LED Strip Lights Q
LED Strip Lights Q
I installed a small yellow LED switch next to the dimmer wheel,and the one strip of LED lights I currently have installed have been running off external batteries. The strip lights I purchased have positive and negative wires and that connects to positive and negative terminals on te battery pack. My first question is where would be te best place in that area to wire these switches in, and what wires exactly would I solder or crimp them to? Also, the switch has 3 prongs positive negative and ground and it has an LED light inside it that lights up yellow when it's flicked on. Do I need to ground the switch? I own a 2002 OZ Rally. Thank you.
I was told to wire it to an empty slot in the fuse box but I don't know enough about wiring to know exactly how to do that and keep the proper amount of voltage without blowing the fuse because I plan on running at least 4 different strips of LED off this one switch if not more. They're only 12V strips I believe. I was also told to run it straight to the battery but that seems a little hazardous and unnecessary. We most likely have the same spot we would need to wire to considering if your lancer didn't come with fog lights stock there would be no fuse ready made for fog lights.
I have LED strips in the driver and passenger side, by where your feet are. I have them wired to the cigarette lighter ring light so that they only turn on at night when i flip on my headlights. I also also wired them to a on/off switch in the event that I don't want them on for whatever reason.
The cig lighter light is regulated by the same fuse as the the ash tray light and corner marker lights (on the side of the headlights). You can swap out the 10 amp (i think that's what amp it is) for a 15 amp fuse. However, I ran it light this for years before the fuse gave out recently and i just replaced with a 15 amp, no issues
I guess the only difference would be that I would only lose my LED strips if I blow the fuse as opposed to blowing my cig lighter and ash tray and side lights but its probably more trouble than its worth to dedicate a fuse. I'm probably just gonna do exactly what you said lol.
As far as the switch goes, I put mine beside the dimmer switch. I ran a wire directly from my connection to my fuse box under the hood. I bought a 12 gauge wire and soldered in a fuze connection that had the same gauge wire. Radio Shack has a lot of different connections for fuses. I wired this to the positive on the switch. Then I took the ground connection and wired it to a good connection on the chassis. Make sure you don't use a connection where there is paint. After that, take the ground from your lights and connect it to the chassis as well. Preferably same place as previous step. Finally connect the positive on your lights to the 3rd prong on the switch.
E46byeRAhi
17
May 19, 2017 04:26 PM
TxFAkuma
13
Jun 22, 2016 08:53 AM
Pal215
10
Jan 19, 2016 04:23 PM
