2013 lancer DE no start with key
Old Aug 7, 2018, 01:27 PM
william5353's Avatar
Question 2013 lancer DE no start with key
ok, HELP please I have a 2013 Lancer DE I got the motor hot so I removed it and tore it down and built it the way I wanted it. it was apart for quite some time, well its all back together now but I have one problem won't start everything turns on but key won't start it I can put a power prob on the starter and it will fire write up the clutch switch works fine on the ign switch the green wire powers up when in the start position so i am assuming that its good does anyone know the path from starter to ECU and what wire it is going into the ECU from the starter, and from ECU through firewall to ign, than I could at least find out what side of the ECU to look toward. I do need help soon, so for faster communications, you can email me at btucker@creekenterprise.com anything would help
