Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Troubleshooting
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 26, 2009, 06:14 PM   #1
Personal Sales Rating: (0)
Solofantasy's Avatar
Drives: 2009 Lancer GTS 5spd
Question HID Harness help will be great!
Yo guys, I have search over and over, read over and over on this forum about HID harness. Now I bought 9006 HID Harness with relay+fuse from ebay. Now, I am not sure about the remote turn on control. It suppose to work with just the power source I have with HID. When it switch to position 3 on light control, it suppose to have 12V. But mine is just not turning on at all after installing harness.
I don't know the difference between the sidemarker and the fully turned on lowbeam source. They all both suppose to be 12V, should be enough to trigger "remote turn on".
I have each power wires attached to each Ballast. Connected to battery. Remote turn on does not work with OEM lowbeam source at fully turned on position.
I know some of you guys used sidemaker power on harness, but I dont see the difference... can someone explain! please. thanks!
Offline
Old Aug 27, 2009, 06:51 PM   #2
ok, not its working, but still doesn't eliminate the the flickering problem caused by DRL. Grr. The product!! THEY LIED! eliminate flickering due to low voltage my ass!
Offline
Old Aug 27, 2009, 06:56 PM   #3
Personal Sales Rating: (11)
2002 Mitsubishi Lancer
02-Lancer-Es's Avatar
Drives: Lancer
Pm'd
__________________
My car
Online
Old Aug 27, 2009, 06:56 PM   #4
2008 Mitsubishi Lancer
evo_soul's Avatar
Drives: Lancer 2008 GTS
Well the Relay will help your HIDs ignite and keep voltage stable.
But I am not sure about these fuses. XenonDepot and I am sure other HID companies have something called CANBUS FIX which is what eliminates the antiflickering. I think in some ways it acts as a capacitor. So even in situations of under supplied voltage, it maintains a steady stream.
That said, your situation is still salvagable, you just need to go out and find a good anti flicker CANBUS fix. It should be also a plug and play solution. and not involve cutting or splicing of wires.
if you need more help let me know.
Cheers
__________________
Current MODs:
XenonDepot 3000k (Low) - Injen CAI - Custom 2.25" Dual Exhaust - Side License Mount - HOS Urban Fr and Rr Lip - Tints: 22% 5% - LED Side Mirror - 18" MSR Style 045 - Scorpion V-LIP - 3 Piece Spoiler - ASW 4-2-1 - KVR CF Brake Pads - KVR J Hook Rotors (Silver)
Next:
XenonDepot HID 3000k (fog) - ASW Engine Dampener
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."
Offline
Old Aug 29, 2009, 11:43 AM   #5
jRox's Avatar
Drives: Traded: WW 2008 Lancer GTS || Upgraded: WW 2009 Lancer Ralliart
Send a message via AIM to jRox
Check out my sig. It will get rid of the flickering issue caused by the DRL's.
__________________
////////// FS: DRL Bypass w/ Relay Harness
Offline
Old Aug 31, 2009, 11:52 AM   #6
I won't have the $60 to spare. But it sounds really tempating.
But I just basicly tapped into Sidemarker for now. It works.
I might just use the unused OEM 9006 harness convert to FOG, so it would be Daytime running foglights.
Offline
Old Sep 26, 2009, 10:42 AM   #7
03chi-town0Z's Avatar
Drives: 09 WW Ralliart
Quote:
i put one of these on my ralliart when i upgraded to hid lighting and couldnt be happier, i highly recommend it to anybody looking for a great fix to this annoying and potentially dangerous problem. and the best part, the other harnesses out there only cause the lights to stay on permanently, sort of eliminating the problem but not really. jrox harness completely eliminates the drl while providing a stable, direct power source to the ballasts when desired. that way, you can turn your lights completely off or just have the parking lamps on for when waiting in driveways, etc. so you dont blind everybody in the house or whatever. definitely worth saving up the 60 bucks, plus it shipped to me in 3 days, can't beat that.
__________________
03 LB Lancer OZ: totalled 06-2005
09 WW Lancer Ralliart: bought 05-2009
Back in the saddle again...
Offline
Old Sep 26, 2009, 06:01 PM   #8
jRox's Avatar
Quote:
QFT! Thanks for the positive review and feedback!
__________________
Offline
Tags
2008, 2009, 9006, bus, design, drl, fix, flickering, harness, hid, lancer, make, mitsubishi, problem, relay
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
