Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Troubleshooting
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 16, 2009, 10:21 PM   #1
Personal Sales Rating: (13)
03lances's Avatar
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
Blown had gasket changed now low comp??
Ok so changed out a blown head gasket on a 02 es and there was alot of water in the combustion chambers and all over in the head but dipstick is clean just straight oil. put on new HG Timing is correct, new belt as well, comp is reading 50 across the board with one hitting a whopping 70. so my question is I know you can pour some engine oil down the plug hole to see if its the rings that is causing the problem but how much comp gain whould I expect to see if it is the case? The cylinder walls were not looking the greatest but not enough to concern me at the time. The timnig was on when I pulled the belt and put the new one on and got it right the first time so if it is the valves I imagine the coolant must have hydrolocked the engine or something causing it to give
__________________
16G Turbo build:
Build completed tuning time
Offline
Old Aug 17, 2009, 10:14 PM   #2
Personal Sales Rating: (14)
Drives: '03 Evo brain'd Lancer OZ-T
The minimum limit for cylinder compression is 170psi, with a 14psi tolerance of difference between cylinders. At 50psi.... I would start looking for another engine. Adding oil to the cylinder is just a way to test if compression is being lost from the rings or the valve seals. If compression goes up any at all, its the rings. If it doesn't raise, it's the valve seals or possibly the headgasket.
__________________
Evo ECU Swap for 4G94 Lancers: How-To
4G94 Lancer EcuFlash Master Definition List: Download
4G94 Lancer Bigger MAF Swap: How-To
Lancer Factory Service Manuals: Download
Offline
Old Aug 17, 2009, 10:24 PM   #3
03lances's Avatar
Ok cool I know for a fact the head gasket is fine and timing is perfect and putting oil in it raised it about 10psi, not much but enough confirmation for me, they brought over another engine I will be putting in it anyways today so oh well, am trying to get the old engine off them for me then I can strip it down
__________________
16G Turbo build:
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
