Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Troubleshooting
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 2, 2009, 08:55 PM   #1
Personal Sales Rating: (4)
Drives: 03 Lancer Es
Fuse Problem! need help asap.
okay so i have two fuses that keep burning out. my horn and the emergency flashers which also control the turn signals there both 10a fuses and they keep shorting out within the day. ill replace it in the morning and by midday theyll burn out. i do not know what the problem is. at first it was just my horn. but 2 days ago my flashers fuse went out. i replaced it and within the end of the day it was out again? what could possibly be causing this to happen??!
Offline
Old Sep 2, 2009, 10:55 PM   #2
JRR
2003 Mitsubishi Lancer
JRR's Avatar
Drives: 2003 turbo OZ Greddy Boost Controlled at 11psi!
Send a message via Yahoo to JRR
id check the wires. you might have a cut somewhere or just grounding out where it shouldnt be grounded.
__________________
JR - "OK so maybe it isnt an EVO, but at least it is faster than YOURS" Quote from me to a guy with a subaru!
03 Custom Turbo Build
Base Lancer To Evo Compatibility Thread
FOR SALE:
evo parts, turbo fuel, and other things laying around the garage
Online
Old Sep 3, 2009, 01:44 AM   #3
Personal Sales Rating: (13)
03lances's Avatar
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
I did some work on a mercury that had its turn signal fuse keep burning out. Thing was for their car that fuse happens to also connect the shift lock on the automatic so no turn signals means you couldnt put it in gear!!!!! and there was no manual release for it. Long story short try pulling your reverse lights to see if one is grounding out, this was the case on that particular car .
__________________
16G Turbo build:
Build completed tuning time
Offline
Old Sep 11, 2009, 01:16 AM   #4
Personal Sales Rating: (0)
Drives: 04 Lancer OZ
make sure the fuses are the appropiate amperage.. itll save you tons of time :-) .. if all else fails switch to a higer amp fuse, if that still fails then its a ground for sure!
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
