Amp install - volume doesnt effect subs
Old Jan 19, 2012, 09:10 AM
justyntime's Avatar
Hi, I installed an extra amp to power additional subs using the technique found in the how to. I used a soche hilevel to low level converter and everything works BUT when I turn the volume down, it doesnt alter the volume of the subs at all. What did I do wron? Or is that just how it is?
Old Jan 19, 2012, 09:49 AM
Veronica's Avatar
check the gain on the amp. Turn it down if it is maxxxd.
Old Jan 19, 2012, 10:58 AM
justyntime's Avatar
Nah that not it. Im saying even with the volume at 0 theres still sound coming out of the subs no matter what the gain level.
Old Jan 20, 2012, 05:55 AM
Veronica's Avatar
Is it music (sound) or just rythmic movement of the cones (spurious signal)?
How loud?
Does it do it with the radio off? Then stop if engine off?
sirsleepsalot
May 29, 2013 06:15 AM
nsxiphos
Mar 7, 2012 10:23 PM
DMuhny
Aug 18, 2011 02:27 PM
Waz996
Jun 21, 2011 09:29 AM
bboy_RES
Feb 1, 2008 03:05 PM
Quick Reply: Amp install - volume doesnt effect subs
