tricks on removing this motor mount
Old Jul 12, 2014, 04:26 PM
bowlofturtle's Avatar
So i'm doing, well trying to get this rear roller mount off.
I'm a little weakling.
So i got the cross member off with my impact and did the front roller with no problems.
I got the 14mm that holds the rear roller off, that took forever.
I got the upper 17mm on the bracket off using a breaker bar but i fit my breaker on to the lower 17mm. Also the 14mm that holds the mount down, the 2 fronts are easy, the rear pass side is easy cause i can get it on top. But that driver side one is blocked the sway bar and PS lines. I can someone get a open end wrench but no leverage to turn and depending on how long that bolt is, the sway bar blocks me.
I'm stuck at the last 14mm driver side mount bolt and the 17mm bracket bolts. Any tips on getting this off or should i just take it to the shop. I would love to somehow fit an impact in there but no space.
anthonypazsd
134
Jan 19, 2024 11:48 PM
Juan Martinez
Lancer How Tos / Installations
20
Dec 23, 2013 06:27 PM
VADER X
Evo X How Tos / Installations
22
Oct 5, 2012 09:41 AM
urbanknight
Dec 15, 2006 12:26 AM
urbanknight
16
Feb 14, 2005 08:21 PM
Quick Reply: tricks on removing this motor mount
