Damn radiator...!!!
Damn radiator...!!!
So after extensive googling of the 'net and this forum,I still have yet to find a solution!
My 2006 lancer Ed overheats only after idleing for about 30-40 mins, a little bit faster if I turn A/C on. I checked for fuse problems, but Ive never had any fuses in the spots that shows where they should be on the diagram, as far as relays and things of that sort, what process do I go through to see what's broken, or should I just replace em all
More than likely the culprit is the fan relay. They're notorious for going out. Also your radiator cap could be shot.
Turn on your ac and see if your fans turn on. MAKE SURE IT DOESN'T OVERHEAT! If it starts getting high turn on your heat to the max. You don't want to deal with a warped head.
dmik
Lancer Troubleshooting
12
Nov 20, 2021 09:12 PM
czapski
Nov 26, 2008 07:01 PM
