Yes, in order to get rid of the check engine light, you would need the eliminator. As for the high flow cat, it doesn't hurt to have one, but it won't fix the code unless you have the eliminator. And just a heads up, the eliminator would go on the 2nd cat, after the downpipe.
For the P0135 code, could be the following:
•O2 Heater element resstance is high
•Internal short or open in the heater element
•O2 heater circuit wiring high resistance
•open or short to ground in the wiring harness
Possible solutions:
•Repair short or open or high resistance in wiring harness or harness connectors
•Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)
