2nd Gear Lag
2nd Gear Lag
Has anyone one other then me lags on 2nd gear? I've been pondering too long let a brother KNOW! First gear is fine to redline, until I shift to 2nd gear it'll give about a 2 to 3 second lag before it'll start to pick back up..
Double clutching???? why??? I dont think thats the problem. Try searching in the driving techniques section of the forum. You should find your answer there. I will agree with the first part with possibly falling out of the power vband but also dont dump the clutch, try slipping it. If you want more info go to the driving techniques section of the forum.
The problem is the stock ECU- It leans out right where you're shifting to (you're ending up between 2500 and 3000RPM if I had to guess) there's a little "hump" in the AFR curve that goes up to about 13.3 AFR. about 12.7 is optimal. Contrary to popular belief, if you go too lean, you do lose power. (FWIW the stock ECU under WOT goes down to about 11.8)
So, if you're concerned about needing more oomph after a shift, shift later (like when the needle is heading into the redline). Or just don't be concerned about it.
thanks but guys i've done all of those haha except for the ECU idea..umm...can it be my clutch line how since our lancers have slave clutch modulator? i know its a stupid question i need help thats all i'm tired of losing =( but i switch passed redline right before the rev limiter cuts me off..
you need to fill out your mods list in your profile. If all you have is something like 17" rims and a CAI you really shouldn't be surprised that you're losing. And you're racing at a track, right?
why would a CAI hurt? or is it the combination of that and the 17" rims???
Originally Posted by meewantevo
Conclusion: My Lancer was starting to lagg from the stock clutch..the clutch is slipping and starting to burn ou.. *sigh*
and dude how do you know the clutch is slipping???? is ur RPM rising but ur not going nowhere???
I didn't say it would hurt. What I said was (to rephrase) "if all you have is the simplest of mods" (CAI for example) you shouldn't be surprised that you're losing. Read the threads. This engine isn't the most powerful NA on the market, it doesn't respond well to mods, and in its stock form it can't handle the kind of boost it will take to be really aggressive (you need to up grade the headstuds, etc).
Anyway, as was answered in the other thread he started, the change from 1 to 2 mechanically induces lag. The gears weren't designed by the Ralli///Art race crew We'd need 6 gears making 2-3-4-5 each a little shorter and 6 a little taller than our current 5. That would be awesome, except we'd be shifting way more often than we are. Each shift takes about 0.1sec if you're fast and that adds time to your laps. Or, a taller 1st and the rest of the gears the same (I'd take a slightly taller 4th) but then we'd lose torque in 1st. So the best way to overcome the 2nd gear lag is to build the motor and reduce the mass that the engine has to move.
http://www.quaifeamerica.com/downloads/QSpeedCalc.exe
right click > save as*
find your gear ratios somewhere on this site, put in your tires size, and play with it.
or there's probably gear shift post somewhere on the forum...
joeymia
Jan 9, 2006 04:59 AM
