the outside temp is not showing (08 GLS)
Did you remove the headlight support assembly and the front bumper then look?
i will also look for a used ambient temp sensor
unfortunately i don't have a friend with a lancer so i think my only method is buying new one the problem is i couldn't find any in ebay, would you please help me look one up?
I don't know if that is it 100%. But, if that is in the area like the diagram shows, then I bet it is.
Do you have access to a multimeter? If so, the test the sensor and see what resistance it shows vs the ambient temp, use the diagram I provided in the 4th post (don't hold it in your hand while testing, this will throw the temps off)
If the sensor is out of range (and the connector pins are clean and have good pin tension!!!) then I would get a sensor from mitsubishi, this is probably your only option.
If you sensor is not out of the range, then you have to test the wiring from the sensor back to the dash, this will require electrical schematics and a bit of knowledge on the system.
RalliartN
Jun 24, 2015 12:00 PM
SFL Autosports
Evo 'For Sale' Electronics / Lighting / Audio
Dec 21, 2011 06:08 PM
