- 2008 importfest in T.O?
- Improving gas mileage
- Driver Side HID and Headlight leveler not working
- After walbro 255 lph, what does come next???
- My dyno tune results...
- Very odd...
- CEL logging software.
- Mike Reichen / Devo Tuning @ The Maxton Mile, 4.6.08
- What The Hell!!!
- Guess the power! Speedo vid
- Clutch question....?
- AEM Wideband Sensor
- fix-it ticket
- WORKS croxx plate fit?
- Revers lights help.
- Bad News After Installs!
- Hypothetical question about warranty...
- Looking for lightweight
- Check out these gauges by PLX Devices
- 45mm Gauge pod...
- Trunk lock won't turn
- B&M short shifter PPL help!
- Driving with four wheel studs/ lugs...
- Does modding...
- check engine after stage 2 buschur
- Someone has stolen Acd pump from my car
- silencer removal on exhaust???
- Best place to ship front bumper through?
- 05 MR turbo vs Evo9 turbo q.
- Boost Gauge is off? Boost logging?
- Bad Valve Seal? Low Efficiency
- Rev limiter question
- Me and My Black head light Job
- HID Problem help please
- Who went to englishtown on wednesday and got some videos?
- Anyone cart their toddler around in their Evo?
- Looking for an Evo 9 MR
- hi everybody
- evo 8 2003 , wiring help
- I need a front plate holder for my EVO 8
- Air temperature from turbo to IC question
- Help: Evo + Rain = wet passenger floor
- Can Faulty Spark Plugs Trigger SES Light?
- AMS in the media...
- car boost problem
- nisei lower ic pipe and motiongarage??
- Excited about attending my first evo meet
- 03 Evo boredom ideas??
- Resale Value varies!?
- Should WORKS warranty my turbo?
- questions about weight saving for drag racing.
- Under Hood Shifter Bushing Kit For 06 Evo IX MR?
- Apexi intake filter. DTM tune. +36 whp, Mustang Dyno
- Size Of Stock Guages
- Has Mitsubishi made the same mistake again
- track and temperature and other concerns
- Best AMS turbo kit?????
- how can i replace my o2 with my plx wideband?
- The AMS Time Attack EVO “TA1” is back and ready to kick some butt!
- do i have everything
- I need some help in deciding on a turbo
- Help! Nasty sulfur-like smell in my cabin air system
- Lightest USDM EVO chasis?
- Does this Evo check out?
- Painted Headlights
- is this to much?
- Need Help Guage Relocate
- JDM Headlight for an IX RS
- Evolution Manual
- Oil Pressure Gauge problem
- Quick Question, Quick Answer
- Flywheel Bolts stuck
- invidia n1
- I'm sorry ahead of time...
- need some advice
- Defi Red Racer not performing closing mode
- Wheels & Tires
- Huge car meet in New Orleans
- maf problems
- fq 400 and other evos stolen
- dyno numbers???????????
- Raising Boost after Road Tune
- Hey Guys Need Help
- Installed my rally shift indicator
- get them to warranty it?
- Need help from you guys on buying my first EVO!
- Quick IX Question
- Warm Climate ?'s
- Modding Exhaust
- How much would my evo be worth with slight front end damage that has been repaired an
- Front lip clearance?
- Ready For Next Big Mod!!!!
- Help Please
- Boost leak????
- Installed LED tail light bulbs, now getting all 3 ACD lights lighting up solid.
- Widebands & evoscan
- How much is it to get a key made???
- Lower RPM after putting aftermarket BOV!!
- WW problems with Evo IX?
- Which gasket to use with aftermarket o2 housing?
- Headlight question
- quick question??
- used tru boost ok?
- Any advice on removing this part? (pics)
- $8000 evo
- Think you guys have warranty?? Look at this
- Bored, question stumping thread.
- transmission capacity
- did anyone get "on time" when they bought their car ?
- sorry need info
- Dyno And Reflash Results!
- ok. i took my car to the dealership they dont know whats wrong with it.
- Evo won't start!!!... HELP!
- 4G93GSR CM5A with 4WD stuffs from Evo 4
- Car is stalling Help please
- Engine Sound in Evo 8 and Evo 9
- Cams...too much??
- Evo Scam???:: Houston Texas:: 8k Evo
- Info card numbers
- 60mm air/fuel ratio gauge?
- Vendors: Aem Oil pressure gauge
- Is This Car Too Good To Be True?
- READ IMPORTANT FOR YOUR SAFETY : SRS Light - $1500+ part
- is a 50/50 bov bad?
- Adjust door gap?
- Another member taking money and not sending goods
- Tuningtechnologies on the front cover of Dsport magazine
- Borrowed?
- EvoDave?
- Front and rear oxygen sensor differences??
- Rims for evo
- Rims for evo
- What would you do?
- Upgrading to a REAL car
- Vishnu's Xflash or Tomei's Exhaust manifold+dwnpipe!? Need help!!
- HELP, Question about headlight
- Flow rates on PCV system
- Evo 9 MR SE How many are out there
- money for mods!!
- rim of the world????
- Non-evo drivers..
- Help removing Trunk Wire PLEASE
- what do you guys think? can this baby come back?
- Thank You For Saving My Life....
- Front windshield/roof trim...why can't it stick?
- Removed brake lines and blown airbags?
- Mechanical to ProSport Electronic Boost Gauge.. Problems?
- ANOTHER LF axle boot leak. WTF
- Live and Learn
- I've got a real bad problem! Help!!
- drawing a blank. maybe its a brain fart
- Greddy turbo timer
- Tried taking out pcv vavle...failure
- head off heres the damage
- Ets Or Injen
- Exhaust Issue
- Noise from right rear please help!!!!
- CBRD evo in Modified Magazine-
- Aem wideband question??
- Oil light
- Plx Dm-100 Gauge w/Lc-1 Wb??
- anyone know of a evo III bulid thread???
- need urgent help!! locked out!!
- Finally she is home
- should i get a mr?
- Video: my Evo @ Motorfest Mexico!
- Autometer question!!!
- boost leak tester?
- Spring project pics
- How to install shifter bushings?
- EVO Grease Monkeys???
- Found a Evolution IX MR
- Fuel Injectors Cleaner...Do they really work????????????
- High mileage Evos....ok to buy?
- Signal and Marker lamp blubs replacement?
- What should I ask for this 500HP race motor?
- 411.68 WHP Stock Turbo Race Gas w/QTP cutout
- Inner Rear Spash Guard Question???
- Intercooler are Intercooler Right?
- Evo IX with stock MR HIDs, want to change bulbs...
- Injector size question
- Question about Oil Catch Can
- plug wires?
- Quest for 9's... Buschur Racing FTMFW!
- running 275s on 9.5
- 91 Octane
- Megan Track Coilovers Issue
- Is it possible to decrease our turning radius?
- So what would you do if this happened to your EVO?
- 'Click' under dash
- Arrrrg
- Big Turbo Up Grade Help
- you know you love your evo too much when...
- Brembo Brake Paint
- All evos queit at idle?
- OEM smell
- Are Evo8 wings under warranty or is the joke on me?
- weird noise coming to stops?
- Dash Light
- Will I be ok?
- Evo7 gets beat by a skateboarder....
- UGH! Another Steering Clunk
- Taillight out...not the bulbs. Anyone know whatsup?
- 400 Whp, Help Thanks Guys!
- Front Lip for EVO VIII
- insurance fraud
- just thought you'd like to know
- Very Disapointed!!!!
- Interest tester for FOG LIGHT CIRCUT BOARDS
- Couple of questions about warranties
- What should i do first Boost Gauge Or Drop the Car??
- Keyless entry
- JDM Headlight vs US Headlight
- Spark plugs Replaces at 13,000 miles
- evo twitchy at high speeds
- compression test = uh oh
- Hitting the good ole' 1320
- Outfitting EVO Interior for Charging Gadgets
- Rear driving light fuse keep popping???
- Evo Slow...
- Car Does Not Start Anymore....
- CEL fixer???
- Car is up and running... need someone to tune this beast now
- Evo Rally video
- I need a sunroof block off
- mmmm....upgrades
- Letter from Mitsubishi...
- Good Deal???
- A-Spec titanium manifold??
- No more tein green.
- Whats The Best Internal Wastegate For The Fp Green Turbo? Fp 18psi Or Forge Wga?
- A/C Doesn't Work
- Battery removal help, quick!
- evo interior help
- speedometer
- anybody knows this type of fuel?
- *** How often do you change your spark plugs?? ***
- Is it worth putting in an aftermarket intake?
- evo ix brembo peeling?
- Red Tint to my left HID??
- Clutch smell??
- Is it worth installing Injen LICP?
- Diferences betwen EVO 9 & EVO 9 MR
- NRG Seat bracket ???
- any members have 35r vids that they can post up
- aem wideband!
- Clutch clicking sound
- Evo 9 low mileage
- Evo Stock Xenon Light replament?
- Boost guages
