Lancer Horn
Old Jul 9, 2012, 08:39 PM
DJ Icy Diva's Avatar
Unhappy Lancer Horn
Hey Guys,
my horn has stopped working. It's not the physical horns as I had those replaced earlier this year. My thought is that it is the connection between the steering wheel horn sensor and the wire that travels to the horns.
Does anyone know how difficult/easy it is to get at the horn sensor, and if the airbag needs to be removed?
Any helps is greatly appreciate!
PS. When I press the horn, nothing happens... it was sticking for a while, but now, nothing.
Old Jul 10, 2012, 02:29 PM
03lances's Avatar
Try checking fuse? Yes the airbag needs removed. Easy to do just make sure you diisconnect the battery and let it sit for at least 10 mins before messing with it.
Old Jul 10, 2012, 07:57 PM
Thanks for the reply. I will definitely check the fuse before taking anything apart. Hopefully it's a quick fix.
Keeping my fingers crossed!!!
PS. Do you know if there is a how-to on how to remove the airbag?
Old Jul 11, 2012, 03:58 PM
03lances's Avatar
Not sure if there is a how to but its pretty straight forward. Disconnect the battery and let it sit for a little bit. Then there is a little panel on the side of the steering wheel you can pop off that gives you access to disconnect the airbag electrical connections and the horn its 2 or 3 bolts either 8 or 10mm IIRC. you have to access from the back of the steering wheel. You may find your problem by simply pulling off that panel and shining a light in there to see if it came unhooked or something.
inslowoutfast
Apr 21, 2017 06:19 AM
Ernest Latcher
Jan 4, 2017 06:31 AM
Ernest Latcher
Jan 3, 2017 09:40 PM
paintballproam
May 25, 2008 03:43 PM
8th_Sin
Dec 25, 2004 02:56 PM
Quick Reply: Lancer Horn
