2002 lancer OZ lose power high RPM
Old Aug 18, 2013, 07:16 AM
mitsu140's Avatar
Question 2002 lancer OZ lose power high RPM
I notice few days ago tha when my lancer 02 hit pass 3/4 rpm lose power like if something stop the air or fuel flow but when i release the gas for a second and accelerate again the problem stops. I had replace the the head gasket and also took head to machine shop to get fix. But this problem happen like a month after the head and cylinder were fix. I had took it to the mechanic and e says tha may be the exhaust monifold he also notice tha the crank pulley wooble a little bit. Also notice a ticking sound on the engine bay. Thank you so much any ideas of whats wrong with the car will help. 2002 mitsubishi lancer Oz
Old Aug 18, 2013, 09:14 PM
03lances's Avatar
First thing I would do is pull the belts off the crank pulley and see if its loose. Then I would get your cat checked to see if it is clogged. I would also check your fuel strainer on the bottom of your fuel pump and run some injector cleaner through. Usually the symptoms you are experiencing have to do with either lack of fuel or blockage in the exhaust.
Dallas02ozRally
27
Nov 18, 2023 11:38 AM
mitsu140
Lancer Troubleshooting
Sep 21, 2012 12:03 AM
negrito 18
Aug 9, 2009 07:10 PM
negrito 18
Lancer Aftermarket Forced Induction Tech
Jul 29, 2009 09:34 AM
negrito 18
Lancer Engine Management / Tuning Forums
Jul 18, 2009 07:35 PM
Quick Reply: 2002 lancer OZ lose power high RPM
