Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Troubleshooting
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 24, 2009, 11:03 AM   #1
Personal Sales Rating: (0)
numbers5052006's Avatar
Drives: 02 oz lancer
Question Help... where should this go??
My check engine soon light came on for about 70 miles when I was out of town then went off. As soon as it came on I pulled over and saw this wire, looks like a ground, that must have come loose. For the life of me I cant seem to find where it goes.
Can one of you guys look at yr engine and let me know.
The light has gone out but I don't want this just floating around in there.
Thanks in advance!
mike
Offline
Old Aug 24, 2009, 11:05 AM   #2
1lancer's Avatar
Drives: 06 lancer...
what is that...i don't have that on my 06 lancer....thanks
Offline
Old Aug 24, 2009, 11:11 AM   #3
Personal Sales Rating: (3)
ethan169's Avatar
Drives: 2003 TB EVO VIII
Send a message via AIM to ethan169
Hmm. I dont have a lancer so I can look at mine but it should basically be fine if you connect it to anything solid that is chassis grounded.
On the second picture you provided there is a what looks like small threaded hole by that silver high pressure line (i think) in between the cap that has an H on it and a wire connector on the left. Looks like it could have been there. Find the right size bolt from a hardware store and bolt it up.
It looks like that ground wire connects to the bottom of that unit there. Which if i had to guess would be something with the EVAP or emissions or something like that.
Good luck!
-Ethan
__________________
Tuned by Mellon
Offline
Old Aug 24, 2009, 11:11 AM   #4
Quote:
02 OZ lancer... (I think that is what you are asking)
As for what the wire is, maybe a ground of some sort?
Offline
Old Aug 24, 2009, 11:15 AM   #5
The wire should be grounding something as the other end is bolted onto the bracket/chassis:
Offline
Old Aug 24, 2009, 11:19 AM   #6
ethan169's Avatar
Quote:
Your absolutely right! I guess i didn't look hard enough. I was under the impression that it was not connected to the chassis.
Im not sure then it this case as I have no experience with your model or one of my own to compare to.
Good luck!
-Ethan
__________________
Tuned by Mellon
Offline
Old Aug 24, 2009, 06:25 PM   #7
I think I figured it out... quite a while back I had the timing belt replaced. This should be an engine ground wire, attaches to the timing belt cover. Guess that wasn't why the light came on however....
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
