idling Problem
Old Jul 12, 2013, 07:30 PM
ittick's Avatar
idling Problem
I have a 2002 lancer es, and it has a strange idling problem that I cant figure out. normally she idles between 500 to 1000 RPM, But when she warms up she starts to idle high, as high as 3000 RPM. I figured it out as far as the throttle, its like something is sticking as it warms up. if you pull out on the gas peddle while shes idling high, it stops and goes back to normal, until you push on the gas peddle again. I took off the throttle cable and just had her idling for a while and it never idled fast. Can someone please help!
Old Jul 13, 2013, 09:37 AM
Automatic 51's Avatar
The throttle cable is binding up inside of the sleeve, its not an uncommon problem. Either keep pulling up on the gas pedal when it happens or replace the throttle cable.
Old Jul 16, 2013, 12:57 PM
ittick's Avatar
Thanks, I will let you know if it works when I manages to get a new cable.
Old Jul 16, 2013, 08:58 PM
03lances's Avatar
Before you buy a cable try just leaving slack in the line. Reconnect the cable and make sure you position the bracket so that there is slack when at idle. This may solve your issue too its worth a shot to try before buying a new cable
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
TurboTJ
Jan 29, 2018 08:22 PM
3gturbo
Dec 22, 2015 03:15 PM
Evo47
May 4, 2015 08:53 PM
PINK LANCER
Lancer Engine Tech
Nov 9, 2013 08:11 PM
Quick Reply: idling Problem
