View Full Version : Apex-i Power FC
Pages : [1] 2
  1. Power FC models? Which one for EVO 8?
  2. Any one use FC tune on their EVO?
  3. fc tune
  4. need a base map for a 35r having issues
  5. Advantages/Disadvantages
  6. Datalogit tuner needed northeast pa
  7. ApexI Power FC D-Jetro W/ FC Commander
  8. RPM DROP OFF too quick
  9. HELP --- Apexi Power FC
  10. 5 bar map sensor?
  11. TurnOver, No Start
  12. Aem Uego
  13. apex i power fc for evo 6 to evo 4
  14. Immobolizer possible issues with apexi
  15. PowerFC Manuals & mapping!
  16. Need manuel or help asap!!
  17. power fc tunning program asap!!!
  18. help plz
  19. Evo8's power fc on evo7 ?
  20. Selling my L-Jetro
  21. Pfc tuners
  22. Quick question power FC
  23. your settings
  24. how to check timming!
  25. Wideband
  26. Gizzmo launch control
  27. Who has pushed the power fc?
  28. manual on apexi FC(english) for russian
  29. Pfc with New Map sensor(3.5 bar)..
  30. New Map Sensor for PFC ( apexi AVCR- 3.5bar)
  31. Installing Apexi AVC-R in Evo X
  32. AIT Sensor Upgrade?
  33. Tuning 4 Faster TURBO SPOOL
  34. Will this Fit?
  35. De-Jetro MAP Sensor Install
  36. PowerFC controlling 8 Fuel Injectors
  37. EVO ECU pinout?? Power fc problem Evo6-7-8
  38. Dwell time (dead Time) for COP..
  39. Knock in High Boost with Right AFR
  40. THRO check light Power Fc evo VII
  41. power fc and use of wideband?
  42. MAF or MAP with PowerFC Setup
  43. Datalogit won't plug into PFC ?
  44. Need a bad ass affordable stand alone?
  45. New Power FC Install
  46. cooling fan fix
  47. Hello From Guatemala, Pls I Need Help Experts With My Pfc
  48. Car nearly stalled..Need help..
  49. FC commander question
  50. Optional boost control help thru ECU
  51. Power FC D-jetro wiring Diagram
  52. evo 8 map
  53. Apexi Power FC L-Jetro for sale
  54. Power FC Alternator Control
  55. Multiple Maps with Power FC?
  56. wideband says car is running 17+ AFR all the time, Power FC
  57. 2 step
  58. Timing retrad from 2.0 to 2.3L
  59. Motor Patches Shirt Jacket F1 Motorsports Badges
  60. Getting motor to idle with PFC and no IAC
  61. no start
  62. Timing Tuning Infor
  63. Need setting for a AVCR map 3.5bar map sensor on PFC
  64. What's FPR on sensors??
  65. knock levels and peak hold ?
  66. Anybody knows what is FIC 850cc Latency values?
  67. Tuning
  68. Apexi Neo O2 Sensor?
  69. O2 sensors with Power FC
  70. Using Another Solenoid?
  71. 2.3L 4G63 Apexi D-Jetro Map needed?
  72. PFC Djetro
  73. Tacho no running..
  74. Anybody knows wat Deceleration Fuel Recovery means?
  75. FC L-jetro HELP...
  76. Fc dataloggit "Protect settings"
  77. FC data edit won't connect
  78. Is the FC worth it?
  79. Apexi Power FC (D-Jetro) in LA, CA (HELP!!!)
  80. Starting
  81. Power Fc And Hks Eids
  82. FC tuning
  83. FC Datalogit
  84. base ignition timing?
  85. Power FC Map Sensor
  86. Intake Temp Sensor
  87. Another PFC IGN tuning.
  88. PFC for EVO 3
  89. New to PFC
  90. Tuning
  91. power fc (map sensor)
  92. Inital Start Up
  93. power fc -switchable maps?
  94. Boost Controller Kit Help
  95. scaling 660cc injectors
  96. power fc, power gains ?
  97. FC datalogit com port error
  98. Stock Map
  99. What is the limit of factory maf?
  100. Installation question before buying Power FC?
  101. AEM 3.5 bar map on power fc
  102. Apexi PFC tuning - From Kenya
  103. Apexi Gizzmo's
  104. Commander mount?
  105. Ecuflash vs Power FC
  106. Power FC & AVCR problem
  107. submit content for the powerfc faq
  108. Map Sensor Kit
  109. '03 Evo & Power FC?
  110. Power FC on Ebay
  111. Power FC Boost Controller install??
  112. WELD JAPAN will be tuning POWER FC Dec 13-27th.
  113. APEX'I Vs HKS Vs MOTEC M800 OEM
  114. 1000cc injectors with PowerFC
  115. Power FC & AC?
  116. Power Fc Tuners Near Nashville,tn
  117. end of sale powerfc
  118. AEM Wideband output with Datalogit - Anyone tried?
  119. PFC map question
  120. Can someone help me with my EVO VI power FC map?? PLEASE!!
  121. power fc questions
  122. O2 sensor volatge questions
  123. FC Datalogit vs FC PRO software kit
  124. power fc info needed
  125. PowerFC + Commander Manual for CT9A
  126. Need a new Air temp sensor!
  127. Power FC tuner for evo
  128. Got the EVO on the Dyno finally
  129. Datalogit read all error 84 & 88
  130. Do you have a PFC and larger than standard injectors?
  131. eta on evo 9 power fc
  132. Boost controler hook with PFC
  133. Power FC and Precision Turbo Injector specs: needed
  134. PFC knock reading is high - please help !
  135. Need a EMS - how easy is the PFC compared to AEM
  136. Yellow Top Injectors: Lag Times..
  137. APEXi PFC tunner around Tampa,FL
  138. Anti lag
  139. my apexi avc-r.can someone PLEASE help me
  140. Power FC Water Temp Setting????
  141. any cp9a power fc to trade with ct9a?
  142. Knock control and the PFC
  143. Finally installed
  144. Datalogit W/out the waite
  145. Launch Control w/ Power FC
  146. boost solnoid
  147. Which Value?
  148. Apexi Power FC + Commander Question
  149. Need Help please
  150. Can't seem to get the power fc to work
  151. widebands for pfc
  152. Second O2 Sensor with PFC D-Jetro
  153. Need help on this please.
  154. Stock FC Map
  155. Apex-i Power FC could never start
  156. Help on PFC D-Jetro
  157. Evo ix Engine management system
  158. Setting for 680cc
  159. Power FC and 280 cams
  160. Injector size question
  161. Power Pc and G.M. Boost Solenoid
  162. Launch Control?
  163. FC-Datalogit Users Required!
  164. Need feedback on this product
  165. WTB: FC-Datalogit
  166. How is the initial tune?
  167. Front O2 Sensor w/ PFC
  168. Anyone Tune Apexi Power FC around Minnesota?
  169. HKS SSQV BOV problem
  170. injector correction with Power FC
  171. Where to mount PFC?
  172. Power FC knock control question
  173. A new PowerFC?
  174. Where To Buy???
  175. L-jetro w/map sensor
  176. Knock from bad gas?
  177. Power FC tuners in Socal?
  178. map sensor
  179. PFC and intercooler sprayer control???
  180. Weird Boost Issues with EBCS Solenoid
  181. My Dyno graph.
  182. Help, my evo does not start with PFC...
  183. What is an acceptable knock count?
  184. Apexi Power Fc for 05 evo
  185. whos using the Evo 7 Power FC for the USDM Evo 8?
  186. Will the PFC L-Jetro (2003) work in a 2005?
  187. Please, help with tps, i'm in total confusion......
  188. how to hook up the sensors on the power fc?
  189. I need a good map
  190. Help with injector lag value...
  191. where to mount the commander?
  192. MDP sensor and Power FC on Aussie EVO 8
  193. running over 400whp with the power FC?
  194. TPS and injectors recognizing.
  195. got questions
  196. power fc max boost
  197. expert opinion--reliability with Power FC
  198. Anyone want Apexi boost controller?
  199. getting a Power FC
  200. Info about Pfc on Evo VIII GSR
  201. MAP sensor question...
  202. UK Tuners
  203. Map Watch capture..... can anyone help?
  204. Any tuners care to look at this log?
  205. Power FC and alky kit
  206. Apex-i boost controller and PFC
  207. Apexi PFC maps. HELP ME PLEASE
  208. Where can i buy this Apexi Boost Gauge?
  209. L-Jetro Conversion
  210. Datalogit?
  211. Can I use SAFC2 with my PFC to tune seperate maps?...
  212. D-Jetro Power FC sensor kit.
  213. POWER FC settings
  214. Power Fc Whp???
  215. What the hell?
  216. i need help
  217. Power FC & LHD Evo 7
  218. Power Fc D-jetro
  219. Advice needed..
  220. Opinions on Power FC
  221. PowerFC for sale
  222. Apexi...first contact
  223. Setup of Power FC
  224. Colant temp 96c is it okay ? using Power FC
  225. evo 7 power fc on evo 8? please read
  226. Buying a used Apexi-Power PC any advise ???
  227. Experience Mapper Needed..
  228. maf sensor ????
  229. Tuner Advice for PFC
  230. Finally Solved My Knock Problem
  231. wiring question
  232. US Instructions for Power FC D-Jetro
  233. Power FC problem mapping
  234. Any tips on installing and tuning a PowerFC?
  235. Power FC on a Mitsubishi RVR?
  236. Who is the POO when it comes to tuning the power FC in TX?
  237. Boost 1.6.....2.0 bar
  238. Apex'i World Sport 2 Exhaust?
  239. FC-Datalogit Question??
  240. Power FC problem
  241. Knock Reading using FC Commander
  242. Help Power Fc Evo 8 280 Hp Jpd
  243. Selling D-Jetro w/command, BC, datalogit, etc
  244. FC-Datalogit for D-Jetro
  245. Help with Power-FC D-Jetro
  246. Odd 5th Gear boost behavior
  247. Is SFC-II and Power FC the same thing?
  248. emmisons
  249. What are the best afc2 settings on stage 1
  250. My short 1 night review (L-Jetro)
