Engine Noise After timing belt, normal?? Please help
Old Sep 23, 2013, 12:45 AM
BlueGoat's Avatar
So I completed the timing belt job on the 06 Lancer and it's making a odd noise. Loud ticking. It's been so long since I've heard the car run I'm not sure if its normal or not? The noise does not get louder when I rev the motor so I don't think its a bent valve.
So here is the video I promised lol. The car hasn't exploded yet but.....
http://s800.photobucket.com/user/Blu...tml?sort=3&o=0
Old Sep 23, 2013, 11:59 PM
BlueGoat's Avatar
So I just took the car on it's first test drive and it seems to drive fine. I have blown a rod in my Nissan before and it was obvious, you could feel it when driving. Lancer seems to drive just fine no knocking just a loud whine/hum noise, similar to a bad bearing on a pulley (checked the pulleys all seems well. Besides that noise there is the usual loud ticking (near the injectors) any idears? I'll post a video of a test drive.
Old Sep 24, 2013, 06:19 AM
cfdfireman1's Avatar
Adjust the valve clearance, how many miles has it been since you did it?
Old Sep 24, 2013, 07:46 AM
eusgen's Avatar
Could be a lifter!
Old Sep 24, 2013, 07:52 PM
BlueGoat's Avatar
""Adjust the valve clearance, how many miles has it been since you did it?""
I just did it lol. Hasn't even seen half a mile.. What do you mean adjust the valve clearance? Remove the belt and adjust it?
I'm stuck... guess I could take it to a shop and see what they think.
The 2.4 Ralliart motor will fit this with some minor modifications correct?
Old Sep 24, 2013, 08:44 PM
Automatic 51's Avatar
If its a whine that changes with engine rpm, especially under load, it could be the tension on the belt if too high. It would make a supercharger type whine.
If its a louder ticking: did you change valve cover gasket also? If that's not torqued propperly then it might have a small leak around that.
I tried to watch the video but it isn't showing up on my phone.
Old Sep 25, 2013, 09:23 AM
You did timing belt, did you measure and adjust the clearance between the top of the valves and the rocker arms?
Specs are supposed to be;
Intake valve: 0.20 mm (0.008 inch)
Exhaust valve: 0.30 mm (0.012 inch)
Old Sep 25, 2013, 08:13 PM
BlueGoat's Avatar
Image wouldn't show up. I'm going to take some tension off the timing belt see if maybe its to tight and re-check everything. Next I guess I'll do a compression and leak down test.
Could you re-post that pictures? cfdfireman1
Old Sep 25, 2013, 08:52 PM
BlueGoat's Avatar
Thanks for the repost of pic, still won;t work though now I just get a loading screen that sits for 20minutes. Sorry not sure whats up
Old Sep 26, 2013, 04:52 AM
Try this or search for valve lash adjustment. It sure sounds like those valve clearances are out of spec.
MyronGainz
Aug 14, 2019 03:54 PM
babaz7
Oct 2, 2017 05:22 PM
orion4096
35
Jan 25, 2016 03:37 PM
evo_k
Pacific Northwest
18
Jan 10, 2015 07:56 PM
tim85851
11
Dec 10, 2011 09:42 PM
Quick Reply: Engine Noise After timing belt, normal?? Please help
