- need usb cable
- UTECH launch control
- UTEC Help!
- UTEC and Tuner Pro Set Up List in Private For Sale
- M16C Experts?
- Using Tuner Pro with Evoscan
- o2 sensor
- No support for UTEC makes me sick!
- wtb tunner pro
- UTEC FS Stage 4 Parts Tuned
- utec cable
- ECUFlash load versus UTEC
- MAF sensor removal with TurboXs Utec?
- can't get a signal out of the tuner
- Utec for evo 9 Q
- Still love my UTEC!
- Good idea?
- Another Utec/Tuner for Sale
- utec for sale cheap
- WTB: TurboXS MAP Sensor
- A Few Basic Questions
- Help! Which wires which?
- 1000 cc injectors with a utec?
- How to Log A/F as volts?
- FS or WTT Turbo XS Utec
- utec
- Cheep UTEC!
- Problem...please help!
- Utec map selector for sale
- FS: UTEC, Tuner, and MAP Selector
- utech for sale in Michigan
- Any UTEc users using MAFT pro?
- A Trade My Utec For A Stock 2003 Evo 8 Ecu
- utec shuts car off?
- wtb utec cable for laptop
- utec tuner
- Fs:TurboXS Utec
- Utec 4 sale chicagoland area
- Max MAF signal with alcohol?
- utec not reading correct boost
- Captured a UTEC log - help me understand ...
- Blown Fuse in tuner
- map switch question
- utec/nitrous
- Keep BLowing Engine fuse? Help
- putting back on the utec
- Not enough boost
- fs: evo8 turboXS Utec
- A Strong Message to Turbo XS. Please help.
- FS: TXS Utec $325 shipped
- Utec with evo 9?
- 30 PSI Stock Turbo Run Data Log
- FS: Txs Utec IL
- Perrin EBCS with Utec
- Evo IX Utec
- UTEC Help Runing Rich At Idle
- Knock with 2.3 sroker Turbo XS Utec and Knock Lite
- Openecu as primary EMS with utec as secondary?
- FS: Like new turboXS Utec
- U-Tec for sale
- Speed density
- UTEC Problems
- My Utec
- spark issue?
- Utec log HELP!!!!!!!
- GM map w/pigtail and map switch
- where are you guys mounting your bosch knock sensor?
- Disabling CEL - Does it Still Register Knock???
- Just purchase use UTEC need help
- UTEC Plug-in
- tuning changes (more bolts ons)
- TurboXS Love.. Mitsulogger 1.5
- Utec or Reflash?
- hit wall while tuning last night (log attached)
- Call Out to Turbo XS to Open Source Development
- map remote switcher
- What can the utec do for me?
- Race Gas
- Just got my utec....some questions
- Anyone USE UTEC to Trigger NX Express Solenoid?
- Injector Scaling
- Boost related to temp/humidity?
- OLF Question
- High Fuel pressure due to UTEC??
- Is this a good piggyback
- Large Boost Spike
- turboxs fuel, and ignition maps
- Possible transition issues?
- Florida Tuners U-Tec
- Help, Can Anybody Help Me??
- im new to this, and i need some help to dyno my car
- anybody had turboxs dyno tune at their shop?
- First Tune - Finally!
- Formatting Issues During Logging
- Still Learning.....
- utec mac compatable??
- 02 Sensor Hookup for Tuner
- suddenly not reading O2's
- nu b q
- UCC Knock Column
- TunerPro knock light anomaly
- WTB - Used Utec Lite
- car tuning models & auto parts
- UTEC w/mapswitch & map sens on ebay, NO RESERVE!
- Issue following TurboXS tune
- Can't tune the UTEC
- UTEC on EVO 9?
- utec vs. dyno tune
- Need to design a failsafe for alcohol
- another UTEC for sale
- trying to sell UTEC with map switch
- Question about U tec anyone that knows good
- Utec with remote map switch and DTEC Map Sensor $600 shipped
- TurboXS Utec 4 sale
- Found out something really interesting today
- Problem with UTEC
- A couple questions....real quick.
- fs: tuner,map selector, map sensor
- HKS eids+ UTEC
- Used Tuner Pro Install
- Another Noob Question
- DTEC help
- maf
- utec nub question
- Utec tuners
- FS: Tuner Pro w/ VW O2 Sensor
- Open Loop Fueling always on? Need some help
- FS: utec+tuner lite
- FS: UTEC + Tuna Pro
- Newbie Utec Question
- Retiring the UTEC
- Anyone Have 2.3 Datalogs?
- so many utecs for sale...
- UTEC w/map switcher for sale..... 525 shipped
- UTEC w/acc for sale..$550 shipped
- Utec setup for sale
- Interesting Quirk
- Blowing fuse...
- Tuning for AFR's...
- UTEC problems....
- Having some probelm with knock...
- Evo-8 UTEC + Tuner Pro + extras for sale!
- Operating temp idle help...
- FS: EVO VIII UTEC w/ map switch
- Shift Light Install
- UTEC and Alcohol/Water Injection
- WTB Utec
- utec questions
- Does the Wideband need to be recalibrated after power loss ??
- Load %'s?
- another gt35R log
- Tuner Pro/Map Sensor/Shift lights for sale
- utec on evo9?
- 280 Cams, TurboXS UTEC, HKS DLI-2 & Blowthrough Meter.............
- help with MAP sensor
- GM BCS...ATTN: Malibu
- Pigtails for GM solenoid and 3 bar MAP Sensor
- Base map for MAP?
- Jr. At ICS !!!
- Current Map and Pull
- Is ECU Timing Useful?
- jun cams
- around town cruising afr's too high
- Im back!!!
- Is the utec evo specific?
- MAP sensor slow response time
- quick log of gt35R..
- Backfire after OLF upgrade?
- HELP: Need help on some codes since utec install...
- Effects of HKS DLI II or AEM TWIN FIRE on tune
- Utec for sale
- Utec tuners in washington
- WHo in colorado really knows what they're doing with utec
- UTEC or no UTEC?
- Evo IX UTEC
- Quest. to people running GM or Perrin BCS
- Car won't idle while Engine is cold!!
- Txs tuner pro questions...
- Log Time - Tune Tomorrow, Opinions wanted.
- UTEC and Tuner Pro For sale
- Boost controler issue
- UTEC for sale
- Map switch interchangability
- General UTEC questions
- FS: UTEC w/ MBC
- Help setting up UTEC
- Video Of UTEC Launch Control
- Possible ECU->UTEC "switchover" problem
- What are your knock settings at?
- WTB: Used UTEC with map selector
- UCC compatible for mac?
- Error message while loading maps
- Lean on high end?
- WTB: Used TurboXS Tuner or Tuner Pro
- CEL after injector install..
- utec questions
- WTB: Map Switch
- Timing and UTEC, where to start.
- Huge power loss
- clutch noise and the Utec?
- Which do you prefer: MAF or MAP load referencing?
- Which do you prefer: OLF or MAF-offset?
- For those running high boost
- Help with a map
- MAP sensor ?.
- DTEC-FC Anyone using one?
- Tuners in NY Area
- Tuner Lite -> UTEC - Where do I plug in the PC?
- how are u running ur alky
- UTEC Generating Bad MAF Values
- knock logging w/ utec
- Problems with UTEC
- Replacements
- fs: Turbo XS UTEC w/ Map Switch
- Video: Ever make adjustments that the UTEC didn't like?
- FS: TurboXS UTEC w/ map switch
- UTEC problems
- UCC How-to create a very base map
- DLI II - UCC datalog
- UTEC Launch Control Question
- TurboXS UTEC + Tuner for sale
- Help Please!!
- New features on Utec question
- stock afr
- ABC boost spike/taper
- start hz mapping question
- Launch control with 05s
- 280 cam question
- Help with map
- Fuzzychi- clear some space in your message box
- UTEC Map sensor- Malibu have question
- TPS changeover point for alky tune?
- Highest power output with the Utec?
- TurboXS Utec for sale
- No lift to shift w/o using launch control?
- Why do WRXs have launch AND shift RPMs??
- Any one have a MAP Sensor for sale
- Help
- TurboXS UTEC MAP Sensor for sale
- Installed UTEC, no boost.
- utec tuning
- Tuner PRO for sale
- Injector size
- Utec tuner lite wiring diagram??
- DTEC Question: can I connect the MAP
- Utec
- Is it worth getting tuned
- Which wideband o2 sensor should I get?
- high RPM misses??
