Huming noise when driving 60+mph
Yep so when i drive 40 mph or more the passenger front tire side makes a weird humming noise. Im getting new tires this week and hoping that it fixes the problem. Any suggestion?
its auto and it cant be the tires got four new ones the other day. Im assuming it gotta be the hub or wheel bearing. The noise is coming from the passenger tire side. I did a quick tire shake test and everything was nice and tight =\
Okay Fixed!! Did tire test, no movement in the tires at all. Jacked up both sides and spin the tires and feel the springs. If theres play in the springs then the bearings are bad. Did that to both sides and the right side springs was moving alot. Took it to the shop and had it replaced and BAM! All the annoying suspension growling noise is gone. All together the cost was $160. They only charge labor if you bring your own parts so thats a +. I bought the bearing from oriellys auto parts for $20 and some change. So hopefully it lasts for a while.
N33d4sp33d
11
Oct 25, 2013 11:58 AM
Noize
21
Jan 4, 2012 09:22 PM
millsyy17
34
Jun 6, 2010 09:11 PM
