A/C Compressor issues
Old May 28, 2014, 04:02 PM
M-Ray90's Avatar
Hello I have a 2002 lancer that the A/C compressor will not engage. I don't believe the compressor is bad. I have checked all the fuses and relays for the system and nothing is burned out. The single wire that goes to the A/C compressor when hooked to a test light gives no sign of having power. I am at a loss have checked everything I can think of. I tired charging the A/C and the compressor worked for a little bit then just stopped. Is there a common system short? Thanks for any feed back in advance.
Old May 28, 2014, 05:42 PM
marcouxa1's Avatar
Does your compressor engage when you jump your relay with current?
Old May 28, 2014, 05:51 PM
meckert's Avatar
if the system ran with a mild charge then went out---you have a system ac Freon charge issue...if the Freon is too low it wont come on. If its clicking in and out, off and on with a small charge you need more for it to engage and stay on.. go vacuum the system and recharge and it will work.
Old Jan 29, 2021, 02:04 PM
Ronald Brain's Avatar
I bought a 09 lancer gts in Phoenix where it was 110 degrees but the only way I can get to compresser to stay on is to over charge it almost 100psi it’s ice cold and stays on for a good amount of time I dunno I think it might be a compresser bearing I can definitely feel it in the car when it kicks on cuz it’s way overcharged
Zhakkee
Jun 10, 2020 12:21 PM
zstryder
Sep 10, 2012 09:48 AM
lucky_evo
Sep 1, 2010 07:54 PM
BadBoyBeltran
Jul 24, 2009 09:00 PM
J8dailo
Aug 3, 2007 08:55 PM
Quick Reply: A/C Compressor issues
