changed plugs and now running rough
Old Mar 27, 2013, 04:51 AM
mhorn0817's Avatar
06 lancer es with 97k miles. Changed plugs yesterday and put in autolite 3924 copper. Supposed to be oe spec plugs. Gapped them to .40 per the manual (.39 - .44). Started car and ran great. Drove the car latrr and started running rough and threw a cel. Everything is tight and connected. What could the problem be? Also i noticed when i pulled the plugs out that were in car, they were gapped between .60 - .80 which i thought was weird...any help would be great. Thanks
Old Mar 27, 2013, 06:54 AM
eusgen's Avatar
autolite who? get NGK!
Old Mar 27, 2013, 06:57 AM
Automatic 51's Avatar
I wanna say oem plugs are iridium, not copper. What error code is the car throwing? Did you use dielectric grease on the plug boots when you reassembled everything? And while you dont wanna over torque the plugs, make sure they werent too loose and backed out. That can cause issues too.
I agree, NGK iridiums have worked grear for me.
Old Mar 27, 2013, 07:10 AM
mhorn0817's Avatar
Yes i know now i should have went with ngk. Either way advanced auto said these were oe plugs. So whether autolite or ngk i should not have this problem. And eveb autolites website say these are a oe plug or atleast .simething like it. Im going to pull code ib about 2 hrs. No i didnt use grease but still saw sone on boots. They werenice and tight as well. Also why would the pkugs in the car be gapped at .6 - .8 and its supposed to be .4?
Old Mar 27, 2013, 07:16 AM
With the iridiums you dont gap them so i dont have any experience gapping anything.
Old Mar 27, 2013, 07:19 AM
twabtoxer's Avatar
Go getsome NGKs
Old Mar 27, 2013, 07:27 AM
mhorn0817's Avatar
Either way the car should not be running rough and throwing a code with these plugs
Old Mar 27, 2013, 10:42 AM
mhorn0817's Avatar
Looks like ill be picking up some ngk... cel was p0302. Misfire in cyl 1. I put the original plugs vack in and it runs fine now
Old Mar 28, 2013, 01:02 AM
Ellimist55's Avatar
That codes for a misfire on cylinder 2 not cylinder 1
Old Mar 28, 2013, 04:36 AM
mhorn0817's Avatar
I meant 301 not 302... which cyl is number 1?
Old Mar 28, 2013, 06:33 AM
Cylinder 1 is closest to the timing belt
Old Mar 28, 2013, 07:03 AM
mhorn0817's Avatar
So cyl 1 is all the way on left...looking at the motor
Old Mar 28, 2013, 10:30 PM
Unless I am mistaken yes
Old Mar 29, 2013, 10:16 PM
Evo Goblin's Avatar
I think like a software engineer...
try swapping one of the other spark plugs from the other 3 cylinders to cylinder #1 and see if you still get the same error code.
This should tell you if that one plug is bad, or not in all the way?
-Rob
Old Mar 30, 2013, 12:19 AM
ambystom01's Avatar
Buy a plug gap tool. Check gaps and re-gap if necessary.
ranicx
Feb 26, 2017 07:49 PM
Evo47
Apr 10, 2016 01:00 PM
kambodianboi
Oct 6, 2010 08:13 PM
Oracle1
Mar 30, 2008 09:57 PM
hawkmoon
Lancer Troubleshooting
13
Jan 26, 2004 11:36 PM
Quick Reply: changed plugs and now running rough
