View Full Version : Turbo XS UTEC
Pages : 1 2 3 [4]
  1. Something really weird happened...
  2. Questions on my 1st datalog
  3. safe to run car like this?
  4. WORKS plus Utec
  5. *** UTEC Control Center - NEW UTEC GUI ***
  6. UTEC and Boost Controller??
  7. Tuna Pro install question
  8. Getting ready to tune
  9. want a utec?
  10. UTEC idea...may be far fetched. mmmmm
  11. Tuning idle
  12. test pipe
  13. This is my dilemma...what would u do?
  14. Some UTEC install ??
  15. UTEC seems to work!
  16. Here's one for ya, Jack.
  17. Does Map 0 bypass UTEC?
  18. Anyone here running 272's?
  19. Timing Question
  20. Prototype closed-loop boost control solenoid for UTEC
  21. tired of waiting....
  22. Gear Specific Maps ?
  23. Hesitation when running TXS stage 1 map
  24. Injectors going nuts?
  25. downpipe-tuner-o2
  26. TurboXs Customer Service
  27. UTEC to turn off my CEL?
  28. utec boost control or ebc?
  29. TurboXS DTEC
  30. Utec Launch Control
  31. Looking for a Map for my UTEC
  32. will there be a tuner sale?
  33. Connecting my UTEC to Laptop
  34. logging egt with tuner pro
  35. Open loop fueling saved my Day!
  36. Factory Fuel and Ignition Map
  37. Anyway in Tampa, FL area with UTEC like myself?
  38. GM Boost control solenoid
  39. New Feature Suggestion..
  40. display screen
  41. Fluttering boost???
  42. Utec sale Prices
  43. UTEC / TXS Tuner interaction
  44. stage 2 map
  45. any good shops in so. cali for utec install and tuning?
  46. Just got back from track with TXS stage 2
  47. Software question...problems with laptop connection. techies please :)
  48. Firmware
  49. Just got my Stage 2 in...well, almost.
  50. Sure wish the TXS boys would comment on when we can expect.....
  51. Launch Control.. how bad is it for your car, and ignition or Injector cut?
  52. running catless w/ UTEC?
  53. can utec control boost? or do u need a boost contorller?
  54. Ordered my UTEC
  55. New UTEC Firmware, PLEASE!!
  56. UTEC Knock issues.
  57. stage 2 Map....
  58. BR580, round 2
  59. Utec Maps
  60. 700cc injectors / 255lph pump
  61. Knock Detection (CEL LIGHT) Question
  62. BR580 problems
  63. wideband ?
  64. Troubleshoot my tuna problem
  65. track update - best time on new map
  66. a quick for you UTEC tuners
  67. just got back from track - ran MJ's map
  68. utec and data log ?
  69. New power graph
  70. Utec Maps
  71. made some g tech runs
  72. First run with Utec - Data Log ?'s
  73. Tuner A/F graphs
  74. MAP Sensor Driveability
  75. Utec Installed - Boost Issues - Help
  76. Max Maf Value ?
  77. TurboXS Tuner suggestions....
  78. more newbie ?'s
  79. .....map crossover bump....
  80. Utec for sale
  81. newbie UTEC questions
  82. MAP Sensor install?
  83. (Nathan)UTEC w/ MAP Sensor?
  84. how much boost are you running ?
  85. Poll How Much Boost Are You Running ?
  86. New UTEC software beta test help needed
  87. UTEC Changing maps on its own ???
  88. Proof the UTEC works
  89. Unichip
  90. EVO Utec Software Update
  91. laptop mounting???
  92. Lost boost
  93. Need some help with preliminary UTEC results
  94. UTEC compatibility?
  95. losing map sensor calibration when i save changes to map
  96. Where are the TXS guys hiding???
  97. Connection / placemnet of Wideband O2 bung
  98. UTEC vs. DYNOFLASH!!!
  99. UTEC Dashboard for PocketPC
  100. UTEC-SD v1.0.0 Now released!
  101. Post your 3rd gear DATA1 Log Pull..
  102. Release date for rev 1.4 utec firmware
  103. Data Log Lab Version 1.4.1 Available
  104. UTEC Map Yields 279whp on Buschur Stage 1
  105. UTEC vs. EXEDE
  106. Hey Jack, hows that new MAF sensor???
  107. Map sensor, and load reference
  108. UTEC Digital Dash ALPHA RELEASE!
  109. What exactly is injector scaleing
  110. UTEC Makes Horsepower...
  111. Is utec appropriate for me?
  112. closed or open loop idle
  113. Check Engine Light
  114. went to Dyno-comp on saturday. Results.
  115. satisfied with your UTEC?
  116. next stage of maps
  117. next level of mods
  118. 1st dyno after tuning with UTEC
  119. TurboXS Downpipe Help
  120. HELP !! utec won't accept changes to basic MAPS
  121. Question concerning my UTEC log.....
  122. Data Log Labs users (and My evo's HP)
  123. MalibuJack
  124. Quick question
  125. Thread -O- Maps (post 'em here)
  126. Got my UTEC today!!! anyone have any air intake recomondations?
  127. Knock and Boost Creep
  128. Can Utec be used to log base fuel and ignition maps ?
  129. Open Loop Fuel Control?!? Soon?
  130. you wont believe what i did with my UTEC
  131. Utec & Pruven
  132. Tuna installed
  133. question for utec users
  134. UTEC passing emmisions
  135. boy, this tuning thing is getting interesting....
  136. knock detection, stock ecu VS utec
  137. Very minor bug in TXS Tuner interface
  138. Normal AFR's
  139. TUNA w/ knock sensor and UTEC MAP Sensor INSTALLED
  140. MAF calibration question
  141. looking for a reflash
  142. Stand Alone?
  143. New UTEC user with rpm scale question
  144. Is my Innovative Wideband compatible with the UTEC??
  145. UTEC for Evo 5?
  146. Data Log Lab Beta Testers Required
  147. Anyone Elses car do this with the UTEC? (Pics inside)
  148. Knock counts @ 4500-5300 rpm
  149. My first datalog, can someone explain the funkiness?
  150. Wrx Utec!
  151. what gives?
  152. MAP Sensor
  153. AutoLogger. Another utec logging software.
  154. I need Datalog files
  155. UTEC + Flash?
  156. Sold on UTEC
  157. data log minus typhoon original settings
  158. took off my Typhoon and re-installed stock intake
  159. MalibuJack's UTEC DigitalDash
  160. Newbie friendly??
  161. Why no Load Site 100?
  162. water injection
  163. GUI based playback program
  164. Something's wrong.
  165. my wife hates the UTEC....
  166. TurboXS EVO race gas dyno plots
  167. UTEC Launch control
  168. TurboXS tuner questions
  169. Damn I'm Happy
  170. Just tuned at turbo trix
  171. Anyone using the ARC intake with the UTEC
  172. TXS UTEC and RFL-Ti On the Way
  173. Ray's UTEC studder transition log
  174. can we get an update on the MAP kit and Gameboy adapter..
  175. UTEC Revisions (Flash info)
  176. Utec log
  177. [HELP!!!] ABC installation
  178. UTEC Request List
  179. changing the TPS value...
  180. Just upgraded my BOV to TXS BOV.
  181. WHP expected
  182. See if you can spot the new UTEC feature
  183. 520whp on UTEC
  184. Tuna install
  185. Switching to a map that hasnt been set yet
  186. adapter to mount knock sensor on tuner
  187. pictures of my utec install.
  188. utec as a first mod?
  189. Evo utec ????
  190. What should I expect?!?
  191. EGT plug and play sensor
  192. should I get it?
  193. UTEC Parameter file change
  194. Utech \ Pruven Tunning. Wow!!!!!
  195. Inconsistencies with UTEC
  196. Evo installation notes
  197. Idle Quality with Cams..
  198. Tuner-WB O2 sensor mounting location
  199. Z1 Performance has the UTEC
  200. Tuner and UTEC Connected..
  201. RJ-11/16 port on the UTEC
  202. here is my first datalog with UTEC!!
  203. installed my UTEC today. Here is a preliminary review..
  204. Utec installed!
  205. I heard a rumor Nino installed a Utec today on an evo.......
  206. UTEC vs. XEDE...anyone know the difference yet?
  207. my UTEC is in the mail
  208. Closed Loop Boost Control
  209. Ease of Use
  210. Don't miss this! The Evo UTEC is Out!!!!
  211. Is there any Windows based software to be used with the utec?
  212. anyone using UTEC yet? Post your results here
