Go Back   evolutionm.net > Market Place > Private "Regional" For Sale > Mid-Atlantic Region
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 6, 2009, 06:53 PM   #1
Personal Sales Rating: (9)
cnoevol's Avatar
Drives: Miss Daisy
Send a message via AIM to cnoevol
FS: 1986 Corolla GTS 20V 4AGE BLACKTOP
This is a great lil car. In AWESOME shape for its age, original paint. 184k on body, swap done little over 6k miles ago, its one of the cleanest swaps ive seen. Car weighs 2100 lbs. with half a tank of gas.
I bought it a couple months ago was gonna use it as a track car next year but has since had a change of circumstances. Would make a great starter track car or drift. I autoxd it once and it was fun to drive. The previous owner (toyota tech) did the work on the car.
$7500
Engine
1998 AE111 20v 4age
TRD 4-1 header
Buddy club spec II exhaust w/ cat
Cusco engine mounts
Lightweight water pump and alternator pulley
Jubiride throttle screens
T3 velocity stacks
Earls oil cooler
Odyssey 11 lb battery behind driver’s seat
Drivetrain
Low mileage JDM transmission
XTD flywheel
ACT clutch kit
T3 Short shifter
Tomei 2 way LSD
Cusco transmission mount
Slotted rotors
Hawk pads
Braided stainless steel brake lines
Braided stainless steel clutch line
16x8 Sportmax 002
Falken RT615 205/40/16 worn but have new set of nexen n3000 tires to replace them
Suspension
T3 NRCAs
T3 camber plates
T3 front coilovers 6.7kg spring rate
KYB AGX front inserts
KYB AGX rear struts
TRD Japan rear springs 4.3 kg
Battleversion 5 links
Prothane bushings
Stitch welded chassis
Manual steering rack
Interior
Sparco Corsa driver’s seat
Corbeau FX1 passenger seat
Harness bar
RJS 5pt harnesses
Momo deep dish suede steering wheel
Pro Sport oil pressure and water temp gauges
JDM Alpine MD and 3 CD in dash dual din
Alpine 4” speakers
New Parts
Windshield
Windshield molding
Taillight gaskets
Distributor cap and rotor
Radiator
Brake master cylinder
Clutch master cylinder
Clutch slave cylinder
Rebuilt OEM Toyota calipers
Ball joints
Inner and outer tie rods
Wheel bearings
Rear end professionally rebuilt
Carrier bearings
Pinion bearing and seal
Axle bearings
Eyelids (not installed)
Test pipe(not installed)
__________________
Built by BUSCHUR RACING
Offline
Old Jan 6, 2009, 07:27 PM   #2
Personal Sales Rating: (29)
evoboy83's Avatar
Drives: evo 8
hot looking ae86 ..... glws
Offline
Tags
1986, 20v, 4ag, 4age, 86, blacktop, corolla, exhaust, gts, harness, jdm, sale, system, tampa, trd
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
