Catalytic Converter Issues!!!!
hey guys first off i drive an 03 lancer es. i recently had a check engine light come on so i took it to get checked and the reading that came up was that my cat was clogged, which makes since because the car has been showing all the symptoms of a clogged catalytic such as needing to be in really high rpm's before switching and strange rattling sounds while accelerating. my question is....
1.) can i just remove the cat altogether and just straight pipe to a muffler? if not why?
If it is the 2nd cat ( under car ) you can get a Magna Flow Cat for it for around $100. It will cost about $30 or $40 bucks to have it welded in.
If it is the front cat ( headers ) you might* find a shop that will replace that cat, if not you will have to buy the header assy. which is around $299 to $325.
If you do it right, you car will last longer and run better. Deleting cats/mufflers are not what it was designed to do.
You can, but it's not legal. Not good for the environment either. Smog regulations are there for a reason.
Last edited by Lancerprobs; Jul 23, 2014 at 04:57 PM. Reason: adding more information
I don't think I can Pm because my account is new. Either try PMing me or reply to this message. But I'm in California, how much are you looking for shipped?
PCToolsWiki
May 26, 2012 07:00 PM
RNSpeed
Nov 14, 2009 12:09 PM
