ordered
- Vibrations
- Evo X
- lawsuit in process
- Cool Mitsu Stuff from Frankfurt Auto Show
- ss braided turbo lines
- MAF Sensor Orientation
- EVO X video + review on Edmunds.com
- A way to improve side crash rating?
- Crash beam for JDM IX rear.
- New Way to lower your lancer
- Shop put tranny oil in my t case
- apexi turbo timer help!?!
- Black valve cover?
- Online Photo Gallery of Tuner Shootout 07
- Clutch finally slipping =/
- trunk holes on rs
- Gsc s1 cams or HKS 272? i cant make up my mind.
- Need help finding the right gauge mount!
- I pwned myself....tuning technologies
- immobilizer help
- Why is this ??
- quick question....
- I need a part number for the sunroof seal, anybody know where I could get it?
- How long does it take to change Trans fluid, TC fluid, and Rear Differential Fluid?
- Those with Tanabe DP's....
- stock a-pillar for evo IX
- EVO 8 vs. Lamborghini Murcielago.. Whos the best???
- Taper to 13psi stock?
- What mirrors are these and where can I get them?
- coolant temp gauge vs aem ems
- how bout that new...
- MR air dam no longer availible???
- Can you tell..?
- Thinking about an EVO.... lil help please
- anti fouler mod and ebay turbo xs tbe question
- what ignition to get???
- Engine Oil Suggestions??!?
- Need advice for EVO 8
- ARP head Studs/ gasket
- new sti or evo x
- Anyone ever buy anything from HopUp racing?
- Minor issue with installing fuel pump
- Can I install my fuel pump with a full tank of gas?
- LS1 in an Evo...
- What should i be running
- Windshield repair.
- CEL problem
- This happen to anybody??
- Cil problem
- Which great Exhaust to go with?
- Climate Control Mechanism and Keyless Entry Q's
- Wheel selection help for a GG MR
- Attn evom: ForgivenEvo poss SCAMMER
- evo9 headlights
- Reliability of an Evo
- EVO or RSX Type S? Why?
- heat sheild 4 megan ex man?
- Prosport Gauges?!
- carbon fiber doors
- autometer dash pod
- in-dash head unit?
- Idleing at 925-950ish stock evo 8
- air/fuel
- MBC help..
- DO NOT SCRUB YOUR MANIFOLD COVERs
- ABS/Anti Lock and ACD on
- I Need A Roll Cage Where Can I Get One
- For those with sheet metal intakes?
- Boost leak test, out of all places...
- hard intake pipe with stock airbox
- Project EVO RALLY CAR!
- torque
- Evo to NSX? What to do?
- o2 Housing Poll!!
- Where to get this part?
- o2 Sensor Plug Picture
- Any Brand New 2006 Evo MR's still available ???
- shifter cable bushing install?
- Jdm rear bumper part number
- Evo 8.5 is a success!
- ebay special...
- greddy profec 2 ?
- my new mods
- should i buy it???????? 2003 evo
- a friend...a racer...a ricer
- Need '06 RS VIN to buy RS Trunklid and Springs, can anyone help?
- Need help on ?
- Does anyone have the Cry02?
- maintenance
- shift problems
- Headlight question
- reusing Diaqueen
- JDM MR headlight question
- Non car enthusiast reviews evo 9 MR
- Quick Q on engine dies on idle.
- Oil Filter
- Evo Dies on Start up in the am
- Forge MBC
- oil filter
- hey a quick question
- Prolly a NEWB question...
- small accident, have question
- What's your experience with TopLevelPerformance?
- Evo WRC v. prepped S2000
- Evo IX Cel Fix Didn't Work
- Attention Frank Extremeboost NOT HAPPY
- pic/link/info request: custom seat brackets
- Evolution community(long)
- Drivability Issues
- Whining since boost gauge install?
- Quick Help on Fuses
- Starting to get upset with the evo..
- Clutch????
- is there any way to shut of the rear o2 sensor?
- Slow Turbo Spool?
- K&N drop in filter
- ethanol question
- Rumor: Warranty is honored early in the month
- question about t-case fluids.
- o2 Housing Install
- evo dave
- New Numbers!
- Mitsu Galant Evo Head
- *Replica* Carbon/FRP High Mount Rear Spoiler Base (coming soon)
- JDM ecu map vs US map
- Starting to go realllly worried help
- evo dave
- should i switch up my tune for winter??
- Hairspray for LICP?!?!
- price question
- Need quick answer: STOCK IGNITION INSTALLATION
- Help finding part number...
- Which One To Get?????
- Downforce Comparison.
- Question: Dependability of evo compared to Audi S4
- 2007 nopi nationals my evo lap around the atlanta motor speedway
- Rear windshields
- Intake and Intercooler Pipes CARB Exempted?
- Aero work, undertrays and misc looking for opinions
- Problems with Zeitronix and ZAVT
- Need help purchasing tactrix cable and stuff
- HP calculator
- megan tbe clearance issue
- Whine.
- New Evo, cracked window, help??
- Sports Meter Gauge Kit
- Car Won't Start...
- Which drop in filter?
- Help with seatbelt unlocking.
- electronic boost gauge problem
- Injen Intake w/ Different Brand IC Pipes Void CARB?
- ROAD/RACE-Carbontrix IT Cover
- Nopi 2007 2nd place
- Preston with the Yellow Evo
- Thinking of buying this evo need help take a look at the engine bay
- What's the going rate for...........
- Aftermarket intake on Evo?
- Anyone used a windshield repair kit?
- I need help
- is 400 hp possible without...
- Transmission FLuid Help
- Water/rain causing open door light to stay lit.....
- Reichen and his EVO 2 break more records out at The Sllver State Classic
- some question
- turn the boost
- Changing exhaust manifold
- P0248?!?
- Your Ultimate/Dream set-up...
- Bushur gauge pod
- New BR dyno #'s.
- Aftermarket Downpipes Street Legal
- Sti transmission vs evo transmission
- HELP w/ EVO 9 MR =New parts?=
- Need help choosing an aftermarket racing seat
- Can A CB3 lancer Be Converted to a EVO III ?????
- Blinker bulb part #
- Carbon fiber buper shield
- Fair price?
- should i worry
- Question to those with Fuel Pressure Gages
- Alternator issue
- bought the special...
- My evo 8 hp numbers and dyno chart
- heater cable broke?????
- 6-speed shifter bushings
- I need HELP! Anybody have pics of their HKS Hi POWER?
- EGT probe in exhaust manifold California smog legal?
- Best MBC?
- foglight installation = pain
- Possible apexi timer problem?
- IX front bumper OEM license plate holder
- Most accurate readings
- Evo Vandalized for the 3rd Time
- Our cars are just awesome....
- [HELP] Problem @ 3000rpms
- codes p0136 and p0141
- Whats that black stuff?
- headlight housing paint
- Headlights
- Took off wing to find....RUST
- SE lip?
- AEM UEGO reads full lean sometimes
- Buschur Racing O2 Housing
- Stolen badges?
- Anyone have a block heater?
- wtf is this noise?
- Front Bumper Lip, '06 IX... Falling Off?
- good way to get oil out of exhaust?
- Our (non-HID) Healights Blow
- HVAC Issue's!
- Evo 9 bumper?
- Evo9 swap Pix's
- Massive Grinding Noise from Right/Rear Passenger Side of the car. Help?
- Is Tanabe "Concept G Blue" exhaust too loud for a DD?
- Questions Info Plz
- Who's Going To The Re-dsm Shootout?
- Rest In Peace Colin McRae.
- tranny warranty?
- Greddy Ti-C Silencer Removal
- confused on some terminology and a ?
- 430hp Mitsubishi Evo IX by Jyuichi Wakisaka in Tsukuba
- JDM MR bulbs Types
- Subaru P1 and Evo 6 video
- 6 Speed MR vs. 5 Speed RS
- flywheel....
- Help!! Something always goes wrong during my installs!!
- Weather influence
- Lookinh for a clutch
