the outside temp is not showing (08 GLS)
Old Mar 5, 2014, 03:21 AM
The tracker's Avatar
Hello
i am having a problem with the outside temp sensor as its now showing in the dash here is a picture
Attached Thumbnails the outside temp is not showing (08 GLS)-photo-mar-05-12-36-33-pm.jpg
Old Apr 7, 2014, 06:54 PM
CamShaft's Avatar
sensor or wiring to the ambient temp sensor it failed. Find the failure.
Old Apr 8, 2014, 12:31 PM
Thank you for replying but where can i find the ambient temp sensor?
Old Apr 14, 2014, 08:27 PM
CamShaft's Avatar
here
Old Apr 15, 2014, 04:04 AM
here
I kept looking but it was nowhere to be found, probably the previous owner uninstalled it for some reason, is there anyway to install new one? and if i will install new one, where should i connect it to.
thanks
Old Apr 16, 2014, 06:31 AM
CamShaft's Avatar
thanks
Did you remove the headlight support assembly and the front bumper then look?
Old Apr 16, 2014, 08:46 AM
Veronica's Avatar
'if' the PO removed it - there should 'still be' a connector behind the bumper cover...
If not - the wiring harness may still be there (but be cut). Go to Ebay/get one used with pigtail and splice the wires....
Old Apr 17, 2014, 04:16 AM
no i didn't remove the headlight but i did check the area, ill try removing the bumper.
i will also look for a used ambient temp sensor
Old Apr 23, 2014, 04:46 AM
I think i found it, it was taped to other wire, excuse the dirt ><
so what should i do now?
Old Apr 23, 2014, 06:50 AM
Veronica's Avatar
Do you have a friend that would let you swap the sensor? (to see if that fixes it?)
If not - I would buy a new sensor (after inspecting the wires/connector).
Old Apr 23, 2014, 08:22 AM
unfortunately i don't have a friend with a lancer so i think my only method is buying new one the problem is i couldn't find any in ebay, would you please help me look one up?
Old Apr 23, 2014, 09:14 AM
I took a picture while dis attaching it, can you please make sure it is actually the ambient temp sensor
Old Apr 24, 2014, 05:13 PM
CamShaft's Avatar
I don't know if that is it 100%. But, if that is in the area like the diagram shows, then I bet it is.
Do you have access to a multimeter? If so, the test the sensor and see what resistance it shows vs the ambient temp, use the diagram I provided in the 4th post (don't hold it in your hand while testing, this will throw the temps off)
If the sensor is out of range (and the connector pins are clean and have good pin tension!!!) then I would get a sensor from mitsubishi, this is probably your only option.
If you sensor is not out of the range, then you have to test the wiring from the sensor back to the dash, this will require electrical schematics and a bit of knowledge on the system.
Old May 1, 2014, 12:45 AM
i couldn't test the resistance cause it only had one wire connected to it.
Old May 31, 2014, 09:27 AM
CamShaft's Avatar
well according to the schematic, you should have two pins.
RalliartN
Jun 24, 2015 12:00 PM
Outie11
Outlander Sport
Jun 6, 2013 11:20 PM
Dbzguy
Feb 17, 2013 07:25 AM
SFL Autosports
Evo 'For Sale' Electronics / Lighting / Audio
Dec 21, 2011 06:08 PM
IS2000
Oct 5, 2005 10:59 AM
Quick Reply: the outside temp is not showing (08 GLS)
