- SAFC2 or UTEC
- kudos to TOPSPEED
- UTEC Loses Power at constant throttle
- Utec Maps??
- CEL flashing before start
- Misfire
- How do you delete maps???????
- TurboXS UTEC ?????
- xs tuner
- Switch to XEDE SMART?
- What do you think….
- utec timing with 272's and T67
- Another set of logs, opinions wanted.
- Is my UTEC strange?
- GM Boost Control Solenoid Part Number?
- Factory p0300 flash and UTEC
- Who has timing greater than 11 degrees at peak torque
- Will this Blow-Through MAF work?
- Maximum timing
- Issue with PO234 Code
- utec map selector
- Questions about MAP sensor
- Reflash as a base map?
- UTEC Questions **Advice Needed**
- First log / couple of questions.
- TunerPro/EGT Question
- Engine Overboost...getting pissed!!!
- TurboXS RFL BOV
- ABC installation (Look ok?)
- dyno tuning ny/nj/long island
- here's my tuner pro
- Utec newbie questions.
- just bought utec used???
- Hesitation when I go WOT
- Florida UTEC owners in need of tuning...
- Tuning for 100% Methanol Injection
- meth injection
- Wish me luck tomorrow with meth tuning
- so whats everyone making???
- MalibuJack's NEW UTEC Wishlist...
- BUMP for Turbo XS Response
- Launch control with an on/off switch?
- Will There ever be Speed Density?
- Can we set up a map database?
- "Base" map on an 05
- Well I did it
- First UTec log
- Back from the drag strip with tuning question
- Tuning HKS 280's
- txs tuner reading lambda
- UTEC map tables RPM range?
- Is UTEC really all that limiting?
- Will MAP sensor install change MAF...
- UTECH vs. EXede
- Just got my XS UTEC!!
- New Way Of Boost Ctrl
- TurboXS would like your help! MD/VA/DC Free Road Tune!
- tried 104 octane...disappointed
- AFR question
- UTEC map sensor
- should i go with Utec?
- Who stocks the UTEC MAP sensor?
- GM Maf with Utec
- Need a UTEC tuner in South Florida
- just installed new UTEC, sweet!
- Palm Treo 600 HyperTerminal software?
- TurboXS KnockLite
- UTEC and 880cc injectors?
- Wierd anomaly
- Remote map selector install -- I'm lost
- Knock Value
- went tuning for 3 hours...heres what i did...
- Timing/boost with race gas
- utec tune on dyno
- Utec for GT35R??
- Odd Utec question
- UTEC pulled timing?
- Can someone here help me to post 2 Hertz vs. RPM graphs?
- UTEC Vs. AEM EMS
- Super lean problem
- Review. Perrin EBCS + UTEC
- Questions about Utec
- HOw to enter TXS stage 1 or 2 fuel/timing/boost map
- Abc?
- Recirculating or VTA Bov for Utec?
- UTEC tuned at Harman Motive.
- UTEC not displaying any numbers in Knock column
- 850cc Injector Tuning Questions
- Nitrous and Utec?
- quick Open Loop Fuelling question on Map1
- MPS_UTEClogger 2.3
- Calibration for Kavlico sensor
- 4th gear map 1 log
- Utec's 2 step take out cat?
- Need info on UTEC tuning basics...
- when to switch maps with different octane
- Where should I mount my wideband o2 sensor
- MalibuJack, what software are you using to graph HP vs. RPM?
- Turbo XS must be close....
- UTEC for Dummies
- Crazy idea about MAP conversion
- Datalog a 03 and 05 evo
- I'm getting my UTEC Drunk
- What should I expect WHP with...
- UTEC logs - observe and diagnose
- TXS stage I/II maps
- I need a tuner lite
- Tuner lite compatability question
- 23 PSI at IDLE
- What all is needed when running this system
- Perrin Shortram and Boost tubes
- cam gear settings question??
- procedure for MAP based tuning
- timing=good in gears 1-3, knocks in 5th in same load cell -- now what?
- Map 0 / EBC@20psi log
- got some questions about utec with flash
- Sorry if this is a stupid ??
- Please explain the optional MAP sensor
- Has anyone tried this software with an Evo?
- Issues with tuning in 90+ degree temps?
- Best Cam Gear settings for 272s?
- MBC or ABC with Utec
- To anyone using the tuner lite
- Starting Map from a WORKs flash
- MAP load maps? And tuning timing question.
- My HUGE discovery in the Utec... mainly for drag racing
- In car tuner question
- retarding timing: UTEC more aggressive than stock?
- Knock Count 1
- Timing with 272's
- Run UTEC with AC Power?
- Confused by flickering CEL light
- UTEC MAF problems
- tuning generalities for aftermarket turbos
- What should I spend my money on?
- Tuner Lite Question RPM
- High Boost with Bleed Valve?
- A little frustrated with OLF
- Please help, I need a map for now!
- General tuning chat
- Map sensor installed
- My lame-a$$ street tune
- Timing and overall performance help: log inside
- Stutter launch info
- UTEC is in: 3rd gear log w/Dynoflash basetune -- comments?
- external MAP calibration
- Timing for a good idle help
- cant run utec without MAP
- Knock Question and between shift stutter
- Boost control question
- AFR Rich after tt custom tune
- Question about using OLF with a flash already scaled for larger injectors
- Can someone check this data log for me??!!
- Just got my new UTEC -- some starter questions
- Couple Qs about the tuner pro and the tuner
- Need Help Quick Please.
- When you left off gas, car idles poor but bliping the throttle will make it better?
- Just got my used tuner pro... need MAP sensor and o2 bung
- Next UTEC firmware upgrade??
- GT35R and Utec
- Close Loop Boost - Spikes in high gear
- Knock question
- a few last minute questions before buying UTEC
- Would I need the Tuner if I get a UTEC?
- utecwshift lites,map mod map selector/tuner pro 800.00
- utecwshift lites,map mod map selector/tuner pro 950.00 shipped
- Tune Utec w/ Mac?
- Can my UTEC controll my nitrous???
- Load Sites with MAP sensor???
- ABC Valve?
- Newbie Utec problems
- My "professional" tune!?
- What are you thoughts of Vishnu's new auto tuning?
- Alcohol injection Tuning Tips??
- More tuning woes
- F/S Tuner Pro
- Putting in bigger injectors
- To stay at 11.0-11.5 a/f's
- bad misfire
- Newbie
- Should I purchase a UTEC?
- UTEC b/c with turbo upgrade
- Anybody getting knok in 5th gear under load?
- CEL fix for test pipe...
- Horrible fuel pump problem
- rattling tuner pro......
- Suggestions for Tuner Pro knock settings?
- RS-R gt2 Exhaust & DP w/ UTEC
- UTEC setting Check Engine lights ramdomly?!!
- What Dyno numbers have you guys Gotten With the UTEC?
- *** UCC Release 4 now available *** (part 1 of 3)
- 0% Load column tuning woes
- tuner pro RPM input
- Map sensor with utec
- orientation of 4 pin molex plug for external MAP sensor
- placement of the utec knock sensor
- Base maps?
- Where to get my UTEC installed and tuned?
- Just got my UTEC today with remote switch...
- How much timing adjustment can I do?
- Dynoflashed + UTEC = ?
- Stock ECU Bracket? Help :(
- got a utec
- Bung location
- timing question
- About to order UTEC what else is need
- I have some UTEC questions
- Intermittent problems connecting PC to UTEC
- UTEC Serial Cable help
- Advantages of a blowthrough MAF with the UTEC..
- Launch control not working
- Another Faulty O2 Sensor?
- This is fuel cut! Log attached
- Atlanta area dyno day. UTEC tuner.
- UTEC Handshake Problems
- just tuned question?
- how to read this ?
- Big Thanks to Jermaine @ Turbo XS
- Stage 1(TBE) map stalling?
- Running lean
- what a/f are you guys at?
- Jack
- UTEC NEWB here
- MAP Sensor Install
- MAP Sensor Q's
- Can Anybody Interpret This Log File?
- Newb Question.
- Ingnition question
- HKS Twin Power
- Rich spot between 4-5k
- Random problem, maybe associated with launch control?
- Abc...
- Tuning Help !!!!
- Hey Jack............
- Security activated
- Anyone running a crank pulley with their UTEC?
- UTEC Tuning Problems - PLEASE HELP!
- Strange cut-out
- New UTEC and now...?
- Tuning smooth idle with UTEC and Cams
- Boost restrictor pill question??
- Tuning with UTEC
- transfer error
- utec tuner question
- How much boost are you all peaking at w/ race fuel?
- Advice on UTEC
- A little Dyno knowledge goes a long way
- DTEC and the PSP
- False stock Boost Cut??
- Load Of Cra* :)
