2002 OZ Rally A/C Blower and A/C Clutch - strange behavior
Good evening all,
I'm really puzzled by the electrical issue I'm having with my wife's 2002 Mitsubishi Lancer. It's got a 120,000 miles and we've owned it since new. It has had almost zero problems up until this point.
The other day, my wife calls and says that her A/C isn't working, it's just blowing hot air. When she got home, she turned the car off, removed her key, and noticed that the climate control blower was running. She turned it off and went inside.
When I came home, I verified that with no key in the ignition, turning on the blower motor switch did turn on the blower motor. I started the car and immediately noticed both the condenser cooling fan and the engine cooling fan both immediately started running. I turned on the A/C, got nothing but hot air, and verified that the compressor was not turning.
I turned the car off and decided to check for fuses. When I pulled the A/C fuse under the hood, I heard a loud CLICK from the A/C compressor area. When I reinserted the fuse, I received another click. I then pulled out the A/C compressor clutch relay, and heard the same click. Since I wasn't sure if it really was the A/C clutch, I asked my sister-in-law to plug in and unplug the relay while I put my hand on the compressor. She did it several times and before I could verify it was the A/C clutch...it stopped. At this point, unplugging the A/C compressor relay would not cause the click. Also, unplugging the A/C fuse would not cause the click.
I then turned on the blower motor (key still off!) and it didn't start running. I started the car, and the A/C worked fine! So I drove 50 miles back and forth to work the next day and figured it was some sort of fluke.
This morning I get a call that her battery is dead. I get home, put the charger on it, and as soon as the voltage came up a little, there was the click from the A/C clutch. Unplugging the A/C clutch relay caused another click. Relay in - click. Relay out - click. Same with the A/C fuse. Then, like before, plugging the relay or fuse back in no longer caused the click.
I do have the service manuals and looking at the wiring diagram...the blower relay coil can only get power with the key in ACC or RUN. The A/C clutch is more complicated...it gets power from the SAME source - the ACC or RUN position on the ignition switch. But, ground is through the engine management computer (car is a 5-speed).
The only thing that seems to be common and could explain everything would be a bad ignition switch - the blower and A/C compressor power, plus the engine management computer all seem to be on the same contact on the ignition switch. HOWEVER, the service manual ignition switch schematic is very confusing and it is not clear if there are really different sections to the switch, or if their method of drawing it is very non-standard.
Any thoughts? I don't want to throw parts at it...but that seems to be the only thing that makes sense?
thanks much,
Ben
thanks much,
Ben
jdrames
Lancer Troubleshooting
Mar 25, 2021 10:35 AM
lghtngyello03
10
Jul 22, 2016 03:26 PM
S3CR3T
Jun 14, 2013 06:15 PM
