Aug 28, 2009, 05:05 PM
Personal Sales Rating: ( 0)
Drives: White lancer GTS
ddm tuning hid kit
I just bought a 55w 8000k from ddm tuning. My problem is When my car is moving already the headlight won't turn on and even if i park my car it won't turn on. then what i did is turn off the engine of my car and take out the keys in it. then turn on again my car. then the headlight works! i dont know what should i do. anybody help me please? thanks so much.
Offline
Aug 28, 2009, 05:13 PM
Drives: 09 Lancer GT
Does your headlight turn on when you first start your car?
If you dont have a relay then thats why they arent turning on. The HID ballasts need a constant voltage. If you dont turn your headlights on all the way before you put it into gear then your DRLs (day time running lights) are kicking in. Your DRLs require less voltage then HIDs and the ballasts are switching of to protect your bulbs from damage.
Either turn your lights on all the way before you put it into gear or get the relay harness and this will solve your problem.
Use the search button as well because this is a common topic.
__________________
09 GG GT Lancer
Apexcone 6000K HID
Evo X CF hood
RRM CF diffuser
18 Tenzo M1 w/ HTZ III
Ingalls Camber Kit
Rays Lugnuts
Eibach Sportline
Ralliart Tails
Sparco Shifter
VG Shark fin
30% Solarguard tint
Pioneer 700bt w/ Siruis
Lamin-X Headlight tint
Offline
Aug 28, 2009, 06:04 PM
My headlight is not turned on before I start my car. I start my car then turn on the headlight.
But when I put it in gear first before turning on the headlight maann it won't work.
Offline
Aug 28, 2009, 06:16 PM
Its the DRLs man lol. They cut in when you start driving or put it into gear.
Turn on your car, turn your lights all the way (two clicks) then put it into gear. If you switch them off while driving the only way to turn them back on is switching off your car.
Get a relay harness from DDM. Mine are from DDM and do the same thing.
__________________
09 GG GT Lancer
Apexcone 6000K HID
Evo X CF hood
RRM CF diffuser
Ingalls Camber Kit
Rays Lugnuts
Eibach Sportline
Ralliart Tails
Sparco Shifter
VG Shark fin
30% Solarguard tint
Offline
Aug 28, 2009, 06:25 PM
oh sheez bro you are right. the only way to turn it back on is to turn off the car! you're a genious bro! thanks very much! that helps alot!
Offline
Aug 28, 2009, 06:30 PM
Personal Sales Rating: ( 14)
2005 Mitsubishi Lancer Evolution
Drives: 2005 Evolution 8, DD 92 Camry
Did you upgrade the fuse from 10AMP to 20AMP?
__________________
Tomei ARMS/HKS 272s/HKS SMF Intake/ARP HStud/Mil.Spec/PTE880/Megan O2/Buschur Mani/3"TBE/Walbro/Hallman/Injen Intake Pipe/3"FMIC/Synchronic BOV/WORKS XC8
EvolNinja
Tuned by 4WS Tuning
Offline
Aug 28, 2009, 06:34 PM
Quote:
nope. nothing like that. I just perfectly installed the hid kit. thats it
Offline
Aug 28, 2009, 06:40 PM
Are you replacing the low beam or high beam? I think it's the same as when I did mine. I had to replace the fuse to the low beam from 10 to 20 amps. GL! By the way, how much did you buy your kit for?
__________________
EvolNinja
Tuned by 4WS Tuning
Offline
Aug 28, 2009, 08:58 PM
^ only really need low beams with HIDs, Did you upgrade the fuse on an 08 or 09? DDM has digital ballast that cut out when the voltage dips from DRL's.
http://www.ddmtuning.com/index.php?p...=101&parent=60
$65 for the digital 55W slim ballast. had these for 1.5 years and still running great.
__________________
09 GG GT Lancer
Apexcone 6000K HID
Evo X CF hood
RRM CF diffuser
Ingalls Camber Kit
Rays Lugnuts
Eibach Sportline
Ralliart Tails
Sparco Shifter
VG Shark fin
30% Solarguard tint
Offline
Aug 28, 2009, 09:01 PM
i didn't upgrade the fuse. i have an 09 gts. do you think I need to?
Offline
Aug 28, 2009, 11:34 PM
No, never head of this. HIDs draw less power from the car so it will never blow the fuse. The ballasts do all the work by bumping up the wattage.
__________________
09 GG GT Lancer
Apexcone 6000K HID
Evo X CF hood
RRM CF diffuser
Ingalls Camber Kit
Rays Lugnuts
Eibach Sportline
Ralliart Tails
Sparco Shifter
VG Shark fin
30% Solarguard tint
Offline
Aug 29, 2009, 11:44 AM
Personal Sales Rating: ( 11)
Drives: Traded: WW 2008 Lancer GTS || Upgraded: WW 2009 Lancer Ralliart
Check out my sig. It will get resolve your issue.
Offline
Tags
ballast, ddm, evo, evolutionm, gts, headlights, hid, hilow, install, kit, lancer, las, put, tuning, vegas  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
