Poping sound when turning
Check your ball joints, that's the cause most of the time. The other possibility is the splines on your halfshafts. If they're worn you'll get popping from making really sharp turns, but not from easy ones. The halfshafts actually pull out of the gear a bit when you make turns, that's why the cv boots work like an accordion. When you make a left turn the right halfshaft pulls out a bit and the left pushes in, and vice versa.
atombomb33
Southeast Region
6056
May 29, 2020 12:03 PM
