- +++ CHEAP HELMETS or hOOK UPS??+++
- Should I Get Rid Of The Viii For A X
- Need help
- Where to tuck away rear O2 sensor wire after TBE install?
- Fog Lights don't work, help!
- Help with pricing
- Help tranny drain plug
- 20 amp fuse for engine
- Gap Insurance - Bad Credit question(s).
- Removing Door Handles..... !!!! Help Help
- NASA northeast Pocono race weekend
- Need help or advice ASAP
- Mini Battery
- Anyone know how to get better gas mileage?
- which CAT will work?
- Greddy e-manage Ultimate
- 1$ For 1Quart (Royal Purple)
- Installing aftermarket horns?
- Question About HKS Intake
- Help Please!! Bulb, SRS, CEL???
- question ne3d help
- Has anyone put the SSL sub in a non SSL car?
- Warrenty problem
- stud and bolt spinning....
- Heat from AC vents
- Help, Evo IX front bumper on VIII
- evo viii- good deal???
- removing stock muffler?
- Sunroof issues
- Drill a hole in the wastegate...
- Quick Question before i order an A pillar
- Ohlins IX vs Ohlins X (video)
- Random Mifire Code!! Please Helpp!!
- New to Now...my Evo IX MR (video)
- Turbo kits?
- Evo Windshield Change to Lancer?
- EVO 9 (light weight mod)
- 10% ethanol good or bad?
- Hello from Koyorad!
- Talk About Making Evo IX The Lightest Possible
- Greddy E-management Ultimate
- Extreme Motorsports 10 sec Street Car
- MR Oil Drain Plug
- A few questions on what i should do next...
- 2005 evo 8 stock boost? Default setting?
- boost set
- A sad thing to see (in the uk)
- Ticking - Please help me diag.
- Help with cluster
- Gt4067r ###
- Time to buy a catch can.... dc3 seems to be the best?
- Help electical problem
- Wow bright lights, Cool Colors! (pictastic thread)
- need help bought a autometer gauge
- Super Lightweight Evo 9
- 06 evo mr oil change
- Suggestions / Car Cover
- TB seals again
- Got new GSCs1 today but came with no paper work?
- what the heck
- air intake problem
- Stock intake
- how do you refill t-case & trans?
- need help finding boost gauge
- Use of a wideband
- can this work
- what coolant do you guys use???
- Car stuttering between hard shifts
- TBE and Intake void warranty???
- really rich in higher rpms
- how much should it cost to port and polish
- Exhaust question?
- IC Pipe issue!
- Jesse's 42R Powered Beast Makes 939 All Wheel Horsepower @ AMS
- Evo 8 fuel pump
- should i trade my evo 8 for an IS-F?
- New Evo8 owner...need help fast.....
- re-arranging center console
- JDM IX front bumper
- The $50 Beatrush Under Panel
- Need a receipt from a company that is no longer in business (logic performance)
- Misfire !!!
- Race Gas Difference
- Advan RS Paint
- Emissions Please help!
- Time for your HELP
- help!!! turbo XS
- Tein lowering springs?
- Sparco Seats
- Right Hand Drive
- stock exhaust too loud
- Weird Sound
- Evo 9 shifter knob sticker
- Water inside my intercooler?
- The Official AMS Open House Picture Thread!!!!
- Rally race coming up soon
- Question about Evo IX
- Buschur Racing Shoot out... who is going?
- Evo 8
- Bad Cam Sensor
- OBX intercooler??
- VSS Wire Location/Color
- Topspeed In Georgia?
- Sneak peak at another Evo drag car!!!!!!!!
- what kind of dyno does ivey use
- Wierd shift light
- when to turn the mbc down?
- Bulbs for Tac Gauges
- Oil Filters?
- vortex GENERATOR question
- Where did you search for your Evo?
- Does anybody know where my thread about IX hitting 13.2 went?
- Fake or Real Carbon Fiber??
- ams intercooler
- Does anyone know where I can buy these...
- Need help! - Installed Gauges - Where do I wire lights?
- HELP!! a/c on= crazy idle!
- Car won't start
- Evolution Owners: Who Does Their Own Work?
- Results of not using proper fuel?
- Replacing down pipe&muffler
- Safe boost leve for a stock internal EVO 8
- mr grill emblem
- how much power?????
- Pruven Performance / BR Baby Mobile
- Is Rally Red the same exact paint used on Evo8, 9, and 10?
- scratches on my rear window
- RPM's stay high with clutch in!?!
- Buschur Air Intake Help
- New to Evo's
- check engine light on, how to use evo scan to get a code?
- Fake Walbro Fuel Pumps!!!
- any high hp high mileage evo's out there?
- Vent next to ignition
- RPM Question
- just got my evo, ive got some questions!
- Horn Doesn't Work + SRS Light Is On
- oem oil temp gauge not working
- Best New Magazine for Evo's
- Turbo System
- need help sourcing ev0 8 fabric
- Hood Grill for Seibon OEM hood
- SRS Light Turned On After Clutch Install
- how to quote someone in thread
- Fq-400
- Comments on Ralliart Din-Gauge
- Evo 9 Maf Signal Wire
- Need some help and advice ASAP! please :) (92 JDM EVO info)
- Buying EVO9 need opinions
- Do you wave at other Evo drivers?
- Looking forward to the NEXT 50,000!!
- who has the UK IX chrome badge in stock
- whats the evo 9 non-hid headlight bulb???? H?
- Do You Name Your EVO
- Greddy Profec b spec II install question?
- please help ..ECU usb wire to laptop
- windshield weight?
- can it hold up to the test
- Check Engine Light Code
- What moves you!?!
- Used 8 & 9 Evo Prices Rising
- Quick Tips to help deaden the outside sounds
- 2005 evo rs
- Tbe & Boost Vac
- anyone see the EVO 7 on ebay?
- Upper Intercooler Piping
- need help fast....LICP
- should i buy from private party or the "dealership"??
- Megan Racing header Gasket fitment help
- Heat smells like feet???
- Help, car wont start
- pic request
- towing
- Evo - Future Collector Car?
- new turbo
- Wierd creaking noise..
- Throttle hang caused because of increased idle?
- Traded in EVO8, Bought a Vette and now want an EVO9 instead.
- Need to know.....
- Will an X knob fit on an Evo 8?
- High Zinc Formula AMSoil?
- is it normal for checkengine light to go on w/hfc
- AC Condenser Evo 8
- EVO VII paintjobs clear coated?
- Replacing Rubber Boot On Lower Control Arm
- How To Replace Rubber Boot On Outer Tie Rod?
- Lancershop.com ??
- Tranny Drain/Fill Bolts Location
- Should you?
- Finally
- ATP intercooler pipe Q?
- Where to Buy FPR Adapter for AM Fuel Rail
- Slower?
- plugging holes in trunk with wing removed
- Huge person seat&harness question
- Code Reader "No Link"
- Seibon CF Trunk: Release Cable Routing
- Decisions!...What EVO do you prefer?
- Where can i buy 3" gaskets for a DP?
- To/Not to install MR roof???...How lighter is the MR roof from GSR roof w/ sunroof?
- Two Step
- Opinions on which Rear Badge to mount on the trunk....
- Beware of improper mounting, Please help
- touch-up paint pen
- ok i just put my perrin tbe on and....
- Help Me Remove Steering Links!
- Mellon tuning in a Hotrod Mag video
- First evo and some questions
- car broke down
- Cams
- weds sport wheels
- Car smells after rain...
- Prosport boost gauge not working anymore :(
- is it worth it trading the evo for...........
- The evo is taking a S*** on me
- alittle puzzled...
- TB Evo...Chrome Advan RS or GTR face?
- maintenance schedule
- SES light is on again w/ 300 code
- AEM TrueBoost - Is it worth it..?
- Check out my vid
- Is over 80 healthy?
- autometer boost guages
- Removing Driver Side Axle on an 06 Evo?
- Sand in the tranny!
- Where to Get a used shortblock?
- help with decision
- running way too rich...help.
- For those that have priced 8 and 9 front bumpers
- Worst Experiance Ever.
- So yeah... pics and story of how my Evo died!!! (THIS WILL BE A 1ST)
- Guess what I'll run...
- Radiator Support???
- hand brake light coming on while driving!!????
- Gains from a test pipe?
- Help Transmission removal
- Victory!!
- Slow car, strange fuel trims?
- Walbro again... i Know, Quick question though...
- TB Seals again
- What's the most rediculous comment you've ever received about your car?...3rd time!
- mustang dyno settings
- do i need a tactrix cable??
- Choice of widebands
- lets play a little game
- evo retro-fit!!
- Mitsu CAPS Program
- What FPR are you guys using with the AP fuel rail?
