- perfection motorsports is hosting a turboxs tuning dyno day
- Injector scaling question??
- Well, the gt-35 is in, UTEC tuning time..
- UTEC ruined my day big time.
- Using TXS's Stg 2 map safe for daily driving?
- MAP 1 Knock
- UTEC/ABC & boost spike?
- Can't say enough, H2O injection!!
- Software update switch position?
- Purchased UTEC + TXS TBE!!
- Lets see your fuel maps w/cams
- asking a long shot question
- Can the ABC effect idle?
- boost issues with UTEC/ABC
- UTEC advance timing/Xede retard Timing
- Injector question
- whats going on with open loop???
- Anybody notice this??
- All Evo's aren't created equal
- What happens when you reset UTEC?
- UTEC ABC install?
- I need HELP tuning my UTEC!!!
- PDA Suggestions for Tuning UTEC?
- Great $6.95 Shift Light
- When is TurboXS going to post up some more maps??
- 91 UTEC MAP for stock turbo
- Possibly going from xede to utec....
- how to configure usb/serial adapter
- UTEC demo software?
- Ay Caramba!!
- Has anyone bought a Utec from this guy (Ebay)
- Can "EVO UTEC" works with MR
- UTEC's Knock Detection
- UTEC Tuning issues
- looking for input
- CEL with UTEC, always after second start.
- Utec + H2O Injection
- Load problem
- Launch control idea
- Utec tuned by Harman Motive
- MAP Sensor Pin Diagram
- What is the value of your boost control gain?
- Switch mounts
- Bringing Evo up to Colorado from Marland- Problems?
- Tuning Order?
- Considering a UTEC -- handful of questions
- Po 171 Ses
- Utec Olf Background Map
- wierd utec problem - random mod maf numbers
- Why my MAP sensor won't work
- Q about knocking
- ABC question
- 04 getting p0300 with utec???
- Anyone running the UTEC with the Buschur alcohol injection?
- Map wiring
- Map sensor Calibration
- New UTEC book idea
- GM map sensor w/pigtail
- MAP sensor install
- need quick answer please N2O and utec extra solenoid controller
- UTEC detonation QUESTION
- Novice questions for boost control
- Dell Axim50x connections
- Closed loop Boost Map
- Knock Thresholds
- Advice on UTEC purchase
- Help with Fuel Maps?
- Misfire problem
- What obd scanner do you suggest?
- Possible to add aux input to UTEC?
- Where to find...
- UTEC on '05 evo
- Questions
- Finally Finished Motor...WOW!!!
- Not Afraid to ask stupid questions
- P0201 Code with UTEC
- Really quick question
- Need Some UTEC help
- Opinions on EGT's?
- FYI. Brand New Tuner FS for $300 in FS section
- Utec or Exede
- utec abc or hallman mbc
- FS: Mint condition Utec,Tuner Pro, etc..
- Utec + turbo kit ?
- UTEC is gonna get me fired and divorced!
- UTEC didnt like my injectors.....????
- Utec question
- keep getting fuel or boost cut?
- 25psi Help!
- First logging run
- Just installed
- o.k. Utec tuners, a few Q's.......
- Tuner Pro
- utec question
- UCC Question
- Help a UTEC newbie out?
- Intakes, Inductions Boxes, Maf Pipes... OH MY!!
- MAP calibration
- MBC necessary w/ UTEC?
- Got my car dyno'd!
- 420 AWHP with Utec
- Utec timing stage 2 -100?
- Tuner Pro ????
- Increasing Boost Slightly
- Q: for all you using UCC
- getting tuned anything else?
- Mods/HP/TQ/Log/MAP
- Modified injector size
- Found a nice addon gauge for the TurboXS Tuner
- My Yule Log.Comments Please
- Is this normal?
- A christmas Gift.. UTEC Digital Dashboard
- TXS Dyno Day Results?
- dsm translator/3in GM MAF
- Looking for BigBoogieman
- ABC Install?
- Quick but Importants Questions on UTEC Install
- Removal of MAF?
- BR Downpipe & O2 sensor?
- maybe bad pump or utec
- 1 Quick Q
- CEL help - P0234 code while tuning UTEC
- what map?
- UTEC a/f
- 11's
- Not boosting with Utec installed
- Tuner Remote Display
- flash swith up or down to set it to run?
- Map Sensor?
- TXS Rocks
- Yet another Utec question
- UTEC Boost controller?
- UTEC Tuned by Harmanmotive (Check out my numbers)
- Buying a used UTEC...
- Features the UTEC REALLY REALLY Needs to compete with a Standalone
- Tuner vs. Tunrer Pro
- 5k rpm studder with UTEC
- Just Ordered UTEC. A few?'s
- UTEC and 05 models?
- Pass thru ?
- Thought I would take a chance
- Update on Engine
- New Maps?
- question for Malibu Jack, knock and timing
- Helpful Addition
- Which to get first?
- map 0 with 1.7 firmware w/ OLF
- race gas and stalling
- UTEC for '04 Evo
- Pics of Head, may be ok
- More success with the UTEC!
- Problem with Utec
- pics from motor
- New Dyno Resutls via UTEC Tune
- my connector doesnt fit
- Utec general question
- Might have seized
- beat my idle issues...I think
- How to idle 272 cams with Utec
- Cold idle problem
- *** UTEC Control Center release 3 available ***
- Problems w/ UTEC and *flash?
- Launch control rpm question
- My shift light V1
- Considering UTEC
- Showin txs some luv
- Just got my UTEC tuned :)
- Cam/inj/1.7firmware questions
- Another restrictor pill help question
- Just upgraded to firmware 1.7 help
- DTEC First look
- Utec Maps For Australian 98 octane Fuel
- Road Tune
- Proper A/F and EGT and Timming?
- Boost problems!!
- 25 psi watta hoot
- shift light help
- Utec for sale!!!!!!!!!!!!!
- Problem holding 20psi to redline
- Safe injector duty cycle on stock injectors?
- 1.7 w/ 1000cc injectors
- 1.7 firmware - Utec to Ecu timing and vice versa interpolation.
- Utec 1.7/w 680cc injector problem, Please help!
- Utec 2005?
- stage II questions
- UTEC took a dump on me
- Timing Low rpm, Low Load..
- Utec, Flased, Injectors, Open Loop
- Tuner question
- WHere are you guys running your tuner...
- Utec log with new 1.7 firmware
- How tricky is it to tune?
- Disconnect UTEC from ECU before upgrading to 1.7? (9v Battery?)
- Maxed out stock injectors @ 23psi?
- CEL after CEL is it my UTEC?
- Am I stupid?!?!? LOL
- Tuner knock sensor placement
- PO108 code after switching to 1.7
- Cams and fuel and UTECS oh my!
- Looks almost like UTEC
- Rev limit set to 7,000 reguardless?
- Turboxs Tuner questions...
- Hear-Ye Hear-Ye! UTEC Firmware v1.7 is online...
- Wideband o2 sensor placement, as well as knock sensor?
- Need a Uteck
- Will the Utech's new Firmware allow a Speed Density Conversion?
- Evo Utec Ver. 1.6 Pre-Release Party
- Interface Question
- Rev Limit?
- Release date on DTec?
- UTEC and XEDE Comparo
- WTF not again.
- UTEC Owner Survey
- External Map Sensor
- Logging with UTEC
- FS Turbo XS Tuner Pro(Brand New)
- Wideband o2 ?
- Utec yeilds a 11.98@115
- UTEC with new turbo kits
- Getting a UTEC, but need a few answers
- Post your UTEC Logs Here
- UTEC noob
- cant rev past 4.5k?
- Flash + utec?
- Could some post Datalog with MAP sensor data ?
- Post your GM 3-bar sensor setup values
- need help getting TXS map
- Temp Changes
- Opened loop or Closed loop boost control
- High boost
- Request: UTEC FAQ
- My UTEC is wrong? or it's normal?
- Stage 1 Map help
- Faster Turbo Response
- UTEC Problem
- TunaPro Logging problem, need some ideas
- Questions for utec owners
- Questions on datalog #2
- MAF to MAP???
- ? on map 0
- usb to serial adapter?
- First OPEN LOOP Fuel map..
- UCC Release 2 Available
- TXS Tuner $399 with VW Wideband
- Can I see some timing maps?
- Importing A/F ratio into UTEC
- Help with datalog need a few pointers
- Stage 2 Map
- UTEc and aftermarket intake?
- Map Seletor
