Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Troubleshooting
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 1, 2004, 08:18 AM   #1
Personal Sales Rating: (0)
Unhappy Help! My stero & clock won't come on now that I installed my Amp & Subs!
I have an '02 Lancer ES & I recently installed a Kenwood Head Unit. It worked just fine & about 3 days later I decided to install my amp & subs. So I take out the back seat, the trim, & the part of the dash I need to get to the stero, and then I ran the power wire & the RC cable. I ran the power wire up the drivers side to the rubber goblet thingie that is under the dash where my wires run into the quarter panel & into the engine compartment. I used a screw driver to poke a hole in the rubber goblet to get the power cable through it, & then ran the power wire to the battery. Once every thing was installed I went ahead & started the car & my dome light wouldn't come on. So I shut the car off & then turned it back on & the dome light came on! Well then I tryed to turn on the head unit & the head unit doesn't come on! I notice that the clock isn't on either! So I shut the car off, & then to make sure it wasn't the head unit I put the factory stero back in & it doesn't come on either! WHAT THE HECK! Anywayz so I went ahead & checked all my fuses & they are all ok. I made sure that when I poked through the rubber goblet thing I din't poke any wires (I am pretty sure at least). But the weird thing is that on my new Kenwood there is a red light that blinks on it when the face plate is off to make it look like there is a security system, & that still blinks but the power to the face plate doean't come on! Also when I had the factory stero in It ejected the CD that was in the CD player, But you cannot insert another, & it has no power to the face part of it!?!
Anyone have any idea's as to what the problem is, or what I should try next? I would REALLY appreciate a good sound plan of action. Thanks alot everyone! Later!
Offline
Old Aug 1, 2004, 08:39 AM   #2
chinto's Avatar
Drives: 2006 Evo Mr Jeep wrangler
Send a message via ICQ to chinto Send a message via AIM to chinto Send a message via Yahoo to chinto
u check ur fuses? and the sterio clock? not powerd sounds like you dont have the sterio spliced in correctly... check all your connections..
Offline
Old Aug 1, 2004, 08:42 AM   #3
Personal Sales Rating: (13)
itscypha's Avatar
Drives: my girl crazyyy!
Send a message via AIM to itscypha
ya check the fuse in your engine bay.
Offline
Old Aug 9, 2004, 01:38 PM   #4
EvoM Administrator
Personal Sales Rating: (8)
HobieKopek's Avatar
Drives: A little red Neon. I also have a Lancer that presumably still rolls...but doesn't drive.
Send a message via AIM to HobieKopek
I think the fuse for that stuff is under your steering column (more or less), not in the engine bay.
__________________
Quote:
Originally Posted by Foggy View Post
I believe the bears are our future
Feed them well, and let them lead the way...
Quote:
Originally Posted by Raphael
Hi. As you can see I'm a bear. I contain no artificial flavors and no artificial colors. Now you may be thinking, "Oh, he's such a cute little bear," but let me tell you I am hard. Really hard. Deep down, I am still a bear. An animal born to raise hell. If I saw a dinosaur right now I'd rip his head off.
Sign up to win prizes by running web searches with Blingo. Powered by Yahoo!
Offline
Old Aug 9, 2004, 01:43 PM   #5
Personal Sales Rating: (26)
screams FUSE!!!!!
Offline
Old Aug 10, 2004, 10:26 AM   #6
Personal Sales Rating: (2)
Centrylancer's Avatar
Drives: a boosted pixel.
Send a message via AIM to Centrylancer
Quote:
Originally Posted by Iamkar33m
screams FUSE!!!!!
thats what it sounds like...
how about an update? did you get it working
__________________
Evoms Resident Viking & Designer!
Dane-Designs - Illustration, Graphic Design & Photography
Quote:
Originally Posted by Fiesty882
people make plans. god laughs
It's a Celebration! - Habitual Line Stepper
Offline
Old Aug 20, 2004, 09:00 PM   #7
Personal Sales Rating: (112)
Z_Lancer_Man's Avatar
Drives: 06 WW EVO IX w/ SSL
Send a message via AIM to Z_Lancer_Man
I have a similar problem. I jsut hooked up another amp today to power my front speakers and when I got it all hooked up, the stereo works fine. But none of my gauge lights work now. The headlights do, clock, dome and stereo all work, but the AC controls and gauge cluster lights don't work anymore. Any ideas?
__________________
AMS 3" TBE w/ TP |GFB BOV | AMS UICP | Muse LICP | Walbro 255 Fuel Pump | Mini Battery | Amsoil air filter w/ Vibrant MAF adapter | Custom Boost Pill (#58) | Omni Power 4-Bar MAP Sensor | Powerslot Slotted Cryo Rotors | Swift Springs | MIL.SPEC TB Shaft Seals
325/310 WHP/TQ (VDR 5.7) - 24 PSI, 91 Pump - Self Tuned w/ECUFlash
Previous Lancers
- '09 Lancer GTS (traded 6/19/09)
- '03 Lancer OZ Rally (traded 1/18/09)
Offline
Old Aug 21, 2004, 10:20 PM   #8
itscypha's Avatar
how u gon say under the steerin column? there isnt a fuse placement for the radio under there its in the engine bay...n ya a fuse... check the manual it will tell ya. good luck
Offline
Old Sep 21, 2004, 11:10 PM   #9
jdubs3rd's Avatar
Drives: 2003 Lancer ES
Send a message via AIM to jdubs3rd
aight, first of all, check all of your wires and make sure they are connected. You want to make sure its not just some stupid mistake. 2nd, i hope you unhooked the battery while you were messin with all of this stuff, cause you may have surged, which could have blown the clock and the cd players motors and face plate. I do know that some bulbs in cd players can still work while other components are blown. And i do know for a fact that clocks love to get blown. I however do not know if the fuses in the lancer are like other guys, and they sometimes are a little bigger than they should and allow those things to get blown in the first place. And hey, does everything else still work, like the starter and other lights besides the clock and cd? hope this helps
Offline
Old Oct 21, 2004, 05:28 PM   #10
jaymz916's Avatar
Drives: 08 GTS
Fuse
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
